Hello I changed the brake lines on my fazer 1000 (rubber to braided). It was a bugger to bleed, but I've now got front and rear good and solid. The rear is now about the best rear brake I've had on a bike (In fact I need to be careful until I get used to it - my previous rather deft "use a little bit of back brake", now appears to be "stamp on the back brake as hard as you can to make sure the wheel locks"). However, the front is less impressive. The lever is rock hard after only about 1 cm of travel, but the brakes actually seem worse at stopping the bike. It's hard to describe, but I find I need to pull a lot more than I'd expect. I upgraded my previous bike (fazer 600) to braided and the front was perfect (never seemed to get the air out the back though), and I have a BMW with braided hoses (admitedly also with servo), so I know what good solid brakes should feel like, but mine just don't feel good. I suspect some brake fluid might have got onto the front pads, but not much - maybe a drip or three from the nipple. I know plenty more went on the rear (like I say, the bleeding was a nightmare), and the rear is fine. Is brake fluid that bad for pads? If so, any ideas before I swap out the pads - e.g. is there a magical thing that will clean any fluid contamination off the pads, or will any brake fluid have "soaked in" by now? (I changed the pads about 2-3k miles ago so there is plenty of pad left). cheers Darren
