Camchains and stuff
Discussion in 'UK Motorcycles' started by mups, Aug 25, 2004.
  1. mups
    mups Guest
    Having decided to keep the old CBR for a bit I've decided to do something
    about the rattling cam chain, so popping down to the local Honda emporium
    to enquire about how many limbs/first borns they want for the bits I
    found that you can only get endless cam chains for the CBR1000s. The
    mechanic there suggested that I split the endless chain, feed it though
    and re-join it, sounds a bit dodgy to me?
    So the choices are
    1) Engine out and complete strip down, to replace endless cam chain
    2) Split cam chain and rejoin
    3) Just bung in a new tensioner and hope for the best
    4) Buy better earplugs
    What are the views of the FOAK on all this?
    mups, Aug 25, 2004
  2. mups
    Jim Ingram Guest
    I'm surprised you can't buy one split, have you tried M&P?
    Having said that I replaced the cam chains on a VT250 many years ago
    by splitting and rejoining without problems. The motion pro chain
    tool will assist in doing this (I would get a spare pin for the tool
    in advance as its not that difficult to break one), but not really
    necessary if you can get a split chain. In any case the pins/side
    plates are basically an interference fit and probably wouldn't come
    off even if you forgot to rivet them.
    BTW if the cam chain is duplex as opposed to roller chain be careful
    when you attempt to fit the new link/re-rivet as its easy to push the
    side plates on too far resulting is a very tight link which is tricky
    to free up.
    Have a practice first on a bit of old cam chain if your going to
    split and rejoin especially if its duplex chain.
    Jim
    Jim Ingram, Aug 25, 2004
  3. mups
    mups Guest
    Jim Ingram says...
    The sales droid at M&P didn't know if the camchain was endless or not.
    Their description just said 'camchain'.
    I think I might give it a go, be a good excuse to buy some more tool porn
    as I've not got a chain splitter. I mean what can go wrong...
    Its a duplex type jobbie, which is what worried me about splitting it.
    Anybody got a bit of old camchain they don't want?
    It does indeed, ta.
    mups, Aug 25, 2004
  4. mups
    SP Guest
    He'll be talking about the Honda camchain then? Galea Services do
    replacement camchains either split or endless for lots and lots of
    bikes, as does M&P.
    Buy a split one and fit it yourself.
    Lesley
    CBR600FW
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    SP, Aug 25, 2004
  5. I've used a soft link as a replacement, and split the camchain, erm....
    three or four times. No worries.
    It gets a bit complicated with a hy-vo camchain, mind.
    The Older Gentleman, Aug 25, 2004
  6. mups
    mups says...
    Do it with the engine in, take cams out then just break the old chain
    and link the enw one to it and feed the new one round by turning the
    crank round. Rivet it up and then refit and retime the cams. Job's a
    good 'un.
    You can buy a set length of the camchain required from any DID supplier
    who has an account with Bickers, the DID importers. Bickers will cut it
    off the roll for you and supply a soft link to suit.
    The type of chain you need is :
    SCAO412ASDH 150 link, Bickers part number: 3114013
    You'll also need the soft link, Bickers part number: 3114050
    DID recommend the use of a rivetting tool, but you can get away with
    doing it with a ball-pein hammer and a solid block on the other side of
    the chain link if you are careful. I've supplied hundreds of cut-to-
    length camchains when I was a Bickers rep, and none gave any problems.
    It may be worthwhile replacing any tensioner blades at the same time,
    for much the same reasons as sprockets get changed with drive chains.
    Lozzo, Aug 25, 2004
  7. mups
    mups Guest
    SP says...
    Oh ta, I'll give Galea a ring tomorrow then.
    mups, Aug 25, 2004
  8. mups
    mups Guest
    Lozzo says...
    Marvelous stuff. Once again I'm indebted to his spicness.
    Right you are sir.
    mups, Aug 25, 2004
  9. mups
    mups says...
    Galea are in Southend somewhere now. Not in the old North London
    workshops they had.
    Lozzo, Aug 25, 2004
  10. mups
    Salad Dodger Guest
    Shall I stick that rocker box gasket into my weekend bag, then?
    | ___ Salad Dodger
    |_\_____/_| ..69339../..16127.../..3180./.19406
    \|^|/ ANORAK#17
    '^' RBR-Visited:74 Pts:1630 Miles:5400
    Salad Dodger, Aug 25, 2004
  11. mups
    Make sure to call the London number - a swift google throws up
    shitloads of links to firms of the same name in Malta, of all places.
    You wouldn't want to get unexspictedly spicked, now would you.
    Pip, Aug 26, 2004
  12. mups
    Pip says...
    Galea is as common a surname in Malta as Hawkins or King might be over
    here.
    Lozzo, Aug 26, 2004
  13. I can see them now, Maltese versions of Swiss Tony, with gold-plated
    Honda camchains looped round their necks.
    The Older Gentleman, Aug 26, 2004
  14. mups
    The Older Gentleman says...
    I so wish I could replicate a Maltese accent in written form. I could
    have a proper laugh with this.
    Lozzo, Aug 26, 2004
  15. mups
    mups Guest
    Salad Dodger says...
    That would be most kind of you Mr D.
    mups, Aug 26, 2004
  16. mups
    Lady Nina Guest
    Is Steph attending? I've managed to read the grand total of one of
    those books she lent me. Summer holidays pah!
    Lady Nina, Aug 26, 2004
  17. mups
    mups Guest
    Lady Nina says...
    Indeed she is. I'm not allowed out on my own now a days
    There's a test you know.
    mups, Aug 26, 2004
