CB650 charging issue
Discussion in 'Motorbike Technical Discussion' started by Phluge, Jun 24, 2008.
  1. Phluge
    . Guest
    I helped build Apollo 13, and all the rest of the manned Apollo
    capsules, back in 1968 and 1969.
    You wouldn't believe how little the rest of the spacecraft
    electricians knew about electrical theory and what the meter readings
    indicated.
    For instance, I had to straighten out the lead man of the bunch that
    was resistance testing the valve heaters on the service module engine.
    They kept getting the wrong readings and I had to instruct the lead
    man (a former Air Force tech sergeant) about the formula for Ohm's Law
    in parallel circuits.
    Once I had him believing me, we hooked up the valve heaters correctly.
    ., Jun 25, 2008
  2. Phluge
    . Guest
    You should be able to read from the black wire to the white wire, in
    the disconnected plug on the wire harness that goes to the brushes,
    and get about 4 to 6 ohms.
    The stator has three phases and is wye-wound with an un-grounded
    neutral, so any reading to the engine or chassis indicate a short to
    ground.
    Any of the three coils in the stator would produce about 60 volts,
    open circuit, at some unknown RPM, but since they are all connected
    together at the neutral point, each coil gets assistance from the
    following coil in sequence and produce 1.73 times the normal 60 volts.
    1.73 is the square root of 3, there are three coils. If the stator was
    star-wound, with five coils tied together at the center, they would
    produce 2.24 times the nominal voltage, 2.24 being the square root of
    five...
    Ain't it wonderful what my Uncle Sammy taught me in tech school?
    The fact that you get a reading from any yellow wire to any other
    yellow wire in the stator, and no reading to ground on the highest
    resistance scale available indicates a good stator
    You have a bad connection in the field circuit at some point, it may
    be internal inn the rotor, it may be a stuck brush, or a corroded pin
    in the wire harness connector.
    Maybe the regulator isn't getting battery voltage at all?
    There are six power diodes inside the rectifier regulator and the
    three stator leads are connected between the anode and cathode of
    pairs of diodes. So you can read the resitance of three diodes with
    the ohmmeter hooked up postive to negative, then you reverse polarity
    and read the resitance of the other three diodes. This arrangement is
    called a "three phase, full wave rectifier".
    You should get the same resistance reading from each yellow phase wire
    through three diodes, then reverse the leads and read the same
    resistance through the other three diodes.
    If you get no reading through any one diode, you lose half of the
    power of that phase for half a cycle. If you get no reading through
    two diodes, chances are you've lost half the power of the alternator.
    Brush wear depends on how the motorcycle was ridden. I wore out a set
    of brushes in my GSXR in 10,000 miles, but never wore out the brushes
    in either of my GT750's in 90,000 miles.
    Confucious say, "Man with ohmmeter make fool out of self when he
    assume that
    reading on meter mean anything."
    I have spent hours crawling around inside of airplanes with an
    ohmemeter in one hand, a wiring diagram in the other, and an
    assumption that the test current from the meter was going through the
    expected wires and components.
    ., Jun 25, 2008
  3. Phluge
    paul c Guest
    I think it's all good stuff, having a 2nd-level understanding makes 1st
    level diagnosis a lot easier for me.
    paul c, Jun 25, 2008
  4. Phluge
    Phluge Guest
    indicated.
    If I was on the crew of Apollo 13, while Tom Hanks was on the tonight Show,
    pre-launch, I would have already considered everything that could fail and
    designed those duct tape contraptions in my head, and made sure I brought my
    Leatherman along, having rebuilt a carburator in a stepvan using a Swiss
    Army Knife on the road once.
    I have a manual on how to use Multi-Testers that has good instructions for
    checking continuity on power cords for your toaster, but says nothing about
    how/when to use the seven different scales on the ohmmeter. It does say that
    if resistance is too large to measure it will read "1" for infinity-- but
    since it always reads "1" for infinity, how do I know if its the default
    infinity, or the reading across the component, or a lousy connection? That's
    stuff for Uncle Sam to ponder. On Appollo 13 I'd have duct taped that meter
    to Tom Hanks's air supply tube along with its manual.
    I have to wait for delivery of an oil filter bolt I ordered before I can run
    the bike for further probing of the charging system -- should take a couple
    days. In the meantime I will try to think through what you said about my
    results so far. Isn't there some kind of pill you can take for this problem?
    pflu
    Phluge, Jun 25, 2008
  5. And look what happened to that.......
    The Older Gentleman, Jun 25, 2008
  6. Phluge
    Phluge Guest
    If he trys to convince me to change my fuel system to liquid oxygen or
    something I will begin to worry he's trying to send my Honda into orbit.
    pflu
  7. Phluge
    . Guest
    The Apollo program ran *unbelievably* smoothly, with only three in-
    capsule fatalities and one aborted mission.
