Caution - motorcycle related content - wet running. Or not IYSWIM
Discussion in 'UK Motorcycles' started by Gyp, Oct 25, 2004.
  1. Gyp
    Gyp Guest
    Right then, this Beemer of mine. Recently it's got a little unwilling to
    run in the wet, i.e. if I wash it, it won't start. If I'm out and it
    starts to rain it starts misfiring.
    Now, when it wouldn't start a couple of days ago I checked and I was
    getting spark. Not a big fat pyrotechnic spark, but a spark nonetheless.
    Not enough of a spark though, I'd suggest.
    So what is it that stops the ignition working properly in the wet?
    Leads? Coil? Electronic ignition module thingy? Wiring connections?
    Left-handed froggle-grommet? All of the above?
    I'd rather not replace everything if it's not necessary so pointers
    welcome. If I have to get the Avo out and open the only pages of the
    HBOL that don't have oil on then so be it.
    Gyp, Oct 25, 2004
  2. Gyp
    Salad Dodger Guest
    Are you mad? It's October, ffs!
    Motorcycle related content indeed!
    Be off with you?
    Try
    uk.rec.mobilephones.jobs.video.books.PC_help.anyoldiron.butnotmotorcycles
    | ___ Salad Dodger
    |_\_____/_| ..73063../..16589.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
    Salad Dodger, Oct 25, 2004
  3. replace you HT leads or when it starts to play up grab hold of one and see
    if you get a skock if you do the the rubber on the out side has detereated
    and letting current travel on the out side to the engine block, also check
    spark plug gap and points etc if you got them
    Chris Griffiths, Oct 25, 2004
  4. Gyp
    Gyp was seen penning the following ode to ... whatever:
    Grey coil? Potentially the original? Check for cracks. Most likely
    it's fucked, and they all do that.
    Replace with adapted R1100 coil. Far better, doesn't crack, cheaper to
    replace if it goes wrong?
    Timo Geusch, Oct 25, 2004
  5. Gyp
    Is that the original coil? The monos were known for that. The old coil off
    mine had three full-length splits in it.
    There's two fixes: either slather the thing in grease and freezer bags, or
    New Coil.
    A good test to see if this is actually the cause of the problem is to borrow
    the new coil orf the Evil Twin, which is not currently using it much.
    platypus, Oct 25, 2004
  6. Gyp
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Gyp
    Get somewhere nice and dark in the wet and fire it up. Look for sparks.
    Nigel Eaton, Oct 25, 2004
  7. Gyp
    Gyp says...
    <snigger>
    Lozzo, Oct 25, 2004
  8. Gyp
    Gyp Guest
    It's the same fault I mentioned a few days ago and you made a note then
    and you don't get anything for a pair of faults.
    Gyp, Oct 25, 2004
  9. Gyp
    Gyp Guest
    But it's only 15 years old FFS. What sort of reliability and build
    quality is that?
    Gyp, Oct 25, 2004
  10. Gyp
    Gyp Guest
    Oooh ta, though I'm not entirely sure when I'd manage to pop in & pick
    it up. Possibly early (or mid) Saturday?
    Gyp, Oct 25, 2004
  11. Gyp
    Gyp says...
    You do, you get a snigger from me.
    Lozzo, Oct 25, 2004
  12. Gyp
    Gyp says...
    I've never had to replace a coil on an RD yet, and lots of those I've
    owned have been well over 15 years old. Buy a proper bike.
    Lozzo, Oct 25, 2004
  13. Gyp
    rb Guest
    Although in your case you would hear it on the radio I suppose.
    rb, Oct 25, 2004
  14. Gyp
    Gyp Guest
    As the R1100 coil is 1/2 the price, what adaptation is required?
    Gyp, Oct 25, 2004
  15. Gyp
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, rb
    Hadn't thought of that. Probably.
  16. Gyp
    Nigel Eaton Guest
    Remove all the bits of R80RT, dispose of them carefully and replace with
    an R1100.
  17. Gyp
    Well, I'll be doing a few hours in work this week, so I'll be in the
    Gloucester area. I'll bell you when I've separated it from the carcase.
  18. Check the float bowls for water - the old Bings were notorious for it.
    The Older Gentleman, Oct 25, 2004
  19. Gyp
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, The Older
    That and golf. And really crap Xmas specials.
  20. Gyp
    Nigel Eaton says...
    He's on the road to nowhere now
    Lozzo, Oct 25, 2004
