hello everyone, here's one for you..... CB125RS/D just had complete engine rebuild, including (but not limited to) gearbox bearings, mains, big-end, crank pin, rod, piston and rings, cam, cam bush, all new valve gear, atu, etc, etc. Trouble is, I'm still getting a noise that I can only describe as sounding like a big-end gone coming from the motor. Thought I had it sussed, as the rev-counter drive gear seemed to be rattling in the clutch case, removed it, but alas, no different. No difference whether clutch is in or out, and if I had to put money on it (rather than into it), I'd say it's bottom end, almost gearbox. Any thoughts on something obvious I've overlooked?? Ta muchly, Rick.
