Car vs. bike conrnering speeds
Discussion in 'UK Motorcycles' started by Ace, Apr 16, 2004.
  1. Ace
    Over the years I've often heard, or been party to, discussions about
    relative maximum cornering speeds ofbikes and cars. Back when I
    started riding, there was no question about it, cars would always be
    able to corner quicker than bikes.
    Now I happened to be thinking about this as I rode in this morning,
    and actually looked at my speedo. There's one bend, for example, that
    I'd normally be happy going round at 70-80mph in the Peugeot (which is
    a 2-litre GTI with 205/45 tyres, stiff suspension and hence immense
    roadholding) but which would demand more concentration etc. to be much
    quicker. This morning I was just tootling along, as you do, but I
    noticed that I was going round it at 100. Bugger me, this 'ere gixxer
    corners fast, dunnit?
    Thing is, I'm sure either of the cars would get round at that speed,
    but you'd feel like you were on a race track, whereas the gixxer just
    cruised around without even feeling fast. I could prolly have added
    another 20mph before it started to get, er, interesting, IYSWIM.
    So, are bikes now better at cornering than cars? Or is it just that
    I'd need to compare it with a Ferrari or somesuch to make a valid
    comparison?
    Ace, Apr 16, 2004
  2. Ace
    Molly Guest
    I also had thought this. But counter steering is you friend and lean
    is mean.
    I can certainly corner far quicker on a bike than I can in a car:
    The cars I'm comparing with are:
    BMW 328Coupe'
    Formula F27
    Caterham Seven (on a track)
    Porsche 944 Turbo
    All lot depends on the car but my theory is that the inertial force
    acting on the rear of production cars will bring the back end around
    whereas on a bike the forces are making the wheels dig in. Of course a
    lot of it has to do with the driver as well.
    I could be completely and utterly wrong but it's my guess. Whichever
    way you look at it I can corner much quicker on the bike.
    Molly, Apr 16, 2004
  3. Molly wrote:
    Out of interest, would you say the same was true in the wet? and I mean
    wet, not slightly damp.
    Doesnotcompute, Apr 16, 2004
  4. Ace
    Catman Guest
    Given that Schumacher still laps rather faster than the WSB guys (at
    least that's what I read last night), I suspect that you're right.
    The GSX-R is really a superbike in the way of super cars innit?
    www.cuore-sportivo.co.uk
    Catman, Apr 16, 2004
  5. Which then leads to the questions of power>weight ratios, acceleration
    down the straights etc.
    Lap times of different vehicles don't really help answer the question.
    Fastest time from start of corner to exit of corner is all that is
    appropriate.
  6. Ace
    The last comparison I saw of this type was on one of Clarkson's
    shows. Niall MacKenzie on an R1 vs. some Touring Car driver in
    a Porsche Turbo. While the R1 always pulled away out of a corner
    due to the better acceleration, the Porsche always made up going
    into and around the bends due the superior grip the four fat
    tyres gave it. The Porshe finally 'won' the race.
    I suspect it really depends on the driver/rider and what bike
    and car are being compared.
    CT, Apr 16, 2004
  7. Catman said:
    A hell of a lot faster - the track at Silverstone used for F1 is a lot
    longer than the (national?) track used for bikes there.
    Simon Atkinson, Apr 16, 2004
  8. Ace
    Molly Guest
    Yes [1]. As a matter of fact I was going to say "also in the wet".
    [1] Tyre profile permitting.
    Molly, Apr 16, 2004
  9. Yes, but you are a riding Goddess.
    There's a thought - if you bought green leathers, you'd
    be a Green Goddess, and could put out fires in your
    spare time.
    Steve Brassett, Apr 16, 2004
  10. Interesting. There's no war I'd be quicker at cornering on two wheels in
    the wet. I simply don't have the confidence at such a small contact
    patch versus that of a cage.
  11. Ace
    Steve Parry Guest
    In
    One of the "benefits" of ABS is being able to "play" with the brakes to
    find the point that the tyres break away under braking in the wet.
    First time I tried I was suprised just how much harder you can be on the
    brakes than you think before the ABS kicks in.
    Steve Parry
    http://www.gwynfryn.co.uk
    K100RS SE
    F650
    (not forgetting the SK90PY)
    Steve Parry, Apr 16, 2004
  12. Ace
    Catman Guest
    Hmm, not sure about that. Surely the power to weight ratio would
    still have an effect, unless you slung them in in neutral and coasted
    around.
  13. Ace
    Slider Guest
    CT wrote:
    [snip]
    And, sadly, who is doing/commissioning the comparison. Bias is a wonderful
    thing.
    Slider, Apr 16, 2004
  14. Ace
    Molly Guest
    No but JP wouldn't be so embarrassed. Hell, he may even fancy me.
    Molly, Apr 16, 2004
  15. Ace
    Howard Guest
    Jeez, this chat makes me chuckle. I am so far from doing anything like
    that! Should I be in the insurance business instead of making jewellery?
    Howard, Apr 16, 2004
  16. Ace
    All you need is the right bike. I believe it should be obvious which
    one that is.
    Ace, Apr 16, 2004
  17. if you're talking race bikes and dry track, then I'm not surprised.
    However, in the wet, you'll probably run into a lack of grip sooner than an
    equivalently-specced car, I'd have thought.
    on roads, it's a different story.
    Austin Shackles, Apr 16, 2004
  18. Ace
    Ye-es, I guess this is a factor, but the corner I was referring to I'd
    often take a similar line when cage-bound as I did this morning on the
    bike, given that there was oncoming traffic restricting the other
    lane.
    Not sure why this should be the case. If there's more mechanical grip
    you'd expect it to show at any speed.
    Y'know, I reckon it's more to do with the feeling - in a cage you'll
    always feel the cornering forces throwing you to one side, whereas on
    a bike you're in line with them, so it just doesn't feel so quick. Of
    course, some bikes are better than others - the trumpet used to get a
    bit wallowy on fast corners due to inferior suspension - although it
    could be pushed it would never be as quick as the gixxer as the tyre
    load would not be so constant.
    Ace, Apr 16, 2004
  19. Ace
    Why? Assuming nothing wierd about the tyres there should be
    proprtionally the same difference in available grip for the car
    compared with the bike.
    This is true, but IME I can be 20mph quicker on the gixxer and still
    feel less likely to lose it if grip started to go.
    Ace, Apr 16, 2004
  20. I think that sounds a reasonable comparison, provided the vehicles were
    prepped to equivalent standards. Obviously, a race-prepped F1 bike is going
    to be faster than a caterham 7 set up for the road and the occasional track
    day, in the same way I'd expect a race-prepped porsche touring car to beat a
    bog-standard R1 on road tyres.
    but the comparison above sounds fair on the face of it. And about the
    result I'd have expected. However, if you set up a mixed race with a dozen
    cars and a dozen bikes, the bikes would win on better ability to overtake.
    This applies even to my SOBoxer, on the road - most of the cars on the road
    these days will go as fast and corner as fast, suitably driven, but when you
    get to traffic, it's much easier for the bike to overtake. modern sports
    bikes are even better at this, the ability to go from 30-90 faster than you
    can say it, almost, allied to the small physical size, makes it possible to
    overtake safely in places where even a fast car hasn't a hope.
