carbi rebuild gasket replacement
Discussion in 'Motorbike Technical Discussion' started by Ben Halicki, Dec 12, 2004.
  1. Ben Halicki
    Ben Halicki Guest
    Hi all,
    I'm in the process of rebuilding my XR's carbi and was wondering if I
    should use any sort of gasket sealant when installing the gaskets and
    o-ring seals? Someone once suggested using a smear of grease (rubber
    grease?).
    Should I use a sealant or just install them dry?
    Thanks in advance for any advice.
    Regards,
    Ben.
  2. They're gaskets and seals. They seal. Fit them dry.
    The only time I ever smear anything on gaskets is if I want to hold them
    in position while I marry up the jointing surfaces: some gaskets or
    seals have an annoying tendency to go *fwippp!* and peel off at the
    wrong moment - the big o-ring that seals the Ducati's filler cap
    assembly[1] is one such.
    [1] Needs to be removed to change the fuel filter inside the tank, if
    you're wondering.
    The Older Gentleman, Dec 12, 2004
  3. Ben Halicki
    Ed Rubin Guest
    (krusty kritter) wrote in
    You do need to lubricate o-rings in a sliding or rotating situation.
    Brake calipers and pneumatic nailguns (OTish but a great example) use
    grease on the o-rings that seal pistons and valves and I would think some
    suspension or powervalve applications might need lubricated o-rings. Of
    course you are dead on target for static applications.
    Ed Rubin, Dec 13, 2004
  4. Ben Halicki
    Blank Guest
    All valid replies. Dry gaskets are supposed to be installed dry, and o -
    rings and seals are designed to be installed as - is. However, I have
    found that some orings and seals don't go in very "nicely". The one
    product that I have found to be safe to properly lubricate these things
    is Dow Corning's DC 4. It's alot like petroleum jelly, but safe on buna
    n rubber. HTH
    Blank, Dec 13, 2004
