Carb swaps
Discussion in 'Motorbike Technical Discussion' started by rhavindog, Jul 8, 2006.
  1. rhavindog
    rhavindog Guest
    Im doing a project that involves a mazda rotary engine in a '64
    alpine...and I would like to swap on a carb set from a large bike
    (1000cc or better 4 throat carb) its a 1.1liter engine (1100cc) being
    new to rotary...and absolutely inexperienced with bikes I have no idea
    if it can be done...what problems ill encounter etc. I will be hand
    making the intake...the goal is to achieve the look of a late 60's
    vintage racer (as much as possible with a wankle engine) without the
    budget for multi side draft dellortos or multi throat mechanical fuel
    injection I have been looking at gsx 1000 or better carbs....any help?
  2. rhavindog
    FB Guest
    36 mm or 38mm multiple carburetors from a *stock* 1000cc motorcycle
    might be too small, because the actual displacement of a 1300cc Mazda
    engine is 2800cc.
    OTOH, the Mazda engine is turning *very* slowly, when the tachometer is
    reading
    10,000 RPM, the rotor is only turning 3333 RPM. Gawd only knows how
    many cubic feet of air per minute flow through a set of Mikuni
    motorcycle carbs and a carb that was meant for a Mazda.
    Air velocity through the intake ports is very critical, and, when the
    airflow is moving slowly, the carburetors don't mix the fuel and air
    very well.
    Mikuni and Keihin do make larger aftermarket performance carbs though.
    Check the
    Sudco International website for the 40 millimeter radial flat slide
    carbs that have accelerator pumps.
    I don't have time to calculate the airflow, and you're probably not
    going to go through with this wild assed scheme anyway.
    Notwithstanding the above remark, you would probably be better off
    googling for a Wankel enthusiasts' website to see what other
    enthusiasts might say.
    The earlier peripheral port Mazda engines were capable of putting out
    290 horsepower, with seriously crappy fuel mileage.
    FB, Jul 8, 2006
  3. rhavindog
    SAMMM Guest
    i'm not a hero on the rotary but, as i recall, the 1.1 liter rotary has a
    substantially larger fuel/air flow
    than a similar sized recip engine.
    there are people who sell kits for this purpose.
    you might inquire as a possible buyer and gain the information you need.
    i think your idea is an ok one but get as much info from the
    experts/commercial vendors
    about this.
    magazine "Grassroots Motorsports" advertising stuff has mazda experts
    advertising in it.
    good luck, sammmm
    SAMMM, Jul 8, 2006
  4. rhavindog
    ken Booth Guest
    ken Booth, Jul 11, 2006
