I've got a spot on the end of my nose. Do you think it could be carb icing?
Using the patented Mavis Beacon "Hunt&Peck" Technique, Ben Blaney I don't do diets. That's probably why I'm fat.
Using the patented Mavis Beacon "Hunt&Peck" Technique, typed Good plan. <toddles off to 'Austrian' section of wine cellar>
Using the patented Mavis Beacon "Hunt&Peck" Technique, jsp No, if anything slightly hot and dry. Red, it is. I still think it might be carb icing though.
Connect a bit of wire to each terminal of your battery, and then attach one wire to each nostril. Instant carb heat. That should sort the problem, one way or the other.
No. It's far more likely to be a wiring problum. Have you chekced youre sidestand switch? [speeeling gone awtray, blamie the opub across the roaddd] hicfuckit!
Nah, sounds like a carb-unkle to me. Boom - Tish. -- Oldbloke 2000 Honda CB500 BOTAFOT #140 "He's like Robbo's chubby kid brother"
