Bugger, Triumph start niet
Discussion in 'UK Motorcycles' started by Higgins, May 2, 2011.
  1. Higgins
    Higgins Guest
    So, having pretty much come to the conclusion, on the way back from the
    French Run, that I was selling the Sprint ST, I decided to give it a
    clean for some pics and to install the metric clocks that I had sitting
    in the garage.
    All done, I decided to turn it around and there's not a peep when I
    press the starter button. It goes though all the motions properly but
    not so much as a click. I guess the rest of my day wil be spent taking
    it apart to get to the connectors to check the various interlocks :(
    Oh, yes, I did put the old clocks back, just in case.
  2. Higgins
    Nige Guest
    Did you try the stand switch?
    Nige, May 2, 2011
  3. Higgins
    Adie Guest
    kill switch?
    Adie (replace spam with nickname to reply)
    YZF-R1 : FZ1N : RD350LC
    (anyone would think I was partial to Yamahas)
    MRO#11 BOTAFOF#7 BOTAFOT#130 DIAABTCOD#17 MIB#24 YTC#16
    BOB#15 ex-UKRMMA#22 BOMB#11
    Adie, May 2, 2011
  4. Higgins
    Higgins Guest
    Only to the extent of scooshing it with electrical cleaner before I
    start hunting for the connector.
  5. Higgins
    Higgins Guest
    It seems to be working properly, killing the idiot lights as normal.
  6. Higgins
    GungaDan Guest
    The two connector blocks under the front of the fairing can get damp
    and cause problems. One on the right with the connections from the
    kill sitch and one on the left with the ignition stuff (from memory).
    Might be worth checking since you've just washed it. They're hidden
    away in the side panels adjacent to the forks and are accessible from
    the front of the bike without taking the panels off.
    GungaDan, May 2, 2011
  7. Higgins
    Higgins Guest
    It probably got wetter over the weekend than it did when I washed it :)
    Cheers, I'll have a look.
  8. Higgins
    Higgins Guest
    On 02/05/2011 16:51, Higgins wrote:
    Well, all the interlocks appear to be working properly and I'm getting
    power in all the right places.
    I'm getting a 12v switching signal at the starter relay but the coil
    ground goes to the ECU and isn't actually at ground. I'm swaying towards
    a dodgy ECU or, perhaps more likely, our old friend Datatool.
    And I don't have the blanking plug :(
  9. Higgins
    I'm assuming you have checked that the ground connection from battery to
    frame/engine/ECU are okay?
    wessie, May 2, 2011
  10. Higgins
    Higgins Guest
    Well, yes, that's been the focus of the afternoon, around the area of
    the clocks, but there's really not much there to disturb.
    Now I'm going to pretend that I haven't done anything and start at the
    beginning.
    I may be some time.
  11. Higgins
    use a jump lead from the battery earth to intrument binnacle/frame/engine
    etc - I bet you disturbed an earth conection when you were faffing about
    wessie, May 2, 2011
  12. Higgins
    Thomas Guest
    You'd think.
    Unfortunately, motor gremlins know that's how you think and can be
    sadistic.
    Thomas, May 3, 2011
  13. Higgins
    Mark Olson Guest
    I'm with Champ on this one. I recently did some work on my FJR and
    despite all the evidence pointing toward the problem being related
    to something that I had worked on, I had already decided to fall in
    love with an alternative cause, and discarded any observations of
    symptoms that didn't agree with it. When I finally decided to check
    it out, even though I *knew* I was wasting my time, because I was so
    certain I hadn't disturbed it... yep that was it.
    BTW, without having a wiring diagram, the description of the problem
    points to a missing ground, nothing to do with the ECU or an alarm.
    I would expect if the starter relay coil terminal is getting 12V when
    the button is pressed, and does not have 12V on it when the button is
    not pressed, that the other coil terminal should be permanently
    grounded by a solid connection and not subject to the whims of an ECU
    or alarm, so I'd look for a loose or broken ground connection somewhere.
    Mark Olson, May 3, 2011
  14. Higgins
    Higgins Guest
    Logic would suggest so, yes, but the diagram suggests different and that
    the low side of the relay coil goes back to the ECU. Bearing in mind
    that the neutral switch line also goes to the ECU, it would suggest that
    the various interlocks are measured by the ECU rather than physically
    interrupting the volts to the starter.
    Anyway, got the fairing off now, so that I can properly see where I've
    been but domestic life stopped play last night.
    Higgins, May 3, 2011
  15. Not necessarily. It may be something as mundane as being to do with
    providing a common ground.
    Automotive electrical environments are inherently very noisy and
    electronics get very upset if there is too much noise. Making the ground
    as near equal as it can be may go some way to hiding issues that would
    arise if it weren't but tbh that is all a bit grasping at straws and stuff
    and probably fairly close to utter fucking bollox but you never know which
    is half the fun and finding the true answer is the other half if you are
    the sort of masochist who finds fettling vehicular wiring sexy.
    steve auvache, May 3, 2011
  16. Higgins
    DozynSleepy Guest
    I managed to replace a little black box near the clocks upside down on
    my CBR600RR when I took the fairing apart. Symptoms similar to yours.
    It was called the bank angle sensor (BAS) and was fitted to the fairing
    near the lights.
    DozynSleepy, May 3, 2011
  17. Tip switch?
    Fraser
    Fraser Johnston, May 4, 2011
  18. That would be my guess as well. It switches off the bike automatically
    if it finds itself upside down. Also called a tip switch. I had a
    faulty one on a crashed CBR1000RR and the thing sent me batty trying to
    diagnose it.
    Fraser
  19. Christ. Didn't know such things existed.
    The Older Gentleman, May 4, 2011
  20. Higgins
    Thomas Guest
    Dunno if it was the first, but the Honda ST1100 had one in '90. The
    early ones were prone to failure and eventually were recalled for an
    upgrade. The first time mine went out was in the fast lane of a
    freeway. Mindfuck it was. The instant fix was to turn the ignition off
    and back on, but it took a hell of a lot more than an instant to learn
    that.
    I think the way it works is a gravity switch that requires a certain
    amount of inertia to flip, so if you just lean the bike over in a turn
    it doesn't flip, but if you drop it, it will.
    Thomas, May 4, 2011
