Yesterday. being the first day of feeling well enough [1] to do *anything* except UKRM or daytime TV, I decided to degrease and re-lube the chain on the Zephyr. Having liberally coated the chain / garage / myself with copious quantities of paraffin, I applied a good coating of the above product. It went on very easily, with very little overspray. Having taken the bike out for some minor bimbleage, there also seems to be very little fall-out on to the back wheel, much less than with the Fuchs stuff I used previously. All in all, I am fairly impressed with it. Now to see about adjusting the chain tension....... I may be some time. [1] It still took 2 of us to get it on the centre stand mind. -- Dan L (Oldbloke) My bike 1996 Kawasaki ZR1100 Zephyr Space in shed where NSR125 used to be Spare Bike 1990 Suzuki TS50X (Patio Ornament) BOTAFOT #140 (KotL 2005/6), X-FOT#000, DIAABTCOD #26, BOMB#18 (slow), OMF#11
I've got a can of it here. It starts off nice and white and gets dirtier and dirtier as the miles go on. It's such a bastard to get the dirty brown residue off too. I stopped using it about 8k before I replaced my chain (changed to Silkoline stuffage) and there were still bits of the white/brown stuff left on it when the old chain was binned. That is nomatter how much I scrubbed and threw parafin at it.
Chain wax is shite. As Nick says, looks nice as long as you don't use the bike. May be good for an over Winter layup, but that's about it. It doesn't fling, granted - but it doesn't lubricate either. It keeps the water off, but all the nasty little bastard gritty particles stick to it like the proverbial sand to a helmet during beach sex. It provides the ideal environment for chain wear, in fact - forming a very unpleasant grinding paste. Stick to chain lube or fit a Scottoiler.
LMFAO, oh well, it was an enjoyable few hours in the garage. I feel another garage / paraffin interface coming on. Alternatively, as the chain and sprockets are the originals, perhaps it's time to consider getting them replaced with a nice gay gold set. WRT Scottoilers, I had one on the CB500 and really could not get on with it at all. It lost it's injector 3 times and spunked it's contents all over the rear tyre, so I left it on when I sold the bike. I was very disappointed with it, as just about everyone else I know who uses one raves about them. Maybe a second chance should be given. The previous chain lube I used (Fuchs) was very messy, and used to fling itself off for days afterwards. What is the FOAK's chain lube of choice, (obviously excluding the eponymous komodo dragon spunk)?. -- Dan L (Oldbloke) My bike 1996 Kawasaki ZR1100 Zephyr Space in shed where NSR125 used to be Spare Bike 1990 Suzuki TS50X (Patio Ornament) BOTAFOT #140 (KotL 2005/6), X-FOT#000, DIAABTCOD #26, BOMB#18 (slow), OMF#11
Hmm, I was expecting it to leave a white film over the chain, but it didn't. -- Dan L (Oldbloke) My bike 1996 Kawasaki ZR1100 Zephyr Space in shed where NSR125 used to be Spare Bike 1990 Suzuki TS50X (Patio Ornament) BOTAFOT #140 (KotL 2005/6), X-FOT#000, DIAABTCOD #26, BOMB#18 (slow), OMF#11
eBay get clever? Or is this something wot is known about. "Your search using snotoiler returned 0 results. This keyword has been replaced with scottoiler. Undo"
In uk.rec.motorcycles, Pip belched forth and ejected the following: What 'e said, apart from the Scottoiler bit. I still think to lube a chain properly by hand is the only way
Well curiously I've never had any trouble with it, seems to work fine and I've not had prematurely wearing chains. So there! )~ Of course I now have some Motrax Gold chain lube which also seems to work very nicely, it was complimentary with the new gold chain and of course it keeps it looking, well, gold.
Just like a Chav's bling......... ;-PP -- Cheers! Fr Jack B12S (The Red Mist), CB450DX (The Moped) FRJACKUKRM AT GMAIL DOT COM Red death, to set you free
When I had one on the SV I positioned the feed tube so that it directs the oil onto the back sprocket. This keeps the tube out of the way of the chain and gives it some room to flex (over bumps, etc) and means the oil is fed down the sprocket onto the chain. It worked well and I'd recommend this method if you get a new one. If you don't, I use PJ1 lube which does the job. I haven't fitted a scottoiler to the 955 as I'm not sure how to go about it.
I've just bought another CD250 which I'm busting for parts, and the previous owner had lubed the chain with Copaslip. He'd also splashed the stuff on every exposed bolt head he could find.....
Did you shake the can properly and if not have you covered your chain in a load of propellant instead of wax? I think the optimum time to re-lube the chain is when it stops to look shiny and wet. The chain wax never looks shiny or wet so when does one know when it needs a lube?
The Older Gentleman wrote So that will be most of ukrm singing the praises of ceramic chain oils next autumn then? My snotoiler drips.
Erm, yes, I shook it most vigourously. I looked at the chain again today, and I have to admit it looks pretty bloody good. The xchainwax tin does say "new formula", I wonder whether it has been improved since you tried it. -- Dan L (Oldbloke) My bike 1996 Kawasaki ZR1100 Zephyr Space in shed where NSR125 used to be Spare Bike 1990 Suzuki TS50X (Patio Ornament) BOTAFOT #140 (KotL 2005/6), X-FOT#000, DIAABTCOD #26, BOMB#18 (slow), OMF#11
Tis good shit. Since buying my new bike, I've only had to adjust the chain twice in 2200 miles and I too use Castrol chain wax. I always clean the chain with a rag soaked in WD40 before re-applying the wax and the chain still looks brand new.
