CB400 Again
Discussion in 'Classic Motorbikes' started by johnsmith, May 12, 2004.
  1. johnsmith
    johnsmith Guest
    this was posted below, but Im not sure if it went thru because Im not over
    good with this...
    The guy was good to his word and sent the rubbers for the cuch drive.
    Next stupid question, can I take the hub out of one wheel by loosening the
    five bolts around it, and put another one in. Then I wouldnt have to change
    the tyre and evryting.
    If I shouldn't be asking this stuff, pleese let me know.
    Cheers
  2. johnsmith
    Mark Olson Guest
    Mark Olson, May 12, 2004
  3. johnsmith
    Triffid Guest
    <HBOL Mode>
    Remove wheel
    Replace rubber bits which will have fallen out anyway
    Replace wheel
    </HBOL Mode>
    You may find that you can't get the wheel out from under the mudguard.
    Trying to lift the bike with one hand and manhandle wheel w'it tother is a
    BAD idea. In this case just change the bits as soon as you can get at them.
    Actually, do that anyway.
    Triffid, May 13, 2004
