Carbon buildups
Discussion in 'Motorbike Technical Discussion' started by SB, Jan 18, 2004.
  1. SB
    SB Guest
    I'm trying to clean up the carbon buildup on my 4-stroke twin from all the
    bits
    around the pistons (valves, barrel tops, head) and am wondering if anyone
    has effective ways for getting it off. I've tried using a little piece of
    aluminium but there is some hard to reach and really hard deposits that I'm
    wondering how to deal with.
    Thanks in advance,
    Shane.
    SB, Jan 18, 2004
  2. Leave it. In fact, add to it. It improves performance. ;-))
    The Older Gentleman, Jan 18, 2004
  3. SB
    Page Guest
    Try oven cleaner.
    Page, Jan 18, 2004
  4. SB
    Bantam Guest
    Yep, I always use a wire brush on the end of a drill.
    It sounds a bit rough but I have also fixed the valves into the drill
    (drill in vice like a turning machine) and, using a piece of gash mild
    steel, turned the carbon deposits off the back of the valves. Finish
    off with some abrasive cloth. (I watch the seats though and try to avoid
    marking the part of the stem that goes into the guide/stem-seal area).
    Bantam, Jan 19, 2004
  5. SB
    Don Fearn Guest
    Not sure *what* was going on, (Burnout)
    leapt in with:
    Voldemort reads r.m.t??
    Ahhh, anyway, I've used Easy-Off oven cleaner to good effect for
    carbon removal. The can warns against it for aluminum, but using it
    for just long enough to remove the carbon didn't harm the aluminum at
    all . . . .
    -Don
    "We have enough youth; let's start looking for the Fountain of Sense." --Anon
    Don Fearn, Jan 19, 2004
  6. SB
    Don Fearn Guest
    Not sure *what* was going on, (Kaybearjr) leapt
    in with:
    Hmmmmm . . . never saw the aluminum turn black when I used it. But, I
    used the "low-odor" variety of Easy-Off; maybe that has a different
    active ingredient than sodium hydroxide? (I can't find the can now
    that I brought it inside to clean the fireplace doors....)
    -Don
    Don Fearn, Jan 20, 2004
  7. SB
    rhino Guest
    Why not use Honda carburetor and combustion chamber cleaner available in an
    aerosol can, or Mercury's "Powertune", same thing.
    OMC had a similar product before they were bought out and may still have.
    Briggs & Stratton also same product.
    Instructions are on the can but all you do is spray it on and let it soak,
    it softens and dissolves the carbon, then wipe it off with a rag.
    It also works for dissolving the gum and varnish found in neglected carbs,
    it's the only product I use for carbs or carbon and I do a lot of carbs.
    rhino, Jan 20, 2004
