CB750 DOHC: Ticking sound
Discussion in 'Motorbike Technical Discussion' started by PWBarrett, Mar 25, 2009.
  1. Oh, I'm crap with electrics. Really. It's just something I've never
    'got'.
    So why does a four keep running on three if you pull off a plug cap,
    then?
    The Older Gentleman, Mar 27, 2009
  2. PWBarrett
    Who Me? Guest
    Yet you somehow feel that you MUST comment on something that you admittedly
    "never got".
    Maybe someone else will waste their time trying to explain but since you
    probably still won't "get it", I certainly am not.
    Go back and re-read the previous 6 posts or so.
    Who Me?, Mar 27, 2009
  3. Oh dear, oh dear, you really are being objectionable.
    Right through this bit of the thread, I have made it plain that I'm not
    particularly good on electrics
    I've used 'AFAIK'.
    I've admitted I'm not good on this, and I admit it again. I'm interested
    in learning new stuff. On other stuff, a lot of stuff, I know a great
    deal. Electrics has always been my blind spot.
    I've read Olson's posting, and I still don't really understand it
    because... well, read the above again.
  4. PWBarrett
    paul c Guest
    You must've forgotten - that was your old Vauxhall, the one with the
    distributor.
    paul c, Mar 27, 2009
  5. Ah. Thanks. Understood now.
    The Older Gentleman, Mar 28, 2009
  6. PWBarrett
    Bob Scott Guest
    Fair enough, learn something new every day.
    Now I'd best go and google Kirchoff's law. One of these days I'll
    actually understand electrical stuff but I'm not going to hold my
    breath.
    Bob Scott, Mar 28, 2009
  7. PWBarrett
    ian field Guest
    The coil is effectively strung between 2 plugs, so the voltage has to jump
    the spark gap at a plug at each end to complete the circuit.
    If you only lose one cylinder with a plug cap off then the spark is
    completing the circuit by some other means, like dodgy insulation on the
    floating lead or where it joins into the moulded coil body.
    A point raised earlier in the thread, if the leakage spark is allowed to
    continue any length of time will burn a carbon track in the insulation, the
    leakage track will eventually become permanent - so no spark at the plug gap
    when the plug cap is put back on.
    ian field, Mar 28, 2009
  8. PWBarrett
    PWBarrett Guest
    Ok - I pulled the pipes on the side where I'm hearing the noise, looked
    closely at everything, and I don't see any cracks or uneven surfaces. I
    replaced the gaskets on that side, put it back together, and it still sounds
    the same.
    It also doesn't change if I push on the pipes.
    I tried running with one plug at a time unhooked (I put an old plug in the
    disconnected cap and wedged it against the block just in case there's
    something to that). It still ticks no matter what.
    So... I pulled the valve cover again. The only thing I can see is maybe the
    upper cam chain slapping against the top chain-guide a little at one point
    in the rotation. But that would make a sound in the center, and the one
    thing I can tell is that the sound is closer to #1 or maybe #2.
    I checked the valve clearances again for the umteenth time. What would you
    consider a clearance excessive enough to cause noise?
    I guess I'll order a cam chain, but just put it back together and ride it in
    the meantime.
    PWBarrett, Mar 28, 2009
  9. PWBarrett
    Who Me? Guest
    That depends on what the recommended clearances are.
    Does this sound go away ......or change much when the engine is thoroughly
    warmed up?
    In addition to a valve clearance problem, it could be a weak (or maybe even
    cracked) valve spring, a sticky valve guide or a burnt and leaking exhaust
    valve.........but the cam chain would still be a good place to start.
    Who Me?, Mar 28, 2009
  10. PWBarrett
    paul c Guest
    ian field wrote:
    Thanks, when I queried that I had compression tests in mind. I
    believe a number of bikes won't crank with the kill switch on,
    certainly I've had a couple of single-cylinder ones like that. I've
    no idea what 'any length of time' could be but I imagine it could vary
    depending on other conditions. When I've watched people taking
    (lengthy) compression tests, I've wondered once or twice why they
    didn't ground the plugs, for safety's sake.
    paul c, Mar 28, 2009
  11. PWBarrett
    PWBarrett Guest
    The book-recommended clearance is .08 mm +.05 -.02
    I was using .09 +.05 -.02 just to avoid excessive tightness when hot.
    Now I've brought that max back down to the book max of .13, and tightened up
    a couple of valves that were on the high side of the range, to bring them
    more to the center.
    Still ticking. (Maybe it's actually a Timex.)
    The sound doesn't go away after a 5 mile ride.
    But it does go away sometimes under load, then come back when I let off the
    throttle.
    Which leads me back to the worn cam chain theory.
    I don't think it's a sticky valve guide or a burned valve, because I just
    re-worked the head. All the valves travelled freely, and I lapped them and
    made sure they didn't leak.
    Oh well, when my new chain arrives, I'll see what that does.
    'anybody managed to swap an upper cam chain with the engine still in the
    frame? Seems like it would be doable. I'm not looking forward to pulling
    the engine again.
  12. PWBarrett
    paul c Guest
    There are many people here who know more about engines than I do, but
    if I'm not mistaken, nobody asked if the four headers heat up equally,
    say thirty seconds after starting from cold. One guess I have would
    be that if they do, that might eliminate a valve as a possible
    culprit. Also, a couple of times, I was able to figure out which
    cylinder by putting a heavy screwdriver on each port and laying my ear
    on the handle. Just a couple of easy suggestions from an admitted
    aamateur...;
    paul c, Mar 29, 2009
  13. My reactions precisely :)
    The Older Gentleman, Mar 29, 2009
  14. Um, in the case of my old air-cooled Kwak four, about two or three times
    the recommended max clearance.
    It's an odd'un and no mistake.
  15. PWBarrett
    Who Me? Guest
    Hot/cold is figured into the published specs. Don't try to out-smart the
    engineers; you will end up out-smarting yourself !! ;-)
    Who Me?, Mar 29, 2009
  16. PWBarrett
    PWBarrett Guest
    Ok - I've swapped the upper cam chain. (The lower one is still using hardly
    any of the range of the tensioner so it's fine.)
    Still ticks.
    I'm hoping it's some shim bucket or other such part that I swapped into this
    head, with a clearance on the tight side, that sticks when it heats up, but
    might wear in.
    OTOH it occurs to me it could be a clogged oil passage, and something's not
    getting oil.
    At this point I'm inclined to ride it till it seizes up, then push it off a
    cliff.
    PWBarrett, Apr 5, 2009
