Carbon Caked on PIston Crown
Discussion in 'Motorcycle Technical Discussion' started by Manjo, Aug 10, 2006.
  1. Manjo
    Manjo Guest
    I have a metric Vulcan V-Twin. Kawasaki replaced the pistons and wrist
    pins at about 20k miles. At around 40k miles, I had the heads off and
    found a cake of carbon covering the crown of both pistons. I scraped
    it off. The bike ran very well for a while after the clean up.
    At 100k miles, leak down tests showed a 15% loss of compression. I
    pulled the engine and again, found a cake of carbon on both piston
    crowns. I lapped-in the valves (with helpful directions from this
    group), replaced all the valve oil seals, had the cylinders honed,
    installed new rings, and removed all the carbon from the crowns. When
    the job was done, I rode the bike 11,000 miles and burnt a quart of oil
    every 2,000 miles. I did a leak down test that showed around a 2%-3%
    compression loss, well within the acceptable range.
    I'm of the opinion that although the static leak down test is very
    good, the oil is obviously being burnt during high-speed engine
    operation.
    I have been surfing the net for possible causes and trying to skull out
    the problem. Here are the some of the suspects:
    1. The 50 horse power engine may be straining at highway speeds
    against the windshield wind resistance plus 250 of rider and packs on
    long trips, throwing off engine timing causing oil to be pulled around
    the rings.
    2. The crankcase breather tube used to run into the air intake stream
    to the carbs, where the crankcase gases would be burnt away. Now the
    tube runs to a filter element mounted on the bike frame. I'm wondering
    if excessive crankcase pressure is "pushing" oil into the combustion
    chamber as the piston moves downward?
    3. There's just too much piston "rock" allowing oil to creep around
    the rings at high speeds.
    Are any of these a possible cause of the carbon build-up? Are there
    other possibilities? Has anyone had this problem with a 4-stroke
    engine, and if so, how did you solve/manage the problem?
    TIA for any fixes, tips, suggestions, or comments.
    Manjo 1995 1500 Vulcan V-Twin
    Manjo, Aug 10, 2006
  2. Manjo
    FB Guest
    Try making a road draft tube instead of running the crankcase breather
    to one of those little filters. A road draft tube goes vertically down
    behind the engine and the end is cut at a 45 degree angle with the long
    side of the tube forward. This creates turbulence which sucks vapors
    out of the crankcase.
    That sounds good. Piston rock is one of the reasons why Ducati Corse
    engines are only good for 30 hours of operation.
    You might try leaning up the idle mixture a bit. Then the engine will
    burn oil vapors as fuel instead of allowing them to cake on the piston
    tops.
    FB, Aug 11, 2006
  3. Manjo
    Manjo Guest
    FB,
    Thanks for the tips and ideas. The draft tube and leaning the idle mix
    will be done shortly.
    On piston rock: is there a Ducati fix for the piston rock? If not,
    should I look at a rebore and new pistons/rings, or perhaps
    new/different pistons?
    TIA for your reply.
    Manjo
    Manjo, Aug 11, 2006
  4. Manjo
    FB Guest
    Maybe the rider should should be a collector and enjoy "looking" at his
    Bostrom signature Ducati Corsa race replica instead of actually riding
    it and making the V-twin engine turn 12,750 RPM in an attempt to equal
    the 180 horspower of a Japanese I-4 design.
    Maybe slipper pistons with thinner piston rings?
    The ever increasing horspower requirements have caused engineers to
    develop slipper
    pistons with very little skirting to reduce friction.
    Thinner piston rings weigh less, so the acceleration and deceleration
    forces at the top and bottom of the stroke is reduced. I calculated
    that the Yamaha YZF-R6
    subjected its piston rings to 4000+ g's at 15000 RPM. And that machine
    has a stroke ofless than 1.5 inches.
    Bigger displacement short stroke machines are naturally going to rock
    their pistons more, even though they don't turn as fast as an R6 or a
    Ducati 999...
    FB, Aug 11, 2006
  5. You didn't run it in on synthetic oil, did you? You need to use
    dead dinos (changed frequently if it's a totally new engine) when running
    in bores/pistons or they'll never wear enough to seal properly.
    Dr Ivan D. Reid, Aug 11, 2006
  6. Manjo
    Manjo Guest
    SNIP<<
    No synthetic oil used in this engine. I've used Castrol 20W50 for a
    while.
    For this last rebuild there was just a rehoning of the cylinders (no
    rebore) and new rings. I ran the bike for about 500 miles starting at
    an average of 40 mph and then increasing the speed each 100 miles to
    60-65 mph over the last 100 miles. I then went on a long road trip
    where the average daily mileage was 300 miles with most miles at higway
    speeds (65+ mph).
    The top end rebuild before this last one, I ran the bike hard and soft
    (40 to 60 mph) for the first 500 miles. I still got carbon caked on to
    the piston crowns. So I figured I'd break in the rings "soft" to
    "hard" this time. Obviously, no reduction in carbon build-up.
    Manjo
    Manjo, Aug 12, 2006
  7. Manjo
    Manjo Guest
    FB,
    I have the crankcase breather hose running directly downward tied to
    the frame. Before this, I ran the bike to test the pressure at the
    tube alone and at the crankcase filter. At the tube, the pressure was
    obvious, but seemed to lessen as rpms increased to 3000. With the
    breather tube attached to the filter, I could hardly feel any pressure.
    I took the bike on the road and ran it at 25 to 80 miles per hour over
    50 miles. The engine ran smoother and seemed to have more power. I'm
    taking the bike on a longer ride today. I'll then check the piston
    crowns for carbon build-up. I'm hoping the filter has been restricting
    the flow of air OUT of the crankcase allowing pressure to build too
    high and therefore forcing oil up and around the piston rings on each
    down stoke.
    I've also leaned out the idle mix by half (2 turns out versus 4).
    Thanks,
    Manjo
    Manjo, Aug 14, 2006
  8. Manjo
    Manjo Guest
    piotor,
    Thanks for the heads up. I don't think there'll be a problem. The
    crankcase breather port is located at the front of the engine. I took
    the hose and just ran it as far down the LH frame tube as I could
    pretty much parallel to the breather port. It's positioned to the LH
    side of the rear tire, but a good 25-30 inches form the rear tire. If
    there is any vapor accumulation, it should be on the crankcase. I'll
    keep an eye out to see how much is there.
    Manjo
    Manjo, Aug 14, 2006
  9. Manjo
    FB Guest
    Some older Kawasakis used to run the breather tube so it would drip on
    the drive chain.
    FB, Aug 14, 2006
  10. So did my old Yamaha XS650B!
    Chains lasted for ages. Such a simple and neat idea.
    The Older Gentleman, Aug 14, 2006
  11. Making a virtue of a ...hmm... "idiosyncracy".
    Dr Ivan D. Reid, Aug 14, 2006
  12. Heh. Well, yes, and why not.
    "Oil mist comes out of the breather? Hey, let's make a chain oiler!"
    The Older Gentleman, Aug 15, 2006
