Buying a 50s BMW
Discussion in 'UK Motorcycles' started by Newt Bridges, Oct 25, 2008.
  1. Newt Bridges
    Newt Bridges Guest
    Hi,
    I'm planning on buying a BMW from the 50s, and would like to know if
    there's something I should be aware of?
    My eyes were originally set on a R25/3, but it's only 250ccm and since
    my own weight is about 110kg it perhaps should go for R51/3 instead.
    I kinda like "the look" of the R51/3 over an R50, but the R50 is newer
    and perhaps recommendable due to the updates it got?
    The R6x are outside my budget, except if there's really good reasons
    for buying one of those instead.
  2. Newt Bridges
    It's very old
    You've posted in the wrong group. There is a sister group for such old
    crap.
    X-posted for your benefit
    wessie, Oct 25, 2008
  3. Newt Bridges
    You may as well buy a recently built one, they haven't changed anything.
    Lozzo, Oct 26, 2008
  4. Newt Bridges
    al Guest
    well, , , , that's not quite right...
    they have changed a lot, but a flat twin is of course a flat twin so there's
    not a lot that can be done to change the shape of it, or the perception of
    it as
    being an old design bike.
    bmw are now building flat twin engines that are very efficient at what they
    do.
    they aren't over engineered to the extent they used to be, so i'd not defend
    that aspect of them, but, for anyone that cares about mpg figures on bikes,
    i was getting 70mpg on a late r1200rt when touring at 'easy' speeds. the
    'not so highly tuned' flat twins can get excellent mpg figures, or can be
    tweeked up for speed and power a-plenty (the sports versions).
    unfortunately bmw seem to have reduced the quality of their offerings and
    aren't over engineering as much as they used to. gone are the days when
    you could throw a bmw into a ditch and come back a year later and start it
    up and use it in the same condition as you left it. i'm pretty sure they'd
    rust into heaps the same as japanese bikes would (i am not having a poke at
    jap bikes by the way, they are excellent machines too, just not what i look
    for in a bike).
    cheers, al, removing his slippers, putting his pipe out, and going to bed
    to catch up on some much needed sleep LOL
    al, Oct 26, 2008
  5. You will develop a tendency to wear large stormcoats and waders.
    Brown workshop coats are optional.
    Grimly Curmudgeon, Oct 26, 2008
  6. The message <[email protected]>
    Oy! I resemble that remark!
    Rusty Hinge 2, Oct 26, 2008
  7. What the ****** is it about BMW owners that they have to lie about their
    fuel consumption figurers (or omit to mention that they were achieved at
    a snail's pace)?
    The Older Gentleman, Oct 26, 2008
  8. Newt Bridges
    deadmail Guest
    (The Older Gentleman) wrote in message
    What do you mean? I regularly get:
    39mpg out of the K75
    40mpg out of the ZXR750
    36mpg out of the K100 sidecar
    42mpg out of the K1100
    and 23mpg out of the 735.
    I have got...
    36mpg out of an ST1100
    32mpg out of the z500 with sidecar
    26mpg out of the 520
    50mpg out of a GPZ600r
    39mpg out of a ZX9r
    59mpg out of a CB250RS
    39mpg out of a GT750
    38mpg out of a K100
    37mpg out of a(nother) K100
    40mpg out of yet another K100
    51mpg out of a BX19rd
    45mpg out of a ZX 1900 diesel
    That's all I've kept records for recently...
    deadmail, Oct 26, 2008
  9. Yes, but you're not the stereotypical BMW bore, like al appears to be.
  10. Newt Bridges
    fragmented Guest
    Never worked out what I get from the GS, but it drinks about as much as
    the 9R at 3/4 the speed.
    fragmented, Oct 26, 2008
  11. Newt Bridges
    It may be that they believe the odometer is correct and when it says
    they've done 100 miles they don't realise it's only about 90.
    Andy Bonwick, Oct 26, 2008
  12. Standard BMW error, is that.
  13. Newt Bridges
    I'd believe the GPS rather than the speedo and odometer.
    It's easy to claim that you get 50mpg cruising at a steady 80mph but
    the reality is that you're actually getting 45mpg at a steady 70mph.
  14. Newt Bridges
    Apparently, if I fitted the speedo cable gearbox from an R1150RT to my bike
    I could make it accurate. I quite like it the way it is. Ever the optimist.
    The Citroen has a digital display which is pretty accurate according to my
    GPS. I don't like it, especially when in autopilot on a motorway. Far too
    easy for my speed to creep up to camera triggering speeds. The car is
    loaded with all sorts of electronic gadgets but they omitted cruise
    control. Fuckers.
    wessie, Oct 26, 2008
  15. Newt Bridges
    Cab Guest
    My Audi has a cruise control where I think the speed set is more in
    line with the built in GPS than the displayed speed on the odometer.
    Cab, Oct 26, 2008
  16. Newt Bridges
    AOL. I only found out on the French trip that the speedo on the RT
    actually reads true instead of lying in the usual BMW
    fashion. Fortunately I noticed before plod noticed.
    Timo Geusch, Oct 26, 2008
  17. Newt Bridges
    Just been checking the speedo/cruise control on our R36. The GPS
    doean't actually display speed, but checking against our TomTom shows
    about +5kph error across the board, so far. What worries me slightly
    is that the TomTom also reads about the same amount _lower_ than the
    many radar-based speed displays that are popping up in the villages
    round here. Dunno if they're set deliberately high, but it wouldn;t
    surprise me.
    _______
    Ace, Oct 26, 2008
  18. Newt Bridges
    My brother has an R1150R, which he bought new about 7 years ago. It's
    currently having its 3rd ABS pump fitted. Logs show that the ABS has been
    activated for 30 seconds over the last 5000-odd running hours.
    platypus, Oct 26, 2008
  19. Newt Bridges
    I haven't had ABS on my R-GS for about 4 years. I haven't died yet.
    It might just be a sensor, as it works for a short time after a hard
    reset. It could be the pump. Apparently, if I bother to take it to a BMW
    dealer they could plug it into a simulator that will diagnose the problem.
    I can't be arsed to ride over to Bristol or Stroud, though.
  20. Newt Bridges
    @text.news.virginmedia.com:
    does that work okay now? I tried it a while ago and it was shit. Went back
    to news.virginmedia.com, which gets a bit slow and grumpy during peak hours
