I have a 1974 CB550. It runs great for a few minutes, then it will start to run rough, like it is not running on all cylinders. I check the fuel filters and one is full, the other is dry. I tested the flow from the fuel valve by connecting to fuel lines into a gas can. When I turn open the fuel valve, the following occurs which may or may not be normal. When I open the valve, fuel flows from line A but nothing from line B. If I plug line A with my finger, then fuel begins to flow from line B. I release line A fuel is still only flowing from line B nothing from line A. I plug line B with my finger and fuel begins to flow from line A again Now if I release line B, fuel will flow from both lines. If I turn the valve off, then on, fuel is only flowing from line A again. I can repeat this process every time. I’m not sure if this is normal or not. I have completely taken apart and cleaned the petcock, it now looks brand new inside. There are no leaks. Part of getting the bike ready to ride this year included buying a new set of carbs that were already rebuilt. I put them on and adjusted the sync and the idle. I have not made any other adjustments to the carbs. Is there something else to adjust that will help the fuel flow or should I try to replace the petcock? Thanks John
