Carb diaphragms
Discussion in 'UK Motorcycles' started by Mungo \Two Sheds\ Toadfoot, Feb 28, 2007.
  1. I'm guessing that they're not supposed to be very baggy when in position?
    What, if any, running problems would this give?
    The Viagra revs fine on a partially open throttle but isn't keen on full
    throttle when it will bog down so I'm trying to find likely causes.
  2. Mungo \Two Sheds\ Toadfoot
    JB Guest
    Hold them up to the light. If you can see splits, holes (even pinprick
    holes), replace them.
    When the slides are closed, the diaphragms will appear creased or 'baggy'.
    This is normal.
    JB
    JB, Feb 28, 2007
  3. They were 'fraying' in a couple of places around the edge but I've sorted
    that. I did look for obvious splits but not tiny ones so I'll whip them out
    again and have a closer look.
    That's good then. Thanks.
  4. Mungo \Two Sheds\ Toadfoot
    Adie Guest
    these are the people to go to when you want new ones
    http://www.nrp-carbs.co.uk/index.htm
    Adie
    YZF-R1 : ZX9R-E1
    keeper of the FAQ for my sins
    Adie, Feb 28, 2007
  5. £32 each? Bargain! I'm sure I saw some on eBay for around £90 each fairly
    recently. Appreciated, thanks.
  6. Mungo \Two Sheds\ Toadfoot
    Adie Guest
    lovely bloke too. just don't get into a vodka drinking competition
    with him.
    cos you'll lose big stylee.
    Adie
    YZF-R1 : ZX9R-E1
    Adie, Feb 28, 2007
  7. No2 son had this problem recently. Investigation revealed that one
    diaphragm was no longer held properly at the end of the piston by the
    inner sleeve and washers - so much so that the whole lot fell out in
    bits when the cover was taken off.
    A single drop of superglue became his friend :)
    Do take care you get the piston the right way up - comparison with
    the other is advised!
    Chris D
    Chris N Deuchar, Mar 1, 2007
  8. Noted, thanks.
    Mungo \Two Sheds\ Toadfoot, Mar 1, 2007
