Camchain tension.
Discussion in 'UK Motorcycles' started by gazzafield, Sep 30, 2006.
  1. gazzafield
    gazzafield Guest
    The HBOL for my SO XJ600 (non diversion) says that I should only adjust the
    camchain when the engine is at TDC. This involves removing the alternator
    to turn the engine over by hand. No big deal except usually this causes the
    gasket for the alternator to stick to the casing then rip. I then have to
    make up a new one which sometimes doesn't fit. So what could be a thirty
    second job turns into a two hour swear-athon.
    So my question is, does the engine need to be at TDC? I can't get my head
    around as to why this would matter. Surely the slack in the camchain is the
    same regardless of the position of the engine or cams/
  2. gazzafield
    I assume the gasket is paper? Greasing it on fitting makes for clean
    removal next time.
    Or go mad and *buy* a replacement before you need to adjust camchain.
    Paper gaskets don't tend to be that expensive - even the Japanese ones.
    sweller, Sep 30, 2006
  3. The engine rottates anti-clockwise, if seen from the left. So turning
    the engine over by the alternator works by pulling 'down' on the forward
    (exhaust) run of the camchain.
    This means that the front run is nice and taut, and all the slack is
    gathered at the rear, since it's not under any load. That slack is then
    gathered by by the camchain tension action.
    The Older Gentleman, Sep 30, 2006
  4. gazzafield
    Why don't you just pop a spark plug out and use your imagination to
    think of a way to tell when the engine is at TDC?
    Andy Bonwick, Sep 30, 2006
