Castle nuts and torque
Discussion in 'Motorbike Technical Discussion' started by Mike W., Sep 30, 2006.
  1. Mike W.
    Mike W. Guest
    This seems so common there should be a rule of thumb about it that I just
    don't know yet. You're torquing a castle nut that will, when you're done,
    have a pin inserted through it to hold the nut in position, such as on a
    rear axle. In general you're going to hit your torque value prior to
    arriving at a perfect alignment for the pin. What's the rule? Next tighter
    hole or previous/looser hole? Thanks.
    Mike
  2. Mike W.
    B-12 Guest
    If you're talking about the stub axle of a car which uses tapered
    rollers, you would back the nut off to avoid overtightening the bearing
    and destroying it in a few thousand miles.
    But you're probably talking about a motorcycle axle that uses roller
    bearings. Properly installed roller bearing sets have spacers in
    between the pair of bearings and on either end, and the spacers take
    the axial loads, so you can tighten the axle to the max torque without
    worrying about hurting the bearings.
    But, be sure to spin the wheel after torquing the nut to be sure it
    spins free. Motorcycles with overtightening front wheel bearings don't
    steer well.
    Also, is the head of the axle free to turn, or is it held by a retainer
    at the head end?
    In the former case, you should be able to *rotate* the axle into a
    position where the hole and the nut align at the same time with perfect
    torque.
    In the latter case, you might need to use a very thin washer under the
    nut to get the holes and slots to align at the same time.
    B-12, Sep 30, 2006
  3. <boggle> Name one motorcycle that uses roller-bearings in the wheels. I've
    never met one. It'd be total overkill.
    So, of course, do the more common ball bearings.
    But you just said you can't overtighten the bearings?
    Absolute bullshit. The required torque will be reached at a
    particular position of the nut w.r.t. the threads; any rotation of the
    axle as a whole will not affect this relationship.
    If you're that anal, yes. My response would be to adjust the nut to
    the closest alignment position[1], but I don't recall ever using a torque
    wrench on axle nuts...
    [1] With the caveat that if that was at the looser position, I'd loosen back
    further than that and then snug back up, in case of hysteresis effects due
    to friction.
    Dr Ivan D. Reid, Oct 1, 2006
  4. Mike W.
    John Johnson Guest
    Or maybe they figure we like the "racer" style that the cotter pin gives?
    Later,
    John
    John Johnson, Oct 1, 2006
  5. Mike W.
    TOMO.MEMAR Guest
    If its an axle nut you are talking about, doing the nut up a little
    more so as to get the split pin to line up will be fine! Ive been a
    bike qualified motorcycle mechanic for twenty years and never had a
    problem yet doing it this way... good luck! Tommo. PS if you want to
    get really picky find the correct torque setting for the size of the
    axle, do the axle up to that setting and then go to the next split pin
    hole.
    TOMO.MEMAR, Oct 1, 2006
  7. Years ago, ISTR reading that some Harleys used needle roller bearings
    and that a tiny amount of sideways play in the wheels was actually
    normal.
    Can anyone confirm? It seems too bizarre (on both counts) to be true.
    The Older Gentleman, Oct 1, 2006
  8. Mike W.
    John Johnson Guest
  9. Mike W.
    Mike W. Guest
    Thanks all. It's a rear axle on a KZ1000P. The caveat about bearing type
    was great and I've been going in the direction of tighter, so I'm doing the
    right thing. Thank.s
    Mike
    Mike W., Oct 1, 2006
  10. Mike W.
    B-12 Guest
    If the cotter pin *falls* into the hole, it's too small, use the next
    larger cotter pin.
    I've installed cotter pins by tapping them into the hole lightly with a
    small ball peen hammer for decades.
    The muffler will sometimes get in the way of the hammer swing, so I
    rotate the axle so the cotter pin hole will be horizontal.
    Part of the head of the cotter pin will seat down into the castellation
    so the cotter pin cannot rotate.
    If cotter pins are too long, they should never be cut to length with a
    pair of diagonal cutters. This leaves sharp ends and any mechanic who
    cuts himself on a shap cotter pin will curse the asshole who installed
    it.
    Long cotter pins can be trimmed with a screw cutter like you see in the
    side of a pair of insulated lug crimpers.
    The ends of the cotter pin are properly bent with the hammer, by gentle
    tapping. The long side will cross over the end of the axle, the short
    side will go down the side of the nut.
    A cotter pin installed in this manner will not rotate back and forth,
    so it won't fret against the nut.
    B-12, Oct 1, 2006
  11. <snip>
    Or just use an R clip.
    The Older Gentleman, Oct 2, 2006
  12. Mike W.
    B-12 Guest
    They look very racer-ish, but can easily be pushed out of the hole that
    they are not designed to fit in. Lynch pins work best if they can be
    pushed in so far that the
    big end is occupying the hole.
    Racer wannabe's will install a Lynch pin to achieve the pukka look of a
    "real" racer, and they also believe that the pin will speed up their
    wheel changing in the paddock.
    Lo, and behold, when they go to quickly change the wheel, the Lynch pin
    is *gone*...
    So, they look around to see what the raceresque solution to *that*
    problem is, and find that the experienced guys have safety-wired the
    open end of the Lynch pin, defeating the quick removal feature...
    B-12, Oct 2, 2006
  13. *Shrug*
    They work for me, although they certainly don't fit everything.
  14. BMW
    Rob Kleinschmidt, Oct 3, 2006
  15. Really?
    <Examines sig>
    Which?
    The Older Gentleman, Oct 3, 2006
  16. /2 through 1984 rear wheel, /6 through R80 front wheel, and all
    swingarms up to 1/81
    Part # 07 11 9 985 005 17x40x12 tapered roller SKF 30203
  17. Well I'm damned. Didn't stop my old RS rear wheel bearings collapsing at
    70mph, mind.
    The Older Gentleman, Oct 4, 2006
