carburetor tuning
Discussion in 'Motorbike Technical Discussion' started by tjbabar, May 31, 2008.
  1. tjbabar
    tjbabar Guest
    I have a 1976 CB750F with a Keihin CR-Special. When I first bought
    the carb and installed it on the bike it ran good even though the
    mixture was pretty rich. The bike sat in outside storage for a couple
    of years and gained some oxidation. I took the bike apart, including
    the carbs, to clean up the corrosion. Now I can't even get it to idle
    right. When I took the carbs apart to clean them up I replaced the
    slow jets so that it would run leaner. I don't know what I did, but I
    have replaced the jets and tried all combinations of slow jets and
    needle jets. The best I get is idling at 1200 with the air screw
    completely closed which of course makes the mixture very rich.
    Because it is idling rich I put smaller slow jets to lean out the
    mixture. The smaller the jets the higher the idle, especially if the
    airscrew is open. I have to have the airscrew completely closed to
    even get close to a normal idle. turning the airscrew even a half a
    turn counterclockwise (leaner) makes the idle run away up to 4000 to
    5000 rpm. But if I put larger jets which richens the mixture, the
    idle slows down, but I still have to keep the airscrew closed or the
    idle runs up to 4000 rpm. Does anyone have any ideas? What am I
    missing?
    Please help!
    tjbabar
  2. tjbabar
    . Guest
    You're full of shit, Jack. Item #44 on the Keihin CR Special parts
    list is Keihin P/N
    1014-004-20 "air screw".
    ., Jun 1, 2008
  3. tjbabar
    . Guest
    Yes, the air screw on a slide valve carburetor does regulate AIR FLOW.
    That's why turning the air screw CLOCKWISE makes the mixture richer.
    OP says that the idle stop screw isn't even touching the throttle
    quadrant...
    ., Jun 1, 2008
  4. tjbabar
    . Guest
    Sticky float valves may be the problem. As the fuel evaporated out of
    the bowls during the two years the bike was stored, the float valves
    dropped down, then they became glued in place by the gum in the
    evaporated gas.
    When the motorcycle was returned to serivce, the float valves couldn't
    move to shut off the flow of gasoline, so the fuel level in the bowls
    was too high.
    It takes less vacuum to lift fuel out of the float bowls when the
    level is too high, so the engine runs rich.
    ., Jun 1, 2008
  5. tjbabar
    tjbabar Guest
    Thanks for all the great advice. I did take the carb apart and clean
    all the passages. I did set the jets to the original. And I realize
    that the jets didn't just magically change sizes while it sat in
    storage. The only thing I haven't done is check the float level.
    Thank you for that suggestion. That is the only useful one I have
    read so far. The throttle linkage is not stuck or compromised in any
    way. The choke is clean and working properly. The reason I suspect
    the mixture is rich is because the spark plugs are dark black with
    carbon build up. I have read elsewhere that float level can cause the
    idle to run away. Hopefully that is it.
    Thanks again all.
    tjbabar, Jun 2, 2008
  6. tjbabar
    . Guest
    Are the carbs 29mm, 31mm, or 33mm?
    If you bought the carbs used, you might try contacting Sudco
    International
    to find out what jet needle and needle jets (nozzles) the carbs were
    originally fitted with.
    The difference in diameter between the needle and the nozzle when the
    slides are completely closed is supposed to be just a few thousandths
    of an inch so the needle shuts off flow through the nozzle at idle.
    But, if you have smaller diameter needle (or larger diameter nozzles)
    the carbs will always drool gasoline through the nozzle.
    Drag racers wouldn't mind this, in fact, having a rich mixture just
    off idle is good for low ET's at the drag strip.
    But a street rider or canyon rider would be better off with a leaner
    mixture at idle so the motorcycle will slow down when the throttle is
    fully closed.
    ., Jun 2, 2008
  7. Not sure about your carbs, but the ones I've worked
    on, if you don't get the butterfly back together exactly
    right, you get ari passing by it and a resulting fast
    idle. Did you have the butterflys apart ? If so, the plate
    may not be sealing as well as it should. Orientation
    of the plate may make a difference here too.
    Rob Kleinschmidt, Jun 3, 2008
