Calibrating Torque Wrench.
Discussion in 'UK Motorcycles' started by toad, Nov 18, 2006.
  1. toad
    toad Guest
    I've got an 7 yr old torque wrench. (Kasama kamasa - something like
    that)
    Am I right in assuming it *will* need regular recalibrating - or do
    they stay in spec for ages?
    Where can you get them calibrated? (Brighton area ATM) Is it pricey?
    If (as I suspect) it's easier and cheaper to get a new one what's a
    good torque wrench to buy ATM? I'd like accuracy over a big range - 0
    -150ft lbs but I suspect that's not possible with just one torque
    wrench.
    toad, Nov 18, 2006
  2. toad
    Do you carry out work with the torque wrench that needs a high level
    of accuracy when being assembled?
    Do you carry out work with the torque wrench that you're being paid
    for?
    If you've answered yes to either of the two questions then you should
    have had it calibrated annually so get on with it or buy a new one.
    If you've answered no to both then just carry on with the same wrench.
    Only you can know how much you've used the wrench and how badly
    you've abused it and they're the factors that matter rather than age
    when it comes to home use.
    Andy Bonwick, Nov 18, 2006
  3. you need at least two for normal use, if you don't use them as breaker bars
    etc they are likely to stay as accurate as is necessary indefinitely.
    if you are worried then just rig up a weight system, grip the square drive
    in a vice and see how much weight needs to be applied to get the torque
    wrench to click. obviously you need to measure a set distance along the
    handle and maybe work out a ratio or two. if you stick to foot lbs it is
    quite easy.
    mrcheerful , Nov 18, 2006
  4. toad
    Dave Emerson Guest
    Unless it's been abused or left to rust it should be fine for a lifetime.
    When I work in the sircraft industry we had to have ours checked every year
    but they never needed adjusting.
    DIY is the best bet.
    Use a socket on a bolt head in a vice
    Attach a spring balance (from fishing tackle shop) to the end of the wrench
    and pull.
    The torque setting should agree with the distanceXforce, e.g ftlbs, kgm,
    etc.
    If in doubt (do fisherman ever lie?) check the spring balance with objects
    if know weight e.g. the favourite "bags of sugar".
    Any wrench that's marked from O has to be suspect.
    Teng Tools do a good wrench @ £57.90 RRP
    http://catalog.teamvise.co.uk/webspeed/katalog/kat_produkt.p?bid=T01&kat_bid=T01&dokid=12237
    and they also do repair kits, if required.
    Dave Emerson, Nov 18, 2006
  5. Checking it isn't difficult. Recalibrating if wrong may well be - even
    impossible.
    What are you doing that requires such accuracy? Most automotive tasks
    don't.
    And you simply won't get one device for this range - the lower settings
    need specialist and expensive tools.
    Dave Plowman (News), Nov 18, 2006
  6. toad
    co10 Guest
    I have had two Norbar wrenches (different ranges) for several years, and
    they have never yet required recalibration.
    Bill
    co10, Nov 18, 2006
  7. toad
    co10 says...
    I bought my Norbar one in 1979, I checked it on the test rig when I
    worked at Millbrook Proving Ground in 1996 and it was bang on. I haven't
    used it much and the tension is always wound off before it gets put
    away. I don't think it'll eveer need recalibrating for the very little
    use it gets.
    Lozzo
    GSF600SW (broked)
    'I do not object to people looking at their watches when I am speaking.
    But I strongly object when they start shaking them to make certain they
    are still going.' William Norman Birkett, 1st Baron Birkett, Oct 1960.
    Lozzo, Nov 18, 2006
  8. toad
    Dan L Guest
    Lozzo tossed off:
    I surveyed their works for aircon maintenance last month
    Dan L
    1996 Kawasaki ZR1100 Zephyr
    BOTAFOT #140 (KotL 2005/6)
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Nov 18, 2006
  9. toad
    Dan L says...
    You get some interesting vehicles in there, from all over the world.
    Lozzo
    GSF600SW (broked)
    Lozzo, Nov 18, 2006
  10. toad
    Dan L Guest
    Lozzo tossed off:
    Ahh, sorry, I wasn't at Milbrook, I was at Norbar in Banbury.
    Their works are very small and somewhat unsophisticated for an
    international company, but their products (from what I saw of them) are
    top notch. I hope I win this one, although a mate currently has the
    contract.
    Dan L
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Nov 18, 2006
  11. toad
    Duncan Wood Guest
    That's not calibrated though, so you don't gain much.
    Duncan Wood, Nov 19, 2006
  12. toad
    Duncan Wood Guest
    But traceable to what?
  13. toad
    Lin Chung Guest
    Lin Chung, Nov 20, 2006
  14. toad
    IanDTurner Guest
    I'm an RAF engineer. Our torque wrenches are calibrated every 3 months,
    and the % error calculated. There is a tollerance beyond which they are
    withdrawn ( around 3% I think ). Also we are supposed to check the
    torque on a torque analyser ( meter ) before any task.
    Of course I do this working on my car...............
    Oh, and how many of us do actually back the wrench off totally after
    use to avoid knackering the spring?
    IanDTurner, Nov 20, 2006
  15. *Waves*
    The Older Gentleman, Nov 20, 2006
  16. toad
    The Older Gentleman says...
    <waves>
    Every time it goes back in the box.
    Lozzo
    GSF600SW (broked)
    'Blessed is he who comes in the name of the Lord does not refer to
    blasphemy during ejaculation' Tori 2006
    Lozzo, Nov 20, 2006
  17. toad
    Dan L Guest
    The Older Gentleman tossed off:
    Waves here, too
    Dan L
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Nov 20, 2006
  18. Religiously. Never once forgotten. Yet.
    Dave Plowman (News), Nov 20, 2006
  19. toad
    Guy King Guest
    The message <>
    Particles, here.
    Guy King, Nov 20, 2006
  20. toad
    Eddie Guest
    Every time, and also if I need to set it to a lower torque.
    Eddie, Nov 20, 2006
