Bye bye
Discussion in 'UK Motorcycles' started by Lozzo, May 6, 2005.
  1. Lozzo
    I'm off to Belfast to pick my bike up.
    See you tomorrow, if I'm in any fit state to type.
    Lozzo, May 6, 2005
  2. Lozzo
    have a couple of pints of Guinness in The Crown - that'd be my recco.
    if you're in a fit state to type, you've missed out on a great night.
    darsy, May 6, 2005
  3. In uk.rec.motorcycles, Lozzo amazed us all with this pearl of wisdom:
    Piece of piss. I did London to Coleraine to London in a few[1] hours on
    a 400.
    [1] More like a day.
    Whinging Courier, May 6, 2005
  4. Lozzo
    Good luck with it. :)
    I've just had an idea about your old 9R braking problem.. bit too late
    though init?
    Muck, May 6, 2005
  5. Lozzo
    Laydeez an' Gennelmen: the Spic has left the building.
    That is all.
    Pip, May 6, 2005
  6. In uk.rec.motorcycles, Pip amazed us all with this pearl of wisdom:
    Is Ireland ready?
  7. Lozzo
    Beelzebub Guest
    No, it's not too late - I'd be delighted to hear, if you don't mind.
    Beelzebub, May 6, 2005
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, Beelzebub
    Unfortunately, the idea was "Punt it out to some mug, before you bin
    it."
    and Ducati Race Engineer.
    Wicked Uncle Nigel, May 6, 2005
  9. Lozzo
    It may be Bandit specific, but... I noticed that my Bandit brakes, as
    well as having anti squeal shims, they come with these thermal
    insulating plates that fit in between the shim and the back of the pad.
    Some people throw these things away with the pads sometimes [1].
    Is it at all possible that the extreme heat of high speed braking is
    conducting through the pad, and heats up the pistons to such an extent
    as to boil the fluid? Boiled fluid has the effect of bringing the lever
    back to the bar in extreme cases.
    [1]I'm not saying that you have, or did..
    Muck, May 6, 2005
  10. Lozzo
    'Hog Guest
    The Racing Snake has survived 911 dicing and made the Dublin ferry with
    90 minutes to spare. It's a big boat but the loading ramp may not be
    wide enough to accommodate his grin.
    Smart boy that, he sussed one important reason I like it here inside 90
    minutes.
    Pip, perk the coffee around midnight.
    'Hog
    'Hog, May 7, 2005
  11. Lozzo
    Beelzebub says...
    Are they still coming back too far before biting?
    Lozzo, May 8, 2005
  12. Lozzo
    zymurgy Guest
    it."
    LOL !
    Paul.
    zymurgy, May 8, 2005
  13. Lozzo
    zymurgy Guest
    Eh ? I'm fecked if i'm getting the espresso pot on every time I want a
    coffee.
    That being said, I very very seldom drink instant.
    I picked up one of these last time I went to Canada.
    http://www.coffee-maker-store.com/item/1961.php
    They pull the grounds out of the pot rather than letting them fester in
    the bottom of the coffee pot. Well recommended & much better than those
    crappy Bodums.
    Cheers
    Paul.
  14. I use an old-fashioned percolator. Excellent coffee, every time. No
    hassle.
    The Older Gentleman, May 8, 2005
