building customs
Discussion in 'Australian Motorcycles' started by Jack VK2CJC / MM0AXL, May 25, 2006.
  1. Jack VK2CJC / MM0AXL
    JL Guest
    Only if you can convince the RTA that you have modified a 1976 bike, as
    opposed to creating a new one by a whole new from scratch frame.
    Doesn't matter a monkey's what he thinks. If the frame is a 1956 frame
    modified then it's not a completely new frame is it ? So it comes under
    the regs for a '56 then, hey ?
    Don't forget that the regs aren't retrospective, so if you built a bike
    from scratch in 1967 using a 1956 donor motor, then as far as the RTA is
    concerned it's a '67 (or whatever number is in their database given how
    sketchy their data is for older stuff)
    An opinion being popular doesn't make it right.
    It's not hard, the frame is the bike, build one fully from scratch and
    it's an '06 - retain enough of an original frame to persuade an engineer
    it's a modification and not a new frame and it's then a modified one of
    whatever year model it is.
    Mod rules vary according to age.
    JL
    JL, May 26, 2006
  2. Wise council indeed.
    Unfortunately I hear through the grapevine that our local guy is a dickhead
    who fails everything unless its standard.
    Jack VK2CJC / MM0AXL, May 26, 2006
  3. Drop into your local custom
    I did. They didnt know. Even though they are rode chopped harleys :eek:)
  4. It's not hard, the frame is the bike, build one fully from scratch and
    Thanks for that, that all makes sense.
    Next question, how much of the frame has to remain to qualify as modified?
    The one I built had the steering head, down tubes and engine cradle round to
    about half way up the back of the motor. I replaced the top tube and put on
    a rigid rear. Or maybe that's down to the individual engineer.
    I don't plan to do this. Not at the moment anyhow, just curious to learn.
    cheers.
  5. In aus.motorcycles on Fri, 26 May 2006 07:57:59 GMT
    So go to him and say "I am looking at a modified bike. Can you tell
    me what I need to know to get it registered? What I have to do?"
    And see if what they say is true.
    Zebee
    Zebee Johnstone, May 26, 2006
  6. In aus.motorcycles on Fri, 26 May 2006 08:04:45 GMT
    Probably. My Yam has the same cradle and oil-carrying backbone, and tank,
    and the rear subframe is heavily modified to fit the monoshock. The
    rest - forks, swingarm, seat,wheels, bars, brakes, lights - are off
    other bikes.
    So the majority of the "frame" is Yamaha.
    It's registered as a '76 Yam XT. Helps that the compliance plate is
    in good condition and the engine number matches.
    Zebee
  7. Jack VK2CJC / MM0AXL
    atec77 Guest
    On rods in Qld you can claim a reproduction chassis as long as you have
    the bit of the original with the serial , not much at all.
    atec77, May 26, 2006
  8. Jack VK2CJC / MM0AXL
    Nev.. Guest
    24 hours ago you had no idea at all of the process and today you know
    the reputation of the 'local guy'...
    Nev..
    '04 CBR1100XX
    Nev.., May 26, 2006
  9. Jack VK2CJC / MM0AXL
    G-S Guest
    It was my experience that they say things like "each case is different
    and we can only judge each bike after we've seen it" and "no we don't
    have written guidelines" and similar unhelpful things...
    G-S
    G-S, May 26, 2006
  10. Jack VK2CJC / MM0AXL
    atec77 Guest
    Translates to NFI but were gonna screw you over ?.
  11. In aus.motorcycles on Fri, 26 May 2006 22:39:05 +1000
    It can be tricky if they do that, but it is still worth a try.
    Zebee
  12. Yes
  13. Hmmm... maybe they're holding out for a bottle of Turkey!
    Pisshead Pete, May 27, 2006