    The handling of the abort and return to Earth was Gene Kranz' and the
    Apollo team's finest effort.
    The explosion of the LOX tank was blamed on short-circuited internal
    heaters, but I recall an incident which happened to one of the service
    modules (I'm not sure which production serial number service module)
    when technicians tried to remove the wedge-shaped cryogenic shelf
    containing the hydrogen and oxygen tanks.
    Somebody failed to remove one 1/4" high strength bolt, and when the
    crane operator tried to lift the shelf, he was picking up the whole
    13,000 pound module by that one bolt, which snapped.
    The cryogenic shelf flew out of the module and went swinging into the
    catwalk guard rail and back into the service module bay before it
    stopped.
    I have always wondered if that was Apollo 13, but the modules were
    stacked in whichever test stand was available at any given time.
    Production serial number 101 was Apollo 7, it orbited the Earth with
    Wally Schirra as spacecraft commander.
    PSN 102 was scrapped because it had so many repairs and reworks it
    would have been like flying an old junker into space.
    PSN 103 was Apollo 8, commanded by Frank Borman. It went around the
    Moon during Christmas of 1968.
    PSN 104 was Apollo 9, which practiced docking and undocking in Earth
    orbit.
    PSN 105 was an acoustic vibration test vehicle which is on public
    display.
    PSN 106 was Apollo 10, which practiced docking and undocking in orbit
    around the Moon.
    PSN 107 was Apollo 11, the first Moon landing.
    PSN 108 was Apollo 12, the second landing.
    PSN 109 was Apollo 13...
    And on, and on, the spacecraft flew in order of production serial
    number.
    ., Jun 25, 2008
  8. Phluge
    Phluge Guest
    number
    I remember watching the Columbia explosion on TV, then a bit later on the
    car radio it was offhandedly mentioned that one of the possible causes was a
    rubber "O" ring failure because it got brittle in the cold. Having just
    re-built a VW engine in which the valve stem tubes had brittle "o" rings I
    had to replace, the notion blew me away -- I remember thinking about how
    they needed to add a few yard-tree mechanics to support their engineers. It
    would have been like me starting my old VW up in winter and immediately
    jumping on the expressway and gunning it full throttle -- what could
    possibly go wrong? My uncle, who was a yard-tree artist would have foreseen
    that problem at the time it was first discussed.
    I think sometimes training can put blinders on common sense -- the fact
    that a committee of engineers can approve something disastrous shows they
    all come from the same school of thinking. Then sometimes things happen and
    you just cannot believe they ignored something basic -- like I've heard they
    are realizing that Big Brown pulled up during the Belmont Stakes, losing the
    Triple Crown, because of a loose horseshoe. They showed a video of an
    obvious shoe barely hanging on all crooked during the race. So dumb it is
    unbelievable, but it happens.
    pflu
  9. And when you replace the brushes it is a good idea to clean that film
    off - which I didn't do the last time I replaced the brushes, not realizing
    the significance.. Which is why the slip ring cleaning worked for me.
    Ted
    Ted Mittelstaedt, Jun 29, 2008
  10. Phluge
    Phluge Guest
    Thanks. After reading this guy's post I found your original thread (where
    you mentioned the brushes inability to dig into the crud). So I went back
    and found there was still a layer of junk on there. After I cleaned it down
    to bare copper I was hoping for the best but, other than giving me a more
    stabile meter reading between the rings, it did not help with the charging.
    pflu
    Phluge, Jun 30, 2008
  11. You can't troubleshoot this system without the engine running.
    Start the engine. Take a meter and read the voltage at the wires going to
    the rotor and the voltage at the wires coming from the stator. The wires
    coming from the stator are the yellow ones. Make sure when you measure
    the yellow wires your on the AC selection of the meter, when you measure
    the wires going to the rotor you are on the DC selection.
    If you have power going to the rotor, and no power coming out of
    the stator, then with the engine running, use the "deflecting feeler guage"
    test mentioned in my original thread that was suggested by someone
    else. If you put a feeler guage a couple mm from the rotor case
    and feel no magnetic attraction, yet there is 10-12 volts going into the
    rotor, then the rotor is bad. If you feel a magnetic attraction but
    there's no power coming out any of the stator wires, then the
    stator is bad. If there's no power going into the rotor then the
    voltage regulator is bad. ANY bad connection in the charging
    circuit will invalidate any of those readings.
    Was the bike running when parked?
    Ted
    Ted Mittelstaedt, Jul 2, 2008
