camchain tensioner on a 98 CBR600F
Discussion in 'UK Motorcycles' started by steveonholiday1, Dec 10, 2007.
  1. Hi all,
    I've just bought a 24000 mile CBR and I'm checking the valve
    clearances but I cant work out a bit in Haynes about the camchain
    tensioner.
    "Retract the tensioner plunger using the special tool"
    Any idea why I need to do this before checking the valve clearances?
    It doesn't seem to stop me getting to the point of checking them all
    in turn while cranking the engine over with a socket in the
    crankshaft.
    I'd be more tempted to ignore it if all the clearances were ok, but
    weirdly, all four valves on cylinder 4 are a bit narrow so I'm looking
    for excuses to avoid having to sort them out... and maybe the fact
    that I haven't retracted this plunger is the reason...?
    Cheers for any help
    Steve
  2. You only need to retract the tensioner if you're actually moving the
    cams (can't remember if a '98 CBR6 has shims under the buckets or on
    top). As you say, for simple gap checking, there's no need to touch it.
    The Older Gentleman, Dec 10, 2007
  3. Thanks.
    It has shims under the cams (not sure what the buckets are you
    mention).
    It looks like I'm going to have to take the cams off anyway if this
    doesnt explain cylinder 4 gaps all being tight. Arse!
    Cheers
    Steve
  4. Camchain tension will not affect valve clearances, so if they need
    sorted, sort them. If you don't, you'll burn a valve sooner or later.
    Grimly Curmudgeon, Dec 10, 2007
  5. Buckets are just that - small buckets inverted over the end of the
    valve.
    The adjusting shim can either be on top of the bucket or underneath it,
    on top of the, which is more secure but means the cams have to be
    removed to change the shim.
