Building a news swerver ?
Discussion in 'UK Motorcycles' started by browniebrownz, May 20, 2008.
  1. So work have said that they're no longer supporting nntp.
    But I think I can talk them round to me building a box and admin'ing
    it possibly.
    Do you need owt special ?
    I'm thinking a couple of 500GB SATA Drives on an Intel DQ35JOE running
    Raid1.
    I have no idea of what OS or Applications to use - being a hardware
    person.
    Any hints - online guides ?
  2. browniebrownz
    des Guest
    des, May 20, 2008
  3. browniebrownz
    Simon Wilson Guest
    Just for ukrm? Other text groups as well, or the full binary monty? If
    the latter then consider multiplying the number of drives, by, er lots.
    And a big FO network too :)
    If it were me I'd go for some flavour of Linux, Ubuntu server etc. with
    something like maybe leafnode. I could give you a hand setting it up?
    Why do you need your own hosted server, the public ones not good enough?
    Simon Wilson, May 20, 2008
  4. browniebrownz
    prawn Guest
    What do you mean by a news server? If you want a full on all inclusive
    bells and whistles news server my advice would be to avoid.
    FWIW, I use leafnode <http://leafnode.sourceforge.net/> and take a feed
    and post using the cheesy server[1]. The nice thing is I can tunnel to
    my server to read and post no matter where I am.
    [1] Which is good enough for me.
    prawn, May 20, 2008
  5. browniebrownz
    des Guest
    The second question would be: what business is that of yours?
    D.
    des, May 20, 2008
  6. browniebrownz
    Simon Wilson Guest
    Wow, 5 out of 5 for leafnode, and everyone answered the question posed.
    Is that a ukrm first?
    <Awaits Cane response with NSW link>
  7. Just text groups.
    I don't think I can get at other public servers through the firewall.
    Its stupid - we're an ISP and own a huge chunk of telehouse, but due
    to that business being a seperate business unit even though they're in
    our building, I can't get at their nntp server through the firewall,
    only the one our Network Services bods have provided on the inside is
    viewable.
  8. browniebrownz
    prawn Guest
    Alarming isn't it?
    prawn, May 20, 2008
  9. Make that 6 out of 6 (I use leafnode on the server that I'm replying
    from) running on linux.
    Incredibly easy to set up as long as you are not afraid of command-line
    stuff.
    And as others have said - you *must* have an upstream server to grab
    new news items from (and to post your responses) to. Leafnode allows
    you to set up multiple server/port combos for the upstream ones to
    allow you a bit of resilience.
    Phil
    Phil Launchbury, May 20, 2008
  10. I have no idea, you seem to have all the ****ing answers though ?
    Like I said - tcp/ports/server stuff/protocols is all black art to me.
    Can you please **** off out of the thread and leave the helpful people
    behind, please.
    Just building a news server to replace the one our NS dept were no
    longer going to support seemed like a sensible thing to do, I'm not so
    sure now !
  11. browniebrownz
    Longshanks Guest
    Why not just tunnel nntp through a port they do allow like 80? Assuming
    they don't do inspection and they don't use a proxy you'd be fine.
    Longshanks, May 20, 2008
  12. browniebrownz
    ginge Guest
    Actually his comment is helpful as it gives you detail of something
    you definitely need to consider and work around.
    My suggestion however is a bit more of a bypass of most of the
    effort... come up with a reason for needing NNTP access "Support
    forums" is always a useful one, and just talk to your corporate
    firewall chaps about getting a port opened so you can get access
    outside your own LAN.
    ginge, May 20, 2008
  13. browniebrownz
    Longshanks Guest
    Although your NS dept have removed the NNTP server you may still be able
    to use the one your upstream ISP provide since you'll be using one of
    their IPs. Just a case of looking on their website and seeing if they
    provide one.
  14. At this point my response would be:
    "Pack up your computer and send it back to where you got it from as you
    are obviously too stupid to use it".
    Then you should either a) give up and go back to counting your toes or
    b) learn something.
    Your choice.
    Well - it's going to involve you *actually* having to learn how do to
    something. Which you obviously can't cope with.
    Phil
  15. Tunnel - Something that goes under ground ?
    nntp - Ahh, I recognise that - its a protocol used for news groups.
    port - drink / place to dock ships / and something I connect to via a
    router on my PC (Guessing the latter).
    proxy - yes - we do - with IE I have to configure the proxy name on
    port 8080.
  16. browniebrownz
    prawn Guest
    Ouch! Harsh but fair. I was going to ask if the OP was a receptionist
    for their ISP employer.
    prawn, May 20, 2008
  18. It'd be useful for you to establish whether this is actually the case
    or not, since if you do have access to other public servers through the
    firewall then you can save yourself a lot of hassle by simply using one.
    From a command prompt in Windows, type "telnet news.individual.net
    119". If you see a text message that begins something like "200 The
    server welcomes..." then you are not firewalled, just use a public news
    server.
    There's no reason for it to be firewalled other than "we don't want
    people wasting their time on usenet", and if they've provided an
    internal server for you up to now, then that is probably not the policy.
    Slower Than You, May 20, 2008
  19. browniebrownz
    Longshanks Guest
    A decent sys admin will notice the the lack of entropy in an outbound
    connection using the SSH protocol and would be more likely to block it.
    I'd try tunneling via HTTP, failing that DNS (which is very hard to
    prevent without potentially breaking their network). The encryption
    isn't necessary and only goes to arouse suspicion.
    If they allow outbound NNTP connections then the best bet would be to
    see if their ISP provider supply an NNTP server and use that.
    Google Groups is a good suggestion that I'd overlooked, but I don't know
    how long I'd continue using Usenet if I had to use that all the time :)
  20. browniebrownz
    Longshanks Guest
    If you have an upstream news server why bother running a leafnode? In
    the past I've only used leafnode where the upstream NNTP server has been
    pretty flacky (connection wise) and so it made my reading experience
    nicer or where I've used a proper NNTP client that requires a local
    feed. In the OP's case I'd say they just want to get up and running as
    quickly as possible minimising the amount of gimmicks required.
