Bugger.
Discussion in 'UK Motorcycles' started by steve auvache, Oct 5, 2004.
  1. steve auvache
    Loz H Guest
    I couldn`t find one myself, hence the idea of multiple 10W items.
    Undoubtedly 25W or above items exist, but I was going for the "quick cheap
    fix" angle. :eek:)
    That wire has a resistance of 4.2 ohm per meter, so obviously 0.042 ohm per
    centimeter, 108cm = 4.5 ohm. As for the amount of turns, I wouldn`t think
    that would be much of an issue, although to be fair I`m not really genned up
    on that side of things (see below regards magnetic field and possible EMP).
    With the wire not being enameled, winding it around a smallish former may be
    tricky to achieve. You would have to wind one layer evenly spaced until
    completion, insulate that layer and so on until complete.
    I would imagine any potential magnetic or EMP effect from the coil is
    already accounted for, with this coil design already being used in the
    original item.
    Loz H, Oct 5, 2004
  2. The Older Gentleman wrote
    It bears the mark of the beast certainly.
  3. Loz H wrote
    A rewind is an option.
    The core is half inch across which is about and inch and a half round.
    27 turns = 40+ inches plus tails. It looks very close and I do have
    some resistance wire somewhere.
    Yes. I could always wind it loose around a waxed paper former, spray
    with something, remove the former then compress and spray again. It
    might work.
    I think this is what they means by variable, the third connection being
    made by inductive coupling to earth.
  4. Platy in "shares concepts with Des" shocka!
    You young webel you..
    Phil
    Phil Launchbury, Oct 6, 2004
  5. steve auvache
    <thwows wattle>
    platypus, Oct 6, 2004
  6. On me 'ed son..
    Phil
