CB650 charging issue
Discussion in 'Motorbike Technical Discussion' started by Phluge, Jun 24, 2008.
  1. Phluge
    Phluge Guest
    I need advice from someone knowledgeable re: bike electrics -- if you have
    to guess, I appreciate the help but I have a question whose answer may leave
    no room for error.
    I got a creamer 1979 Honda CB650 with exceptionally low mileage for a steal
    because a guy died and left it to his middle-aged non-biking sister. It has
    the charging problems typical to those bikes. I have researched the issue
    online, gotten hold of the protocols of diagnoses, and read, read, read,
    about it.
    I was able to do the simplest diagnostic tests such as checking, with a new
    fully-charged battery, to see if the voltage increased when revving to the
    given 5000 rpm. There is nothing there but the battery voltage, and if I
    drive it awhile the voltage drops significantly toward dead and will
    eventually kill even the engine. I don't need any more evidence that the
    charging system is kaput. Further, I meticulously cleaned every connector,
    even though they were all already clean and uncorroded, and it made no
    difference. I have no access to a shop, and no desire to do any of the many
    more technical tests -- would rather simply install new parts.
    I intend to replace the regulator/rectifier (one component) and/or the
    rotor. I read from an expert who says the stator is the least likely to go,
    and if it does it is usually a case of some things burning up, of which
    there is no obvious hint so it seems like that should be the last thing to
    consider. I know that, in the case of car electrics, it can matter which
    components you replace first inasmuch as if you do it in the wrong order a
    bad component can cause the replacement of another part to fail. I am
    wondering if any similar conditions pertain to CB650s since I would
    naturally like to replace the parts starting with the least expensive.
    So, what is best -- replace the rectifier/regulator first and if that
    doesn't solve the problem go ahead and replace the rotor too? Or the other
    way around?
    Thanks in advance,
    pflu
  2. Phluge
    paul c Guest
    Wait a couple of days to see if an expert or two here gives some cogent
    advice!
    I'm not one of them, but from what little I know, would think if you can
    check battery voltage, it won't take more than a couple of minutes to
    check stator output (eg., you may have to remove the seat). That might
    certainly help to isolate things to a useful degree. Could save quite
    a few bucks plus lots of wasted time obtaining parts one by one.
    paul c, Jun 24, 2008
  3. Phluge
    . Guest
    How about checking the alternator brushes before buying parts you
    might not need?
    ., Jun 24, 2008
  4. Phluge
    Why not find out which component is duff before you start throwing bits
    at it in the hope that the right one will stick?
    Check if the alternator is actually working first - ie, measure the
    output which is normally stated in the workshop manual - and if it's
    dead, replace the rotor. If it's not dead, replace the reg/rect.
    Timo Geusch, Jun 24, 2008
  5. Phluge
    Phluge Guest
    I appreciate the suggestions you all have provided so far and will follow up
    on them all. Thing is I am pretty much dependent upon the internet since I
    live about 159 miles away from any shop, and I possibly sound naive inasmuch
    as I am trying to narrow down what is an overwhelming amount of detail on
    the technical forums -- it's not that I wouldn't want to go there but am
    limited to a multi-meter out here in the woods. I can't afford to do more
    harm than good out of an admitted ignorance of bike electrics, and most
    advice assumes you can run down the block to get stuff.
    That is not to say, however, that I am ignorant re: motorcycles. I started
    out with A Harley 74 back in the day when a chopper meant removing the front
    fender leaving a bare wheel, and cutting it down to use as a rear fender.
    All the ramp jumping, trail riding through the woods, etc. was done on those
    big babies and you wouldn't believe the agility some riders had with
    manhandling those monsters doing tricks. Since, I have pretty much covered
    the US on various sized Hondas, having fixed chains at 3 a.m. on an
    interstate using a penlight with concrete highway marker for an anvil --
    that sort of thing. So for any of my friendly pussy-hearted flamers whose
    succinctness ends at "**** you", I would be happy to invite you to come up
    here to Northern Minnesota rather than hide behind the anonymity of Usenet,
    where I would be happy to rip your face(s) off and tuck it under your poopy
    diaper; the bigger pile of shit, you are, the better.
    If I tax anyone's patience with further questions I apologize, inasmuch as,
    like you, I try to do the best I can. Thanks.
    pflu
  6. Phluge
    Phluge Guest
    Paul,
    Can you elaborate -- how do I check the stator output? Is that the one where
    you measure the voltage across the battery with the engine at fast idle?
    pflu
  7. Phluge
    Phluge Guest
    might not need?
    OK, that will be the next thing I will do. Thanks,
    pflu
  8. Phluge
    . Guest
    If the brushes are OK, you can probably disconnect the field leads
    from voltage regulator and excite the rotor field with 12 volts DC
    direct from the battery and see if that raises the output voltage
    while the engine is running.
    The voltage regulating function of that type of regulator is just a
    transistor which is
    turned ON when the ignition key is ON, and then it turns OFF when
    battery voltage rises above 14.5 volts.
    We discussed CB650 alternators EXTENSIVELY in this group about two or
    three years ago, and, AIR, the field leads are the black and white
    wires. One CB650 rider e-mailed me images of the pages from his Clymer
    or Chiltons manual, but I deleted them already.
    ., Jun 24, 2008
  9. Phluge
    paul c Guest
    Phluge wrote:
    If I've got it right, that one tests the whole charging system (except
    for the battery), not the stator/alternator output by itself. I found a
    wiring diagram at
    http://cosky1.tripod.com/index.html
    under the seat there will be a multi-wire connector that joins the
    alternator to the reg/rect and probably three of those wires will be
    yellow in colour (plus two more, one black and one white). You can
    check the yellow ones in pairs, eg., uncouple the connector then check
    each yellow to one of the other yellows, with the meter set to AC
    voltage - if the alternator is working fairly well, on each of the three
    pairs you should see much more than 12 VAC, perhaps as much as 30 or 40
    VAC when you have the engine revving fast, say 4000 or 5000 or more.
