Cannot start bike
Discussion in 'UK Motorcycles' started by Clive, Jan 12, 2010.
  1. Clive
    . Guest
    ., Jan 22, 2010
  2. No tantrum. Just good advice.
    The Older Gentleman, Jan 22, 2010
  3. Is the OP in SC? I rather doubt it.
    How does the dirt get past the dirt and dust seal?
    Possibly, yes, if the shoes are really, really, badly worn and some dork
    has re-positioned the operating arm on the splines to take up the last
    bit of adjustment. I've seen this.
    No, one mustn't. It just isn't necessary. If it's moving freely, it
    doesn't need lubing.
    Do you *ever* work on motorcycles yourself? If so, I dion't see how they
    function afterwards.
    No, there aren't.
  4. This is KrustyUS. He's *always* wrong.
  5. Clive
    I'm finding it hard to take someone who uses the user name .
    seriously. Care to give me a reason why I should do?
    Andy Bonwick, Jan 22, 2010
  6. Clive
    Anyone who constantly changes their posting name to try and make
    themselves visible *has* to be a ****. He's not alone in using this
    technique to avoid killfiles but it's been proven time and time again
    that everyone who does it is worthless and should take a long hard
    look at why they have to do it. Other obvious ones are Anthony Brandy
    and Des so it's case proven as far as I'm concerned.
  7. Clive
    boots Guest
    Mega Ding.
    boots, Jan 22, 2010
  8. Clive
    ian field Guest
    Seems to be mostly the carbs with a plunger operated choke jet that don't
    like choke and throttle at the same time.
    The one's with a choke flap or butterfly seem less fussy.
    ian field, Jan 22, 2010
  9. Clive
    Pete Fisher Guest
    Indeed. Though until you have tried to coax a tuned big single in to
    life on a cold day, with a sub-optimal battery, you don't really know
    the true meaning of fussy. With FOAD Keihin twin smooth bores fitted you
    get adept at leaving the starter jet plunger off, and catching it on the
    throttle if it ever decides to fire. A softer plug can work wonders
    though.
    In any case I see the OP has effectively performed the ritual usually
    required to start a Nordwest that has been standing for a while. Perhaps
    the technique works on smaller fry.
    | Pete Fisher at Home: |
    Pete Fisher, Jan 22, 2010
  10. Clive
    ian field Guest
    Its really dodgy when the brake cam tops out between the brake shoes - it
    wedges between the shoes and locks the wheel solid.
    In times of great desperation I've been known to cut a couple of squares out
    of sheet steel and weld them to the heels of the brake shoes.
  11. Clive
    ian field Guest
    ISTR Hush Puppy brushes being brass - which transfers onto the insulator
    nose *MUCH* worse than a steel wire brush.
    I've successfully cleaned badly fouled plugs with caustic soda in an
    ultrasonic cleaner (about £30 - £40 in Maplin).
    Wait for the oil slick to float to the top, then wait a little longer for
    the oil to break down into a nasty looking dark grey emulsion - then the
    plug should be ready to rinse and dry.
  12. Clive
    . Guest
    WTF does *that* have to do with anything?
    Hey! You're not as stupid as you look, yannow?
    They run veddy, veddy well, thenkyou.
    ., Jan 23, 2010
  13. Clive
    . Guest
    You'll get used to me. TOG is my sponsor here. He's been inviting me
    to join ukrm for years and has wrecked two other newsgroups to get all
    the Canuckistanis and Septics over here, so get used to us.
    ., Jan 23, 2010
  14. Clive
    . Guest
    This *is* Cuntsville, UK, isn't it?
    ., Jan 23, 2010
  15. Clive
    . Guest
    Say! Could you tell a few more stories about pikey bodges you've done
    so TOG will follow *you* are Usenet, instead of me?
    ., Jan 23, 2010
  16. Clive
    petrolcan Guest
    Just don't try further than 53 feet.
    petrolcan, Jan 23, 2010
  17. Clive
    Sean_Q_ Guest
    That's curious considering he's the subject of a famous song:
    All I want is a proper cup of coffee
    Made in a proper copper coffee pot
    I may be off my dot <------------------(note reference)
    But I want a cup of coffee from a proper coffee pot
    SQ
    Sean_Q_, Jan 23, 2010
  18. Clive
    Sean_Q_ Guest
    I thought a Septic was an ancient Greek philosopher.
    SQ
  19. Clive
    crn Guest
    So tell us, O wise one - How the **** did you weld alluminium to steel?
    I call bullshit.
    crn, Jan 23, 2010
  20. Clive
    S'mee Guest
    Oh look a lesser troll! I thought those little things flew to
    antartica for the winter...shame t'ain't open season yet. And my how
    he swings his tiny...<squints> never mind it's built like ken.
    S'mee, Jan 23, 2010
