cb400t throttle cable
Discussion in 'Motorbike Technical Discussion' started by ericngsta, Jul 7, 2008.
  1. ericngsta
    ericngsta Guest
    Hi. I have a '78 cb400t. Just cleaned the carbs and as about to put
    them back in when i discovered that one of the throttle cables broke
    (there are two). My question is do I need the second cable at all?
    When I turn the throttle it pulls on the good cable and returns when i
    pull on the good cable on the carb end. If i do need that second
    cable, where can i get one? Couldn't find anything on ebay. Would it
    be possible to just buy the actual wire and thread it through the
    cable jacket and solder on the ends? Any advise would be great.
    Thanks, eric
  2. ericngsta
    Bruce Farley Guest
    You can get jst the inner wire and solder on the end. I would first see
    if you could order the cable from a Honda dealer. If you can get it I
    would order both of them.
    Bruce
    Bruce Farley, Jul 7, 2008
  3. ericngsta
    . Guest
    The second cable is a positive backup to prevent the motorcycle from
    running away if the throttle sticks open.
    The handy thing about two cables is that the cable that opens the
    throttle is usually the one that breaks, so you can just swap the
    other cable over to
    that side in order to get to a $tealer$hip to buy a new cable.
    Go to www.denniskirk.com or the Tucker Rocky catalog online to find
    aftermarket parts for your bike. Also, try www.oldbikebarn.com
    ., Jul 7, 2008
  4. Yes, it is a safety feature. Some years back, a guy was killed when
    his throttle stuck at WFO while overtaking a car.
    I remember it very well, because I had been riding that same road only
    a few hours before the accident.
    Robert Roland, Jul 7, 2008
