Cans.
Discussion in 'UK Motorcycles' started by steve auvache, Jun 2, 2005.
  1. First let me start with an apology to Loz. Loz ole mate you are not the
    **** I have been quietly calling you for all these weeks while you have
    been steadfast in your defence of Avon Azaros to this seasons crop of
    eager enquirers. Turns out they actually aren't a bad tyre if you don't
    run them 20lbs under pressure. Incredible grip at the front there is
    today.
    Any road. I miss the low down torque that you get with anything other
    than a modern screaming in-line 4 and am thinking of either buying more
    cubes which I really cannot afford or taking the Scorpion off and
    replacing it with something designed specifically to move the power band
    down the rev range.
    Other than a genuine Suzuki can is there anything on the market which is
    aimed towards how the bike was intended to be tuned rather than spoiling
    it with loads of torqueless revs?
  2. steve auvache
    Heh... Doh.
    Buying more cc would be the best solution if you want more power.
    My race can seemed to poduce more mid range on the Bandit than the
    standard can did. Get yourself an old air / oil cooled gixer 750 lump
    for a few hundred if you want more speed. or the cheaper option of
    bores / pistons off one if you want a little more power everywhere.
    Muck, Jun 2, 2005
  3. Muck wrote
    More speed is not what I want. I all ready have more speed than I have
    road space to use it on.
  4. steve auvache
    JackH Guest
    That'll be what the Fazer currently has...
    They seem pretty good to me anyway, and they're not even wearing away that
    quick, which given how I tend to ride, I'd have expected otherwise.
    JackH
    Fazer 600 - Micra 1.3 (K11)
    BOTAFOT #110 D.Bot (University Of Speed) - BOTAFOF #29 - GHPOTHUF #29
    JackH, Jun 2, 2005
  5. steve auvache
    steve auvache says...
    I started laughing, then remembered I have been guilty of this in the
    past. Forgiven.
    Lozzo, Jun 2, 2005
  6. JackH wrote
    You are joking right, they are made of Jelly tots in the middle, mine
    looks like a thrupenny bit it does. Straight across it is at the top
    and the bottom, like some **** has taken a slice off all round the
    wheel.
    Maybe that is what has happened and it isn't me being a wuss, some
    scrote has nicked it. Right, that is the last time I go shopping in
    Tilbury, the thieving cunts will have the fucking rubber off yer wheels
    they will.
  7. Lozzo wrote
    Easy done innit. I knew they were down a pound or two but as I don't
    carry the weight I don't particularly mind having them a bit on the low
    side but that was silly.
  8. steve auvache
    Smaller front / bigger rear sprocket then?
    Muck, Jun 2, 2005
  9. Muck wrote
    I hadn't thought of that.
    A road to pursue, ta.
  10. steve auvache
    JackH Guest
    They've done 5k in total since they were put on, and have hardly any wear.
    Admittedly, only about 1k of that is my handiwork, but that 1k has been one
    consisting mainly of the tits being thrapped off the bike.
    Learn to corner then.
    *boggle*
    What on earth were you shopping for, there... narcotics?
    JackH
    JackH, Jun 2, 2005
  11. JackH wrote
    In fairness to me they are a bit better than they were, I did inherit
    the tyres with the bike and it was ridden by a burd before I got it.
    Actually I went to Canvey but having spent time and effort over the
    years firmly establishing in your minds that Tilbury is not a very nice
    place I lied for the sake of the metaphor. See it wouldn't have worked
    half as well if I had said Canvey would it? Canvey is Essex Girl
    Central, where blow jobs are a normal part of the formal introduction
    process. What place has a blow job in a tale of motorcycling daring do?
  12. Rope wrote
    It does, it does but I can't afford it.
  13. steve auvache
    tallbloke Guest
    guzzi 850?
    tallbloke, Jun 2, 2005
  14. tallbloke wrote
    It is Champ who is the one without a sense of taste, if you please.
  15. steve auvache
    JackH Guest
    Like I need any of that - I remind Sir I have to visit Tilbury every so
    often, what with the maternal side of the equation that is 'me', having come
    from there.
    I dunno so much... it's a place full of dodgy scrotes into salvage motors
    from what I've seen of it - and the prices they tend to ask, 'thieving
    cunts' *more* than covers it.
    More to the point, Tilbury has no place in any tale of derring do... unless
    it's to do with the struggle that ultimately culminates with the hero /
    heroine finally leaving the shithole for good.
    JackH
    JackH, Jun 2, 2005
  16. Andy Bonwick wrote
    That took me by surprise, I wasn't expecting you I was expecting Adie
    and I haven't got me keep net ready. Bugger.
  17. steve auvache wrote:
    oi! I had that for a couple of weeks before you and teh tyres were fine
    at that point. I've also had/got the Avons on the big bindit, and
    they're far better a tyre than I am a rider.
    so, goes back to, learn to corner you old fart.
    Doesnotcompute, Jun 3, 2005
  18. Doesnotcompute wrote
    Itywf that is two points as it goes, one either side of the centre line.
    I have been practising today, a revelation putting air in the tyres it
    was and temptation beyond resisting.
    steve auvache, Jun 3, 2005
  19. steve auvache
    tallbloke Guest
    hardly...
    tallbloke, Jun 3, 2005
  20. steve auvache
    *snort*
    I can just see Champ in a tasselled jacket, shades and pisspot.
    Pip, Jun 3, 2005
