building customs
Discussion in 'Australian Motorcycles' started by Jack VK2CJC / MM0AXL, May 25, 2006.
  1. After my last request for legal advice on exhausts was so expertly fielded,
    I thought I'd throw another into the group.
    A few years ago, when I lived in the UK and I was a little more idealistic
    and a little less cynical/sensible- I built a chopper. Might be more
    accurately termed a low rider in this country. I took the best parts from
    two crashed XJ750s, cut the engine cradle from a frame, put on a single top
    tube and an extended rigid back end. Extended the shaft drive, used standard
    length forks (never liked "overs", to difficult to get the castor angle
    sorted), 6 inch risers, drag bars, forward controls, and built myself a damn
    fine strong reliable machine that handled better than the original swing arm
    frame.
    Now I realise that in this country the thought of someone drawing a design
    for a motorcycle on an old envelope and sitting down at the lathe to
    actually make everything himself would have people stumbling in horror and
    RTA officials requiring hospitalisation. But what can I actually do here? I
    assume making my own frames is not going to happen? But what if I build a
    bike in a RTA approved custom frame? I have asked many custom bike riders
    what they did paperwork wise and they never seem to have an idea. Either buy
    it pre-made and pre-registered. Or ride illegally seem to be the popular
    options. But there must be an approved procedure? Anybody like to try to
    explain in simple terms for a simple biker.
    Thanks
    Jack
    PS. Does anyone else think that a government approved mass produced custom
    made frame is ridiculous? :eek:)
  2. Jack VK2CJC / MM0AXL
    justAL Guest
    Damn, and I thought you just needed an engineer's report?
    justAL
    justAL, May 25, 2006
  3. Jack VK2CJC / MM0AXL
    atec77 Guest
    atec77, May 25, 2006
  4. Damn, and I thought you just needed an engineer's report?
    Pardon me if I'm missing something which everybody else thinks is obvious.
    I'm not familiar with the whole engineers report system and what is
    acceptable and what is not. The NSW RTA website was about as clear as mud
    too :eek:)
  5. Jack VK2CJC / MM0AXL
    justAL Guest
    I'm just clutching straws. Try looking up companies that issue engineer
    reports and try an RTA office first for recommendations or aus.cars.
    It might work it might not, but it's a start.
    justAL
  6. The RTA can supply you with a list of engineers accredited for different
    vehicle types.
    Al
    Alan Pennykid, May 25, 2006
  7. Jack VK2CJC / MM0AXL
    atec77 Guest
    which bit of cock-roach country are you in ?
  8. Pardon me if I'm missing something which everybody else thinks is obvious.
    too :eek:)[/QUOTE]
    You want "Vehicle Standards Information No 28 - Guidelines for
    modification to motorcycles (Apr 1998)"
    pdf available here:
    http://www.rta.nsw.gov.au/registration/downloads/vsi/vsi28.pdf
    (which will refer you as well to VSI15:
    http://www.rta.nsw.gov.au/registration/downloads/vsi/vsi15.pdf )
    VSI28 says (amongst other things):
    Motor cycle design is a complex task. Before you modify your motor
    cycles frame or suspension, you should be aware that structural changes
    to the frame, steering head, front forks, suspension, brakes or wheels
    may load vital components well beyond the limits for which they were
    originally designed; this will increase the probability of failure and
    will be a danger to the rider and to other road-users.
    The RTA will register a modified motor cycle with a properly designed
    custom frame, extended forks and structural modifications but only if
    submitted with a report from a recognised engineering signatory,
    detailing the changes and showing that the changes have not made the
    cycle unsafe.
    It is recommended that you seek the advice of an engineering signatory
    before the modification is commenced. Vehicle Standards Information
    sheet No. 15 Engineering Signatories lists engineering
    signatories recognised by the RTA.
    cheers,
    big
    Iain Chalmers, May 25, 2006
  9. Jack VK2CJC / MM0AXL
    GB Guest
    Here in Oz, 'Damn!' is a polite way of saying "bugger me!". Look
    after JustAL in that regard, and he'll look after you WRT and
    engin-mc-neer's report!
    GB, I'm going straight to hell for that one! Do not pass go, do
    not collect...
    GB, May 25, 2006
  10. Jack VK2CJC / MM0AXL
    GB Guest
    I read that and thought "Shit! I thought Stephen Calder went a
    bit over the top when he thanked me for my time, but wtf is
    that about?".
