Cam chain tensioner
Discussion in 'UK Motorcycles' started by Beelzebub, Sep 8, 2005.
  1. Beelzebub
    Beelzebub Guest
    Right, now that the 9R is sporting a shiny new set of sparking plug type
    items (no threads stripped thankfully), the next job is to replace the cam
    chain tensioner on the R6. I have a glistening new one sitting next to me,
    beside the HBoL.
    (Just went for the standard one btw, Loz)
    HBoL instructions say I have to remove the tank and carbs, is that usual?
    Seems like an awful lot of work for an easy replacement. Does the FOAK
    reckon I'll have to go down the stripping route or might I be able to just
    get enough access without that palaver?
    The simple solution would be that I'd nip outside and have a look at the
    bike to see, but it's not over here atm.
    Btw, I phoned Yamaha UK about whether the chain should be changed and bloke
    was a little non-committal. Said that technically speaking probably right,
    however camchains built to last a long time - also no set period of
    checking/replacing. His recommendation was change tensioner and if still
    got a rattle, then chain. The garage who suggested I get chain done reckon
    they replace cam chains all the time.
  2. Beelzebub
    Beelzebub says...
    I guess they will do, if people believe what the dealer tells them every
    time. It's a very rare thing to have to replace though and not at all
    commonplace in any of the dealers I visit. My bigges dealership said
    they replace about 3 a year, and that's out of all the bikes their 6
    mechanics service and maintain. Say each mechanic does 2 services a day,
    5 days a week for 46 weeks a year taking into account holiday and
    sickness......come on, I'm shit at maths, someone help me....please....
    Lozzo, Sep 8, 2005
  3. Beelzebub
    You can tell if a chain is knackered my measuring the distance between a
    set mumber of links, I think the HBoL should list the maximum that
    measurment should be somewhere. Any larger, and the chain is knackered.
    Mt HBoL lists measurments for the cam chain and the final drive chain.
    Muck, Sep 8, 2005
  4. He's generally right. Provided the rider hasn't shagged it and the
    design of chain/tensioner is decent.
    More than likely a lot are replaced unnecessarily; a simple tensioner
    replacement would probably have done in a lot of cases.
    A camchain is running in a near perfect environment as far as chains go,
    being fed with oil all the time. Wear isn't great under normal
    circumstances, but what wrecks them is a combination of harsh
    acceleration, crap oil, old oil, slack tensioners.
    Grimly Curmudgeon, Sep 8, 2005
  5. Beelzebub
    Eiron Guest
    How does that work then?
    Eiron, Sep 8, 2005
  6. Inertial loading.
  7. Beelzebub
    Like a fucked tensioner or bouncing off the rev limiter?
    Muck, Sep 8, 2005
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, Beelzebub
    Yes. Get on with it.
    And take pictures.
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Sep 8, 2005
  9. Both, and neither, depending on the state of the engine and rider.
    If you accelerate anything mechanical, it's going to put a loading on
    the drive. Even though camchains aren't pulling anything like as much
    load as a final drive chain, the principle still holds. Let's face it,
    lots of riders aren't all that mechanically sympathetic and thrash the
    **** out of their engines quite a lot. All the internal bits suffer
    accordingly. Continual harsh acceleration will stress the camchain links
    and promote wear; in an engine with a badly designed or sticky tensioner
    the process will be exacerbated and the camchain will need replaced much
    sooner than would otherwise be the case.
  10. Beelzebub
    An unmaintained and thrashed engine is going to go pop sooner, that's a
    fair thing to say.
    I'd guess that this is why race engines tend to have things like good
    quality chains and manual tensioners.
    Muck, Sep 8, 2005
  11. Beelzebub
    Eiron Guest
    Can you put some numbers to your theory?
    How does the component of the camchain tension due to engine acceleration
    compare to that due to engine speed?
    I doubt that it is significant even at WFO in first.
    Maybe if you give it full throttle in neutral?
    Eiron, Sep 8, 2005
  12. Nope, can't be arsed.
    At steady speed, there'll be minimal wear; it's my contention that
    sudden changes in speed will lead to chain stretch. Obviously, some
    chain wear and stretch is to be expected, else a tensioner wouldn't be
    needed at all; but continual hamfisted use of the throttle will
    accelerate this wear.
    By that time, something else is likely to go bang if you do it long
    enough and often enough. It's amazing that more camchains don't snap,
    considering what they put up with. The dynamic load on the chain won't
    change much at any engine speed, since the valvetrain is a constant
    load, irrespective of what the bike's doing at that engine speed.
    See above point.
    Mostly what I'm saying, is that camchains put up with a lot of stick and
    are likely to have their lives shortened by unsympathetic use of the
    throttle (both up and down). If there's a slack tensioner, that'll add
    to the problem.
    Grimly Curmudgeon, Sep 9, 2005
  13. Beelzebub
    Eiron Guest
    So you are talking through your hat.
    There is not a constant load on a camchain at a constant speed, as you
    would know
    if you tried turning a cam by hand; it probably gets smoother at high speed.
    You have no evidence that the load on a camchain due to acceleration
    is the same order of magnitude as the load at a constant speed (due to
    friction, valve mass, spring forces, etc.)
    What's the moment of inertia of a typical camshaft and pulley?
    Eiron, Sep 9, 2005
  14. Yes, it probably gets smoother as it gets faster, true.
    Yes, yes, yes, but what about sudden changes in load, eh?
    Why don't you tell me?
  15. Beelzebub
    Another big factor I'd think, is resonance. Every cam chain will have
    its resonant frequency, and it's when those resonant conditions are met
    that I'd expect forces to be high. All completely theoretical though..
    Muck, Sep 9, 2005
  16. It's be interesting to find out, but I'm sure the engine makers have
    done it. IMO, when a relatively lightweight component like a camchain is
    allowed to whip about because of a faulty automatic or slack manual
    tensioner any wear that's already there will greatly increase because of
    shock loadings.
    To add to my other thought on the matter, it wouldn't just be harsh
    acceleration, it'd be sudden changes in load direction (rapidly on and
    off the throttle, like a dancing monkey) that wouldn't be doing it any
    favours in the longer term. That, combined with the above whip might
    lead to breakages.
    Fortunately camchain breakages are quite rare; just as well really.
  17. Beelzebub
    Eiron Guest
    Just what do you think the camchain drives?
    "rapidly on and off the throttle" might do things to your transmission
    but they won't have any effect on the valve gear.
    And to recap, a back of an envelope calculation suggests that if you
    took the engine from tickover to the redline in 1 second the strain on
    the chain due to acceleration would be of the order of 2Kg, which is
    peanuts compared to that due to other forces at a constant engine speed.
    Eiron, Sep 9, 2005
  18. Beelzebub
    Chains jumping teeth are more usual though, but the only ways I can see
    this happening is through FOD or a knackered tensioner, or a really
    knackered chain.
    Muck, Sep 9, 2005
  19. Not really - this was more or less the reason for the early CX500
    camchain tensioner breakages.
    The Older Gentleman, Sep 9, 2005
  20. Beelzebub
    What did Honda do to fix the problem? Beef up the tensioner?
    Muck, Sep 9, 2005
