Cannot start bike
Discussion in 'UK Motorcycles' started by Clive, Jan 12, 2010.
  1. Clive
    Clive Guest
    Hi,
    I have a simple Suzuki (grey import) EN125. I expected it to be tough
    to start the bike after the cold and damp weather. The bike had been
    under a light-weight rain cover for say 6 to 8 weeks. I have a small
    "slope" near the house which is steep enough to get up to, say, 10
    mph. I have tried to bump start the bike on this slope and it almost
    fires then dies or does not fire at all. I have tried bump starting
    with full choke, half choke, no choke. I have tried to jump start off
    my car battery (car not running I have been advised). The bike starter
    motor turns (not burned out yet) but the bike does not attempt to
    fire. Anything else I can try to get this bike moving?
    Regards
    Clive
    Clive, Jan 12, 2010
  2. I used to have a GN125 that did this after beft for a - a thump on the
    carb would
    M R-e-a-d-i-n-g, Jan 12, 2010
  3. I used to have a gn125 that did this after being left for a while - a
    thump on the carb would sort it out though so I am guessing something
    with the carb like a stuck float.
    Pull one of the plug caps and check that the plug is firing with a
    good strong blue spark, if not then start looking at the ignition
    system.
    I would pull the spark plug and see after you have tried starting it
    whether the plug is wet with fuel or not - if it is then heat it good
    and hot with a blowlamp and then try restarting it without choke - if
    the plug is dry then fuel isnt getting to it so check fuel is getting
    to the carb, then check the carb itself.
    Hope this helps
  4. Check the sidestand ignition cutout first of all.
    The Older Gentleman, Jan 12, 2010
  5. Fueltap, plugs, tip switch, sidestand switch, clutch switch are all possibles
    on this one. Sounds more ignition related if it is turning but not firing.
    Fraser
    Fraser Johnston, Jan 13, 2010
  6. Clive
    Eiron Guest
    Does it have a kill switch?
    Eiron, Jan 13, 2010
  7. Clive
    ian field Guest
    Had that with a YPVS Yam 350 years ago, because the 2-stroke twin vibrates
    with a sort rocking motion, the switch "made" when one cylinder fired and
    was sometimes intermittent when the other cylinder fired (or not as the case
    may be).
    A short wire link was hastily crimped with tags to suit the connector and
    plugged in instead of the switch.
    ian field, Jan 13, 2010
  8. Clive
    Clive Guest
    Hi,
    I'm limited in my knowledge and equipment to test things however I
    tried the following today.
    Bump start in second. The bike sort of "rumbled" but didn't get to
    fire
    The battery voltage reads about 11.8V (given possible inaccuracies of
    voltmete).
    I unscrewed the spark plug from the cylinder and the end is black. The
    gap didn't seem "wet".
    I cranked the engine with the spark plug out and could smell petrol so
    I guess fuel is getting from the tank through the carburetor and into
    the cylinder.
    When I was cranking the engine I couldn't see a spark across the plug
    gap when the plug was in the spark lead (?) but out of the cylinder. I
    have read something about when trying this having the spark plugs "in
    contact with metal" but I would have thought the capacitor/inductor
    thing that creates the HT required the gap to create the spark and any
    short-circuit would, well, short-circuit the spark.
    I can't take out the HT/spark lead (?) to test its resistance since
    one end is tucked well under the fuel tank and I don't have the tools
    to remove the tank.
    The local bike repair guy is of course closed today.
    Clive
    Clive, Jan 21, 2010
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, Clive
    That's too low. Charge it. Unless it's a sealed battery make sure the
    fluid level is between the lines in each cell. If not, top it up with
    distilled water. Do *not* use tap water.
    If the end is black, try a new plug. Or clean this one.
    The metal body of the spark plug *must* be in contact with the earth on
    the bike for this to work. Touching it to the cylinder head should be
    enough. Be careful how you hold it in place, it will give you quite an
    unpleasant shock if you touch it. Use the cap to hold it.
    You should see a nice fat blue spark.
    Wicked Uncle Nigel, Jan 21, 2010
  10. That's fucked and may well be the cause of the problem. A decent
    fighting fit 12v battery should show 12.5v plus.
    The Older Gentleman, Jan 21, 2010
  11. Clive
    Clive Guest
    Got it working !!!
    1. Took out spark plug, cleaned surface with some 400 emery paper and
    tested spark by holding body of plug against cylinder head, a yellowy
    spark was seen when I turned over the bike. Not great but probably
    enough. Refitted spark plug and lead.
    2. Closed fuel tap from tank.
    3. Put small container under carburetor drain screw and undid screw.
    Yellow liquid with a few black particles drained out. Whether the
    black was from within the carb or muck around the screw I don't know
    4. Opened the fuel tap for a second to "flush" the carb. Refitted carb
    drain screw
    5. Opened choke fully, no throttle, turned over the engine and it
    fired up after 2 seconds
    Moral ? Probably close the fuel supply tap and drain the carb if the
    bike is to be left over winter.
    Thanks to all for suggestions.
    Now ... the rear drum brake is sticking when I depress the foot pedal.
    I can "knock" the "swing arm" that engages the drum to release the
    brake. I will degrease and relubricate all external rods and linkages.
