Bugs in the fuel
Discussion in 'Classic Motorbikes' started by Charlie Jones, Sep 15, 2003.
  1. Can anyone please tell me how to kill off microrganisms in fuel? I have this
    horrible jelly forming in the floatbowl of my 1939 Rudge. I've heard about
    it before but can't find a cure.
  2. Charlie Jones
    Charlie Jones fascinated us all by saying...
    Ibuprofen and paracetamol
    Lozzo
    '95 Kawasaki ZZR1100D, '97 Kawasaki GPZ500S, '83 Honda CB250RS
    Big Zed Little Zed Dead shed
    New to ukrm? : www.ukrm.net/faq/ukrmscbt.html
    "He's like a child, only not as clever"
    Lozzo, Sep 15, 2003
  3. Charlie Jones
    MikeG Guest
    Yep it's caused by Nanites, they cant live above 50mph so give the old
    girl a good thrashing and that will cure you/it for good.
    They are not dangers to humans unless you are in the habit of putting an
    infected finger from the petrol in your ear whilst having Sex.
    If infected, the symptoms are obvious, you start having an affection for
    Shitoldbritbikes and wearing flat caps while smoking a pipe.
    There is no known cure for this ;-(
    MikeG, Sep 15, 2003
  4. Charlie Jones
    Eh, believe it or not...
    http://www.riskmgr.com/archives/micro.htm
    Hog, Sep 15, 2003
  5. Charlie Jones
    Roger Hunt Guest
    Use leaded?
    or ...
    Have you tied eating it? It sounds a bit like Turkish Delight.
    Roger Hunt, Sep 15, 2003
  6. But petrol, and diesel for that matter, are hydrocarbons not
    carbohydrates and no living thing to my knowledge can survive on them.
    As per your other post, it's the water in the petrol that provokes the
    problem. Even pure water wouldn't, but water is seldom pure. Rainwater
    definitely isn't.
    My old R80 was very prone to water in the petrol, caused by a faulty
    filler cap. It never had a problem with sludge in the fuel, but I used
    to have to whip the float bowls off and empty them periodically
    (fortunately a task which can be accomplished with gloves on) until I
    eventually replaced the filler cap.
    Perhaps if the problem hadn't been so chronic - the water was being
    replaced quite frequently - it would have suffered from microorganisms.
    Regards, Ian
    Ian Northeast, Sep 15, 2003
  7. Charlie Jones
    Sean Guest
    Steam clean the inside of the tank, dry it thoroughly, replace the fuel line
    and clean out the carb with a mild solution of tcp.
    Clean the carb down with carb cleaner or carbon tet if you can get it. To
    dry the tank post cleaning it, blag some bags of dessicant from your local
    computer retailer. Three or four of those in a net bag like the ones you
    get with some washing powder tablets thingummy jobbers suspended in the
    tank and the tank in the airing cupboard.
    The bugs like water.
    Sean, Sep 15, 2003
  8. Charlie Jones
    Sean Guest
    More common with diesel than petrol, but still, if you are a micro organism,
    I guess any available carbohydrate will do.
    Sean, Sep 15, 2003
  9. Charlie Jones
    Sean Guest
    Hydrocarbon? carbohydrate? schmydrocarbon. My mistake. There are bugs that
    can ( I assume, given the sludge seen in diesel and household oil tanks )
    make a living from diesel. Hogs post has a link in it to an article.
    My road going MZ did similar. I couldn't figure out how water was getting
    into the float chamber when the little bowl attatched to the fuel tap never
    had more than a tiny droplet in it. I even fitted an inline filter with a
    sludge trap, to no avail. Turns out it was probably because I had no gaiter
    over the carb end of the throttle cable. That was about the only way I
    could figure how water got in to an otherwise pretty much closed system.
    Bit of silicon sleeving lined with silicone grease and the problem never
    recurred.
    We rescued an early Honda Camino a couple of years ago that had been stood
    in a damp garage for 15 years. The fuel tank contained a 50/50 mix of stale
    fuel and gungy, stinky, cloudy water that had an organic ( it wasn't all
    rust, though there was a fair amount of that. Kinda like rotted leaf litter
    ) sediment. Stank like a disturbed stagnant bog. I guess that'd be the bug.
    Sean, Sep 15, 2003
  10. Charlie Jones
    Guest Guest
    You're confused: the attraction is to much larger engines, and it's
    incurable. The medical name is 'Dibnatism'.
    Regards,
    Simonm.
    Guest, Sep 17, 2003
