CB125S camchain adjustment question
Discussion in 'Classic Motorbikes' started by The Older Gentleman, Aug 28, 2005.
  1. The camchain adjuster on these little lumps (1972 model) is on the
    left-hand crankcase half. what looks exactly like a screw and locknut
    assembly - 14mm locknut, and threaded adjuster poking through it wth a
    slot for a screwdriver blade.
    Irritatingly, I've only got a Haynes BOL of the CB100N. Same engine, but
    that has a 10mm headed bolt poking through the locknut. BOL says to set
    engine to fast idle, undo locknut, retighten, tensioner does the rest.
    Presence of screwdriver slot suggests earlier model is slightly
    different. I tried loosening off the locknut, wth engine set to TDC, so
    obviously not running, and slackened off the slotted adjuster.
    The usual procedure with these things, from clutch to camchain
    adjustment, is to tighten carefully until you feel resistance, back off
    a quarter of a turn or so, and do up locknut. But twiddling it one way
    or t'other felt exactly the same, so I reset it to its original position
    and re-tightened the locknut.
    Has anyone got a manual giving the definitive procedure for an old CB125
    single? Or does anyone know for sure? The engine sounds sweet - I only
    decided to check the camchain as I was doing the tappets - but it would
    be nice to know for future reference, as it were.
  2. The Older Gentleman
    Loz H Guest
    The Older Gentleman <> spewed forth the
    following...
    Lesson #1 in Usenet.
    Read the post you are replying to in full before you spend a patient 10
    minutes copying text relating to all things camchainy from the Haynes BoL
    for Honda Twins (CB125/160/175/200/SS125/CD175), along with a further 5
    minutes personal experience and notes relating to such.
    D`oh. I`ve not got a fuckin` clue about the CB125 single....
    Anyway, this bit.
    Tighten carefully until resistance then back off slightly/tighten locknut is
    valid for clutch adjustment, but not camchain tensioner surely? All the
    tensioners with I`ve come across have all been nipped up nice and tight.
    Loz H, Aug 29, 2005
  3. Yes, you're right. Wasn't thinking when I posted. All old Honda
    tensioners are like that - undo locknut, undo nut, tighten up not,
    re-tighten locknut.
    The point I'm making is that I did try and tighten it up, but couldn't
    feel any resistance.
    The Older Gentleman, Aug 29, 2005
  4. The Older Gentleman
    cable news Guest
    could be that chain is stretched past its max adjustment hence no resistance
    when screwing in adjuster,though i believe theres plastic slides which are
    the tensioners and these do wear out as i found out on in times past on 250n
    and cb100 models....S
    cable news, Aug 30, 2005
  5. 12k miles from new. Nope.
    The Older Gentleman, Aug 30, 2005
  6. The Older Gentleman
    cable news Guest
    oh...only 12000 miles, i didnt know that,..may i ask of symtoms? ty S
    cable news, Aug 31, 2005
  7. Can I suggest you re-read the original posting?
    The Older Gentleman, Aug 31, 2005
  8. The Older Gentleman
    I know you said it wouldn't tighten "one way or t'other", but did you
    go far enough in "t'other" direction? It was unscrew to tighten on
    TL125s, which I believe was the same engine.
    Krusty, Aug 31, 2005
  9. The Older Gentleman
    Steve Parry Guest
    Krusty fumbled, fiddled and fingered:
    Wot he sed ... I had a CB125S and the adjustment screw was anti
    clockwise to adjust the tensioner. It pulls the sprung blade upwards,
    which causes the blade to push forward in the centre tensioning the
    chain. Don't do it too much though cos it's only held on with a circlip.
    If you ever need to remove the rotor to get at the aforementioned
    circlip, I seem to recall the rear wheel spindle was the required thread
    to work as a rotor remover :)
    Steve Parry
    K100RS SE & F650
    (not forgetting the SK90PY)
    http://www.gwynfryn.co.uk
    Steve Parry, Aug 31, 2005
  10. I put it back exactly as it was before I fiddled with it. Thanks to you
    both for the info.
    It usually is, believe it or not. Actually, I have a genuine Honda tool
    in my toolit...
