Caution - motorcycle related content - wet running. Or not IYSWIM
Discussion in 'UK Motorcycles' started by Gyp, Oct 25, 2004.
  1. Gyp
    mups Guest
    Lozzo says...
    He's going to face the final curtain.
    mups, Oct 25, 2004
  2. Gyp
    Eiron Guest
    There's no Hope either.
    Eiron, Oct 25, 2004
  3. Gyp
    <sticks neck out>
    I'm no BMW expert, although having ready access(1) to the
    multi-voluminous Spic Book of Borked Beemers is correcting this
    situation rapidly ... coil. I've heard this plaintive cry lots of
    times and it is always a bloody coil. If it was a plug, or a lead, or
    even a carb, it would start on the remaining cylinder(s) but miss like
    a fucker.
    If it won't even start then it is always a coil.
    If it goes sick at the slightest hint of a splash, it'll be a coil.
    <sticks neck even further out>
    Split, it will be, mark my words.
    1. Vols 1 - 36 in the downstairs lavvy, 37 - 48 on the stairs making
    their way to join the senior vols, 49 - 187 along the landing and all
    the rest spilling out of Spic City in the corner as they run off his
    printer and out the door ...
    Pip, Oct 25, 2004
  4. Bzzzzt! Wrong dead singer.
    The Older Gentleman, Oct 26, 2004
  5. Gyp
    Gyp was seen penning the following ode to ... whatever:
    They all do that sir...
    Timo Geusch, Oct 26, 2004
  6. Gyp
    From memory - I got mine readily converted with a fitting kit and the
    necessary cables - you need a bracket to mount it, plus some cables to
    hook up both HT and LT sides.
    I got mine from http://www.q-tech.de/, part 116.11. He wants 76 Euros
    for it, which includes a set of HT cables as well.
  7. Gyp
    The Older Gentleman says...
    I'd say. Bing and Frank had a bit of a bust up when Frankie was but a
    mere lad.
    I'm sure they kissed and made up, but I don't think they ever really got
    on well.
    Lozzo, Oct 26, 2004
  8. Gyp
    Gyp Guest
    No need to get your hands dirty.
    Cracked to buggery is a suitable description.
    Gyp needs a new one :-(
    Gyp, Oct 26, 2004
  9. Gyp
    Owen says...
    3rd pencil this week.
    Lozzo, Oct 26, 2004
  10. Gyp
    Owen Guest
    Let us guess... You're licking that fucking pencil, aren't you...?
    O
    1 Black, shortly to undergo extensive surgery.
    1 Red, undergoing lightweight surgery. -----
    1 Blue, for Power-Ranger baiting. | o |
    Numbers ... | o |
    Stuff ... | ooo |
    Life ... -----
    Owen, Oct 26, 2004
  11. Gyp
    The genuine (Boche) article is about £70 from either of the Usual Suspects.
    The K100 dual-output coil can, I'm told, be made to fit. I got one of
    these, but in the end, couldn't be arsed to bodge it. Said K100 coil is
    languishing in the shed if you want to try it for size.
    platypus, Oct 26, 2004
  12. Gyp
    Yeah, I know that - I actually don't even know if he speaks English at
    all :-(.
    Well - I can order you a coil, no problem - I've ordered from him
    before, the only snag being AFAIR that he doesn't take credit cards so
    it's bank transfer time.
    That said, most of the Beemer nuts I know (yeah, they're mostly
    septics, so what) swear by this type of conversion. The additional
    advantage of the Q-Tech kit is that it's essentially one half of his
    rather good dual-plug setup and I think you can just buy the rest of
    the kit with a single coil instead of two coils.
    I put this conversion on my GS and if I ever have another, I'd do the
    same even if the coil wasn't cracked. What the guy doesn't know about
    Beemer ignitions isn't worth knowing...
    Timo Geusch, Oct 27, 2004
  13. Gyp
    Gyp Guest
    E-mailed
    Gyp, Oct 29, 2004