    Then I realised that I didn't buy in to that particular argument!
    GB, bush lawyer.
    GB, May 25, 2006
  11. Jack VK2CJC / MM0AXL
    justAL Guest
    I'll save you a seat.
    justAL
  12. Jack VK2CJC / MM0AXL
    GB Guest
    Very kind of you sir. Thank-you hairy muff indeed!
    GB, blush!
    GB, May 25, 2006
  13. Jack VK2CJC / MM0AXL
    JL Guest
    Anything you want,registering it however is a different kettle of fish.
    Why ? If you're a decent welder, no dramas with that. If you're not, pay
    someone who is.
    No such thing to the best of my knowledge.
    Which suggests they didn't build what they're riding.
    Yes there is.
    You build your custom bike, you ensure that the engine meets current
    emissions requirements (because the frame is the bike, and if it's a new
    frame then you need to meet 2006 emissions), you ensure it has adequate
    brakes for the power, and that the frame and suspension are also
    adequate for the engine.
    You go get an engineer's certificate to say it's safe. The list of
    certifying engineers is on the RTA website.
    Once you've got an engineers you get a blue slip, pay the green slip and
    cough up your rego at the RTA.
    Then ride off into the sunset.
    JL
    JL, May 25, 2006
  14. You build your custom bike, you ensure that the engine meets current
    Thanks for the advice. But... one of the common lines I get is that if a
    pre-1976 donor bike is used, emission and noise standards are pre-76 even if
    the frame is new. I know a few guys who ride bikes thinking this. Like my
    nieghbour who has a chopped rigid 1956 sportster. He reckons the loud
    exhausts and woefully inadequate drum brakes are fine. But then, he doesn't
    have an engineers ticket either.
    Not disagreeing, just pointing out popular opinion differs. Hence my
    difficulty understanding the rules :eek:)
  15. Thanks. I hadnt seen that second file before.
    Of course, I dont actually plan to build a bike right now, just want to know
    what the proceedure is if I see one for sale I can ask the right questions
    :eek:)
  16. Which reminds me of a few other cases where the rider claims to have
    replaced the frame with an approved replacment part. Theory being that if
    all other parts are standard, only the frame is different and its
    pre-approved.
    Thing is, I know plenty of bikes that use this excuse to build a complete
    one off. Including one bike thats currently over $100,000 spent and rising.
    Youd think with that dedication youd stick a few 100 into sorting the
    paperwork :eek:)
    Maybe I'll stick to a standard bike. Just buy a polished headlamp peak or
    something :eek:)
  17. Jack VK2CJC / MM0AXL
    CrazyCam Guest
    There is the other way of getting a standard bike, registered, and then
    just swapping stuff, but you have to keep it registered.
    So long as you don't go too outrageous, the pink slip examination ain't
    going to cause too many problems.
    Have a look at http://www.mcmod.org/
    regards,
    CrazyCam
    CrazyCam, May 25, 2006
  18. Jack VK2CJC / MM0AXL
    Grump Guest
    Some years back I wanted to register a YZ 250F MX for use in open 2 day
    enduros. (where registration is a requirement).
    Bought an old wrecked pre '76 CR Honda, slipped in the YZ engine, fitted a
    chain guard, mudflaps, mirrors, bulb horn, battery powered lighting
    including stoplight & had no probs getting it registered.
    No, I didn't try to ride it as unfortunately the "frame broke immediately
    after" but luckily I had a spare YZ frame ;)
    More mishaps over the next 2 years saw it evolve into a road registered
    RM400 even tho the engine case still displayed 249cc??...oh well, cheaper
    rego...
    Grump.
    Grump, May 26, 2006
  19. It helps to get friendly with the RTA approved engineer and ply them with
    beer. They can take forever to approve shit! He'll also listen to your
    ideas and tell you whether he'll give it a hope in hell of passing or not
    before you start building.
    Pisshead Pete, May 26, 2006
  20. They do go off the frame for year of manufacture. If obviously customised
    and you're gunna ride it a lot then do the paperwork. I get followed
    regularly while they run radio checks and the only hassle I had was when
    the radio link was down and they couldn't check the RTA to see if I had an
    engineers approval.
    Other people wing it with varying success. You may be able to find a shop
    who can do the legalities for you, for a fee. Drop into your local custom
    shop with a carton and ask advice. They'll be up to date with the ever
    changing bullshit regs.