    Maybe a "release spring" inside the drum has failed or is "gummed up".
    That's a job for the mechanic.
    Clive
    Clive, Jan 22, 2010
  12. Clive
    Well done.
    "Shit in the carbs" is stock ukrm answer #2 (in a series of, err, about
    4!).
    I can't believe no-one posted it.
    CT, Jan 22, 2010
  13. Clive
    . Guest
    In some warmer climates petrol is formulated diffferently for winter
    and summer.
    If your petrol was very old, the volatile alcohols which make it
    easier to start an engine during the winter may have evaporated away,
    leaving gum and varnish deposits in the jets and various ports and
    passages of the carbuettor.
    The petrol in the fuel tank would be fresher than the petrol distilled
    in the float bowl and that would help to clean the carburettor
    slightly.
    But you should make a habit of adding a few ounces of clear
    carburettor cleaner to the petrol tank before trying to start the
    engine after a lay off or winter storage.
    This carburettor cleaner should contain clear solvents like toluene,
    acetone, methyl ethyl ketone, it shouldn't be a carburettor dipping
    solvent. Carburettor cleaners that are mostly naphtha (petroleum
    distillate) are almost useless, you want the cleaner with the strong
    solvents.
    That's the correct starting procedure in cold weather. Full "choke",
    no throttle at all.
    Your carburettor doesn't have a real "choke", there is no flat plate
    to restrict airflow and enhance vacuum to suck petrol out of the float
    bowl.
    There is a small air valve built into the side of the carburettor. It
    is part of the cold starting enrichener system. When you apply the
    "choke", the air valve allows air to bypass the throttle butterfly.
    This airflow sucks petrol directly out of the float bowl through a
    brass tube which can become plugged up with gum and varnish from
    evaporation of the fuel in the float bowl.
    One more thing:
    When you attempt to start a carburettor-equipped motorcycle engine
    after winter storage, turn the idle SPEED knob or screw all the way
    counterclockwise first.
    This closes the throttle butterfly completely, increasing engine
    vacuum and making it easier to suck petrol out of the float bowl.
    Then apply full "choke" and do not twist the throttle grip. When the
    engine fires up, keep it running by twisting the grip slightly.
    When the engine is warmed up, turn the idle SPEED screw clockwise so
    the engine will run at the specified RPM.
    ., Jan 22, 2010
  14. Clive
    . Guest
    There is no so-called "release spring" inside the brake drum. There
    are two brake shoe *retractor* springs, though. They hold the brake
    shoes away from the roatating drum and against the operating cam which
    is rotated by the short lever that you can see moving when you stand
    beside the motorbike and push the brake pedal with your hand.
    One of the retractor springs may be broken, and it's likely that there
    is an accumulation of brake dust inside the drum. This should be
    removed every time you replace brake shoes.
    The brake dust may have accumulated on the operating cam shaft, which
    needs to be cleaned and re-greased every time you replace brake shoes,
    or if you have been riding through standing water frequently.
    If you want to ride a motorcycle on a regular basis without a lot of
    frustration, you really should learn how to do simple maintenance
    tasks, such as changing a tyre, replacing brake shoes, making various
    adjustments to the controls and keeping the fuel system clean.
    ., Jan 22, 2010
  15. <snip utter irrelevancy>
    Clive, ignore this post and concentrate onfreeing the seizing brake like
    I said.
    The Older Gentleman, Jan 22, 2010
  16. That means the steel pivot pin has seized in the alloy drum plate. Very
    common.
    Remove back wheel, remove drum plate, knock out steel pivot pin, clean
    up, lightly grease, reassemble. Easy.
  17. Yes, there are.
    They are therefore release springs.
    Absolute *nonsense*
    <snip more crap>
    Clive, if you're reading this, the seizure is a very common thing, and
    it's generally caused by an interaction between the steel of the pivot
    pin and the alloy of the brake plate. Just do what I said and ignore
    this nonsense.
  18. Clive
    ian field Guest
    Using emery paper on a spark plug is not a great idea, it isn't easy to
    remove every last trace of grit and it doesn't do the rings any good.
    Using a wire brush isn't much better, it can leave traces of metal deposits
    on the insulator nose.
    A new plug is the favourite option - or if you're desperate, burn the soot
    off the plug with a blowlamp.
    ian field, Jan 22, 2010
  19. Clive
    . Guest
    Look out! A full blown Four-eyed Juicy Fruit tantrum has begun!
    ., Jan 22, 2010
  20. Clive
    . Guest
    In southern California, where it doesn't snow and the highway
    maintenance crews don't salt the roads, drum type rear brakes still
    stick like Clive described and it has nothing to do with corrosion.
    Brake dust and road dirt mix with the grease on the brake cam shaft
    and it sticks.
    Also, the brake cam itself will begin sticking when the brake shoes
    are almost worn out.
    When replacing rear brake shoes, one must always lubricate the brake
    cam and the brake cam's shaft.
    There are also problems with brake linkage geometry that lead to rear
    brake shoe binding, especially if there is a solid steel rod in the
    linkage instead of a cable.
    Now, get back to your fruit juice, Four Eyes...
    ., Jan 22, 2010
