Buffalo Terastation FOAK
Discussion in 'UK Motorcycles' started by Catman, Feb 1, 2011.
  1. Catman
    Catman Guest
    Looks like I've got a failing drive. It's a TS-HTGL/R5
    Anyone know what drive I should buy, and is it worth it, or is it just
    going to have another one fail soonish?
    TIA
    #www.cuore-sportivo.co.uk
    Catman, Feb 1, 2011
  2. I would imagine they chuck a variety of drives at it. You'll have to
    be a bit more specific on the HDD Make and Model Number.
    Brownz (via Gurgle Gruppez), Feb 1, 2011
  3. Catman
    Jim Guest
    Any SATA drive should do, I would buy a Seagate 7200.12 personally. You
    didn't say the capacity but you should be able to buy a bigger capacity and
    it'll just not use the extra, IYSWIM.
    I wouldn't start suspecting there's an underlying problem behind it unless
    you get another failure or if things seem to be running fairly hot.
    This might be helpful, I guess:
    http://www.bl0g.co.uk/buffalo-terastation-1tb-faulty-drive-failure-on-raid-5.html
    Jim, Feb 1, 2011
  4. Catman
    Catman Guest
    Mine's a pro.
    I managed to get to the interface (I'm in Bulgaria ATM)
    It's a WD unit, and can be had from ebuyer for the princely sum of £30.
    It also failed to boot with a 'Could not load kernel error'
    I wonder if it just threw its toys cos of a power failure. I'm tempted
    to buy a spare as a safeguard, though.
    Thanks
    Catman, Feb 1, 2011
  5. Catman
    Catman Guest
    Managed to get to the web interface and track it down.
    Cheers
    Catman, Feb 1, 2011
  6. Catman
    R C Nesbit Guest
    Catman spoke:
    I had exactly that after a power outage! - a telnet session and a default
    reset cured it, including removing the faulty drive issue.
    Sadly it lost everything on it in the re-build, but it has behaved
    faultlessly since then.
    Rob_P
    UKRM(at)indqualtec.co.uk
    uppercase(d) BBIWYMC#1 BOG#11? MRO#31 IBCDBBB#1(kotl)
    FJ1200, CCM130 Benelli Cabriolet (gone)
    Looks like Rab C Nesbit.
    R C Nesbit, Feb 1, 2011
  7. Catman
    Beav Guest
    Given the failure rate of HDD's these days, I'd buy two and raid 'em.
    Beav, Feb 1, 2011
  8. Catman
    Catman Guest
    That's hardly faultless :) Good job I have backup, will watch with
    interest.
    Catman, Feb 2, 2011
  9. Catman
    Catman Guest
    30 more today, after an unplanned power down.
    New drive en route from Ebuyer....
    Fix on Friday when I get back I guess.
    Catman, Feb 2, 2011
  10. Catman
    Catman Guest
    It's already RAID 5
    Catman, Feb 2, 2011
  11. Don't buy western digital. They are shit. Buy Hitachi.
    Fraser
    Fraser Johnston, Feb 3, 2011
  12. Catman
    Catman Guest
    Wonderful generalisation.
    Catman, Feb 3, 2011
  13. Catman
    boots Guest
    Tempts fate - one of my externals is WD, been running pretty much
    continuously for 4 years.
    boots, Feb 3, 2011
  14. Catman
    Yes quite! Utterly useless advice and therefor entirely appropriate.
    I had Hitachi in to see us last week. Largest company in Japan, well I
    didn't know that.
    Vertical Open MRI scanners you can walk a horse through, well I never!
    Hog, Feb 3, 2011
  15. Catman
    Catman Guest
    Well, this is UKRM ;)
    Generally I would by Hitachi, in fact, but I'm getting a WD to match all
    the rest
    Them racehorses are worth a bob or two innit.
    Catman, Feb 3, 2011
  16. Catman
    "Remove Stirrups and Bridle before scanning......."
    Hog, Feb 3, 2011
  17. Hitachi Global Storage Technologies (who are the part of the group
    that look after all things storage) are based at the Swamp in Havant -
    the old IBM building.
    Nice bunch of people - and although Frasers comment is a bit of a
    generalisation, I can back it up by saying their AFR rate is fantastic
    and class leading - based on using around 100,000 drives a year for
    the last few years.
    Brownz (via Gurgle Gruppez), Feb 3, 2011
  18. Catman
    Swamp in Havant? How do they fit a factory into my son's bedroom? Have they
    developed a tardis?
    wessie, Feb 3, 2011
  19. Yeah it was. But of the last 6 WDs I've bought 5 have failed within 12 months.
    A client of mine uses Hitachi drives for mobile security video recording on
    buses. They tested every drive you can name and only Hitachi passed. Since
    hearing that I've changed to Hitachi and had no problems. YMMV.
    Fraser
    Fraser Johnston, Feb 5, 2011
