Bugger, that's torn it...
Discussion in 'UK Motorcycles' started by Dan White, Jul 11, 2005.
  1. Dan White
    BGN Guest
    Does she normally ride in stilettos, and have you found that it the
    spikes ruin your exhaust?
    BGN, Jul 11, 2005
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, BGN
    Possibly. Unless you've ever left WC alone with your bike.
    and Ducati Race Engineer.
    Enfield 500 Curry House Racer "The Basmati Rice Burner",
    Wicked Uncle Nigel, Jul 11, 2005
  3. Dan White
    Ben Guest
    A solvent of some type should remove that. Try WD40 or a decent
    degreaser.
    Ben, Jul 11, 2005
  4. Ben wrote
    Meths, the Final Solution and as a bonus you can drink what you don't
    use.
    steve auvache, Jul 11, 2005
  5. Dan White
    BGN Guest
    WD40 doesn't move it. It's not wet anymore, it's dried in grime.
    <thinks> I could just put another piece of gaffertape over it to cover
    up the mark.
    BGN, Jul 11, 2005
  6. Dan White
    Ben Blaney Guest
    Every time I work away, I have a little period of promiscuity. My
    current situation is remarkably like Finland in 2000. Only more
    complicated.
    Ben Blaney, Jul 11, 2005
  7. Dan White
    darsyx Guest
    don't get caught.
    darsyx, Jul 11, 2005
  8. Dan White
    Ben Blaney Guest
    That's at the front of my mind. But also at the front of my mind is
    my desired outcome.
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, Ben Blaney
    "Kuwait mate? Fucking great. I shagged like a bunny, then I got
    completely stoned."
  10. Don't they cut things off out there for stuff like that?
    Grimly Curmudgeon, Jul 11, 2005
  11. And Susan is...?
  12. 4" wide farmers' silage tape is yer man.
  13. Dan White
    Ben Blaney Guest
    Only if you throw one up a local.
    Oops.
    Ben Blaney, Jul 12, 2005
  14. Dan White
    Dave Guest
    Unstuck.
    Dave, Jul 12, 2005
  15. Dan White
    Ben Guest
    Feeling rather let down.
    Ben, Jul 12, 2005
  16. I can see Blaney becoming the proud possessor of 5 camels - as a dowry.
    Grimly Curmudgeon, Jul 12, 2005
  17. I could do with a bit of that. Mine goes limp quite quickly these
    days. Doesn't even last half the night at the moment.
    Anyone got a swimming pool I can toss my air-mattress into, to
    try to find its leak?
    GSX600F, RG250WD, DT175MX "You Porsche. Me pass!" DoD #484 JKLO# 003, 005
    Dr Ivan D. Reid, Jul 21, 2005
  18. Dan White
    Sure, pop in the next time you're passing.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Jul 21, 2005
