Can a 1967 Honda CL90 run on unleaded gas?
Discussion in 'Motorbike Technical Discussion' started by Steve, Jul 11, 2005.
  1. Steve
    Steve Guest
    Hi Everyone,
    It just occurred to me that unleaded fuel didn't exist in 1967 when my
    Honda CL90 was made. Is it ok to run on regular unleaded? Seems to run
    just fine, is octane the only issue or do I need the lead for the
    valves? I can get 100 low lead aviation fuel, but I can't imagine that
    being any better. Any suggestions would be most welcome, it's an old
    bike and I'd hate to be the one who kills it.
    Steve.
    Steve, Jul 11, 2005
  2. Normally, I wouldn't worry with an old Jap bike, but 1967 *is* a bit
    early, as you say. It's not the anti-knock, but the valve seats, as you
    rightly say.
    I'd be tempted to tip some of that additive in the tank every now and
    again, on the basis that a CL90 uses so little fuel anyway the extra
    cost will be minimal.
    The Older Gentleman, Jul 11, 2005
  3. Steve
    yamadawg Guest
    im not to shure if it requires it but u can allways go to ur bike shop
    and buy a lead additive to mix in with ur gas
    yamadawg, Jul 11, 2005
  4. Steve
    Paul Cassel Guest
    More ignorance spewed forth here from this old fart. The valve seat
    (I've also heard valve guide wear also) recession issue is 'in theory'
    and NOT in fact. I've never heard, even second hand, of a real case of
    valve recession which could concievably be due to using unleaded gas in
    an older engine.
    Here, we're dealing with a Honda which has hardened valve seats anyway.
    There is utterly nothing adverse which will occur to your engine using
    modern unleaded gas of the correct octane rating.
    -paul
    Paul Cassel, Jul 11, 2005
  5. Steve
    Iraxl Enb Guest
    I dont think there will be any issues... In the days of
    leaded fuel, tetra-ethyl lead was used to improve the
    anti-knock qualities of gas. The anti-knock quality is
    numerically designated by the octane rating of the gas.
    With the advent of the catalytic converter, the lead
    additive would poison the converter, and so the switch
    to unleaded was required. If the bike doesnt have a
    catalytic converter (as in mine, a 2002 Honda CBR F4i,
    non-CA), you can use leaded/unleaded, the only thing
    that matters is that the Octane rating for the fuel be
    above the minimum recommended by the manufacturer...
    HTH,
    irax.
    Iraxl Enb, Jul 11, 2005
  6. Well, sorry to disillusion you, but when leaded was phased out, Shell
    did some research here in the UK.
    They took old A-series British Leyland engines (google for it) and did a
    controlled experiment, running them on unleaded, and measuring valve
    seat recession.
    They discovered that "lead memory" meant that it actually lasted a
    remarkably long time before significant valve seat damage was apparent -
    IIRC, well over 30,000 miles. However, if the engine was used hard -
    hammered and thrashed - then the wear curve became amazingly steep, and
    damage was noticeable at as low as 5,000 miles.
    In my then job as editor of a transport magazine, I was given the survey
    for inclusion in the mag. Which I did.
    It probably does. But it's so early, it might not. Almost all Jap bikes
    made since about 197o have been designed for unleaded, but this one is
    Beatles-era. And my posting was erring on the side of caution for that
    reason.
    Aren't you a little bit tired of making yourself come over as an
    embittered, poisonous ignoramus?
    We've had people like you before here, you know.... dear old Hoyt.
  7. You *did* check exactly how old this thing is, didn't you?
    It's a 1967 bike; scarcely bigger than a moped. Of course it doesn't
    have a cat!
  8. I have several thousand miles on my 69 CL90 without any damage or issues
    while using unleaded. At that point in time, Honda was using some hardened
    valves/seats so you should not have any problems. If you are concerned,
    simply have the top end rebuilt with the newer valves and seats.
    Carl
    SBC News Server, Jul 25, 2005
