Can I just replace the rings?
Discussion in 'Motorbike Technical Discussion' started by mike, Jun 11, 2004.
  1. mike
    mike Guest
    I have a '75 Honda CB125S with 13,000 miles on it.
    Don't know the exact history, but it was stored in
    a shed for years and years. I cleaned it up, but it's
    getting increasingly hard to start when cold. Starts instantly
    when hot.
    Compression is 60. Shoot in some oil and it comes up to 120.
    Looks like ring problem. Don't hear any piston slap.
    I know it's hard to diagnose remotely,
    but am I likely to be able to just replace the rings? If I have
    to have it bored and get an oversize piston, it's likely not worth
    the cost/trouble.
    Suggestions?
    Thanks, mike
    Return address is VALID.
    Bunch of stuff For Sale and Wanted at the link below.
    Toshiba & Compaq LiIon Batteries, Test Equipment
    Yaesu FTV901R Transverter, 30pS pulser
    Tektronix Concept Books, spot welding head...
    http://www.geocities.com/SiliconValley/Monitor/4710/
    mike, Jun 11, 2004
  2. Oh yes. Those engines are incredibly strong, and it's unlikely to have
    any bore wear at that sort of mileage.
    The Older Gentleman, Jun 11, 2004
  3. mike
    pragmatist Guest
    Mike,
    You're right about it being hard to diagnose remotely, especially in
    the detail required.
    13K is kind of a short life for rings unless there is rust damage
    involved,
    (a distinct possibility with long shed storage you mentioned).
    The bores may be 'ringed`. If this is the case, you need a hone job
    at a minimum, maybe a rebore, but you won't know until you open her
    up.
    If you don't feel a stiff spot when you turn the engine by hand
    there's a chance its OK.
    Best of luck with it,
    Pragmatist -"R75/5 Forever!"
    We are now ruled by a George II.
    Doesn't history have a fine sense of irony?
    pragmatist, Jun 11, 2004
  4. mike
    fweddybear Guest
    You may have more than ring damage... if the bike sat for a period of
    time, you may also have some damage in the head... i had a similar
    situation... low compression in one cylinder... half of that than the
    others... turned out that the head needed to be welded and resurfaced
    because there was way too much rust damage from sitting.....apparently that
    particular cylinder had a vale open and condensation found its way in there
    and time did its thing. I did the compression test and all too.... wasn't
    just rings in my case.... but while you have the head off.. you might as
    well just do a top end job... it may save you from having to go back and do
    one anyway....
    good Luck
    Fwed
    fweddybear, Jun 12, 2004
  5. mike
    mike Guest
    Tell me more about the additive. Last time I tried putting additives
    in my bike oil, the clutch started slipping. Is this marvel stuff
    clutch safe?
    I tried selling the thing as an RV add-on, that's what I used it for.
    Problem is that people who came to look expected to buy one for $50.
    Don't have the RV any more. Been using the thing for garage sales
    cause of the gas mileage. Not sure I want to go in for a
    complete rebuild. Cost of pistons, etc makes my Scrooge-sense tingle.
    mike
    mike, Jun 12, 2004
  6. mike
    fweddybear Guest
    Well, it sound to me that if you don't wanna do a coplete teardown to
    fix the problem, you will more than likely end up with the problem until it
    gets fixed. You might be better off just selling it for the 50 bucks and
    buying a new one, or maybe a good used one. One way or another, you will
    have to bite the bullet on this one.....
    Good Luck
    Fwed
  7. mike
    Mastermech Guest
    Pull the cylinders free up and clean the rings and glands by hand, hone it
    out put it back together. Check the valve clearance while the top is off.
    Hell if your careful you can probably use the existing gaskets. A little
    black RTV goes a long way.
    Mastermech, Jun 13, 2004
  8. It's a single.
    I wouldn't bother honing it unless it looks rusty.
    Complete nonsense - check the valve clearances with the engine
    reassembled.
    Into the oil pump....
    Well, that's this week's Crap Mechanical Advice posting taken care of.
    next?
    The Older Gentleman, Jun 13, 2004
