Can you help me choose a bike?
Discussion in 'UK Motorcycles' started by Alan, Aug 5, 2004.
  1. Alan
    Alan Guest
    I currently own a Vespa ET4 125cc. Much as I love it for nipping in &
    out of traffic in central London, it's a real struggle on the open
    road because above about 40mph it really starts to run out of puff.
    I've not owned it long, first bike I've had and I have zero no claims
    discount on my insurance at the moment. Insurance costs are a worry
    because of this and because I park my bike on the street in East
    London, a high risk area for theft.
    In about a month's time I'll be sitting my DAS test so if I pass I'll
    be looking at buying a bigger bike to make life a bit easier on longer
    journeys.
    A friend of mine suggested that something like a Honda CB500 would be
    a good choice for me initially - decent performance but not OTT,
    comfy, reliable, economical, easy to ride, etc. Fair enough.
    The thing that makes me hesitate is that before I bought a bike I'd
    had several cars, all with ABS brakes - and I've come to rely on ABS
    to stop me in a straight line without skidding in rain, snow, ice,
    etc. From a safety point of view I'd quite like it back. AFAIK the
    CB500 isn't available with ABS although the new CBF500 does seem to be
    - would that be a good choice?
    Or am I being too precious & should I not worry about ABS?
    Any thoughts on whether or not the CB500/CBF500 would be a good
    choice? Any alternatives I should think about? Are there any
    websites that could help me narrow down my choices?
    As far as my budget is concerned - haven't decided yet, but money
    isn't likely to be a great worry for me.
    Very grateful for any advice,
    Thanks,
    Alan.
    Alan, Aug 5, 2004
  2. Alan
    Stonge Guest
    If you have to rely on ABS on a bike, you'll be dead in a week!
    Stonge, Aug 5, 2004
  3. Alan
    On 5 Aug 2004 04:15:49 -0700, (Alan) wrote:
    <snip>
    Gixxer thou.
    Ace, Aug 5, 2004
  4. Alan
    mups Guest
    says...
    BMW F650 is available with ABS but apart from that and the above
    mentioned CBF600 I can't think of any other small/mid range bikes with
    ABS. Are you sure you really need it?
    mups, Aug 5, 2004
  5. Alan
    Doki Guest
    You can't drive. There's no reason you should ever be relying regularly on
    ABS. You're either braking too late or driving too close to the bloke in
    front. In snow you shouldn't even be using the brakes any amount.
    Doki, Aug 5, 2004
  6. Alan
    mups Guest
    Doki says...
    Bollocks
    mups, Aug 5, 2004
  7. Alan
    Doki Guest
    Do elaborate.
    Doki, Aug 5, 2004
  8. Alan
    Kevin Seal Guest
    How you gonna stop if you don't brake. Eh?
    Kevin Seal, Aug 5, 2004
  9. Alan
    Kevin Seal Guest
    If you have to rely on ABS brakes in a cage, you're a crap driver!
  10. Alan
    mups Guest
    Doki says...
    If you need to stop in deep snow locking the front wheels builds up a
    wedge of snow in front of the wheels which stops the car faster than ABS
    or just engine breaking.
    mups, Aug 5, 2004
  11. Alan
    Ben Blaney Guest
    "Total bollocks"
    Ben Blaney, Aug 5, 2004
  12. Alan
    Ben Blaney Guest
    You're a troll, right?
  13. Alan
    Spot on. Apart from the "breaking" bit, anyway.
    It works the same way with dead leaves and even mud-filled gutters and
    rural road edges.
    Pip, Aug 5, 2004
  14. Alan
    I drive a lot in snow in a 4WD volvo, with traction control linked to
    the ABS system. While I wouldn't say I rely on it, it's certainly
    bloody useful.
    Nowadays I always fit snow tyres in the winter, but the first time I
    was driving solo to the alps (from the UK) I got into a four-wheel
    drift on the road up to Tignes. I was most definitely going to hit a
    road-sign, so I thought '**** it, why not try the brakes?'. A gentle
    application locked and unlocked them, at which point forewrad, rather
    than sideways, momentum was restored.
    Since then I've often deliberately engaged the ABS simply to get
    better traction, or sometimes just for the fun of it :)
    Ace, Aug 5, 2004
  15. Alan
    flash@work Guest
    Icepick (usb port optional)
    flash@work, Aug 5, 2004
  16. Alan
    flash@work Guest
    Does it work with pedestrians?
  17. Alan
    mups Guest
    Pip says...
    Urm, I was using Timo's car as an example, Yer onna...
    mups, Aug 5, 2004
  18. Alan
    Hell, yes.
    That's why so many modern cars are fitted with cow-catcher spoilers
    below the front bumper. They have little to do with downforce or
    directing airflow, they are there to catch and retain pedestrians to
    aid braking. Three or four grannies on the extreme front edge of the
    car provides more downforce than a spoiler, especially at urban speeds
    - as I'm sure you can appreciate.
    Fitting an "eyebrow" spoiler immediately above the headlights is
    recommended, as it greatly reduces the quantity of blood and snot
    smearing the windscreen and can help to retain the tartan shopping
    trolleys below bonnet level too. A nice sharp edge should be
    maintained in order to trim off potentially distracting waving limbs
    which would otherwise oscillate annoyingly in the line of sight.
    Bull bars can work well too, but are less aesthetically pleasing and
    may allow younger downforce weights to gain sufficient purchase to
    climb over the bonnet.
    Pip, Aug 5, 2004
  19. Alan
    flash@work Guest
    <LOLLERSKATES>
    Would you advocate hitting different sorts of grannies for different weather
    conditions?
  20. Alan
    Loz H Guest
    Yep. All good points. Someone around here (Oldbloke, I think it is) has one
    for sale. Buy now, and bask in the glory of a bargain well found.
    Yes. You are being precious. Practice progressive braking. It may be
    blindingly obvious, but if you feel reliant upon ABS to save your skin you
    probably need telling. Grab enough front to throw the weight forward, then
    grab some more. If you feel it lock, ease off and reapply. If you`re going
    to lock the wheels up, it`ll be if you panic-grab at the brakes. Be smooth.
    No doubt someone more expert will be along to tell me I`m full of bollocks,
    but that philisophy works for me.
    Alternatively, buy a 70s Honda. Not much chance of locking the brakes up on
    one of those bastards.
    Loz H, Aug 5, 2004