    That would tell you there is good chance there is nothing wrong with the
    alternator.
    I see there is another post from "." about testing the reg/rect itself
    with battery which would help point the finger at that part if it is bad.
    As I said, I'm not an expert, my electrical trouble-shooting skills are
    so amateur that nearly always I have to refer to an online source or
    an electrical troubleshooting book, but not always the factory service
    manual (it seems some of the typical resistance tests in factory manuals
    aren't always helpful because while they may tell you a part is bad,
    they don't assure you the part is good).
    Not telling you what to do, bu a couple of sources I know of, eg. on the
    www are:
    http://www.motorcycleproject.com/ gives some tips, one I like is how to
    make a high current shunt.
    Some shortish books that I know of are
    "motorcycle electrics without pain" by Mike Arman
    "motorcycle electrical systems" by Tracy Martin
  10. Phluge
    paul c Guest
  11. Phluge
    ian field Guest
    Someone posted quite recently with a similar problem - they cured theirs by
    cleaning the slip rings under the brushes.
    ian field, Jun 24, 2008
  12. Phluge
    . Guest
    That's usually a stop gap fix. Worn out or sticky brushes don't make
    good contact, and a black film begins to coat the slip rings or
    commutator segments.
    ., Jun 24, 2008
  13. Phluge
    . Guest
    No, I was talking about manually exciting the rotor field by applying
    battery
    voltage across the B and F terminals.
    ., Jun 24, 2008
  14. Phluge
    paul c Guest
    Oh sorry, I guess you are talking about testing the rotor and stator in
    isolation?
  15. Phluge
    Phluge Guest
    transistor which is
    I don't doubt that a bit -- from the looks of the forums I have found it
    seems like every owner has had these problems, has input re: solutions, and
    leaves a guy-who-can-barely-interpret-an-ohmmeter's head spinning. I have a
    few pages printed out from a manual, have followed their diagnostic
    instructions as close as I can figure. Here are the results I got: (I used
    the 200ohms scale on a digital meter)
    1.Brushes are fine -- at least 10mm above the mark. I did not try your
    suggestion to excite the rotor from the battery yet, I have the oil drained
    and a new filter bolt on order -- plus I'd be scared a little shitless.
    2. Stator test: Continuity between all yellows is .9. Book calls for 0.5 -
    1ohm. I don't understand these scales, it just says replace if there is no
    continuity. Ther was no continuity with anything for the black or white
    wires, none with any to ground.
    3.Rotor test: It says some very low resistance should be between the slip
    rings (approx. 4-6ohms). My meter jumps all over between about 10 to 175 on
    the 200ohms setting -- I don't know what that is all about. There is no
    continuity between rings and ground. It says that most of the time when
    rotors are bad there will be either infinite resistance (burnt out) or less
    than 2ohms, (meaning internally shrted.)
    4.Voltage Regulator test: "With ignition on, bike not running, you should
    get less than battery voltage between the black and white ires from the
    regulator." I get 0.00 Volts.
    4. Voltage regulator performance test: Voltmeter between + and - battery and
    rev engine. Says it is supposed to prevent it from going over 14-15V, but
    there is no change at all in volts at 5K rpm.
    RE: the regultor/ Rectifier test: The manual makes me crazy here. It tells
    you to measure between the green rectifier lead to each of the three yellow
    leads in both neg and pos directions (should all be the same , HIGH or LOW
    with opposites between polarities). Do they mean to measure WITHIN the
    rectifier or BETWEEN the rectifier and alternator leads? Then you measure
    between the red/white and the three yellows, one direction, all must be the
    same either high or low -- again, within or between the alternator?
    Does the fact that this bike has only 8,061 original miles give you any
    clues? The brushes seem barely worn.
    I'd truly appreciate any interpretation you can offer about my clumsy
    attempts at measuring. The mosquitoes are out in full force day and night
    and they cetainly love it that I am out there sweating. Thanks,
    pflu
  16. Phluge
    Phluge Guest
    I did clean them when I measured their resistance etc. -- they were a bit
    filmy while the brushes are fine.
    pflu
  17. Phluge
    paul c Guest
    Just my three cents of coourse:
    1) I believe one measures the rect/reg right on its terminals.
    2) I still think it's best to do a dynamic test of the alternator
    output, if that shows healthy voltages you could probably eliminate the
    alternator as the problem. Lots of factory manuals say to do that even
    if this one doesn't.
    3) Also, I was assuming the battery is good, but was just wondering if
    perhaps there is a blown fuse between the reg/rect and the battery?
  18. Phluge
    paul c Guest
    paul c wrote:
    Or just a bad connection/chafed/loose wire?
  19. Phluge
    paul c Guest
  20. Phluge
    Phluge Guest
    Battery is brand new.
    The fusible link is good, all the connections are sound and clean and there
    are no damaged wires. I cleaned everything even if it looked good. Other
    than a few riding dings this bike is pristine -- was kept indoors and hardly
    ever driven (avg. 278 miles/year).
    I have seen most of the links you gave, printed out some stuff including the
    "Fault-finding" diagram --thing is I am up to my ears in tests and results
    that I'm not sure I know how to interpret at this point. Like I said, I have
    a digital multitester I barely know how to use (but I'm a persistent
    son-of-a-bitch, the kind they would have liked to have on board Apollo 13. I
    will worry a problem until it gets solved).
    I did all the running type tests last week before draining the oil out and
    I'm waiting for delivery of a new filter bolt before I can do any more.
    I certainly appreciate your help.
    pflu
