Oh FOAK I have hit something quite hard in my GT. It's bent the wheel Can it possibly be un-buckled, and if so can anyone recommend someone? TIA -- Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 Tyger, Tyger Burning Bright (Remove rust to reply) 116 Giulietta 3.0l Sprint 1.7 GTV TS GT 3.2 V6 Triumph Sprint ST 1050: It's blue, see. www.cuore-sportivo.co.uk
**** off **** off -- Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 Tyger, Tyger Burning Bright (Remove rust to reply) 116 Giulietta 3.0l Sprint 1.7 GTV TS GT 3.2 V6 Triumph Sprint ST 1050: It's blue, see. www.cuore-sportivo.co.uk
I'm thinking that this may be what happens. Ebaying the other three will get a chunk of my cash back. Certainly the difference (it looks like) between buying one and buying a set. -- Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 Tyger, Tyger Burning Bright (Remove rust to reply) 116 Giulietta 3.0l Sprint 1.7 GTV TS GT 3.2 V6 Triumph Sprint ST 1050: It's blue, see. www.cuore-sportivo.co.uk
Clumsy ****. Alloy wheels have a habit of cracking if you try to straighten them so not a good idea unless you can find a specialist with the right kit. ISTR it needs lots of contolled heat to get them to the correct temperature for safe bending. The tyre sidewall is probably also fucked.
A wheel refurber can often do this. I had 2 straightened by A1 Wheels in Wolverhampton, but a google for wheel refueb should do it if you're nowhere near. As soeone has said, it's a specialist ting to avoid cracking them.
In communiqué <yWI%m.21176$>, Chris I was going to mention them, but having never used them can't recommend them. It would, however, require the OP to venture in to the 5th worst place in the world according to Lonely Planet. -- +-------------------------------------------------------------------+ | Pete Fisher at Home: | | Voxan Roadster Yamaha WR250Z/Supermoto "Old Gimmer's Hillclimber" | | Gilera GFR * 2 Moto Morini 2C/375 Morini 350 "Forgotten Error" | +-------------------------------------------------------------------+
Indeed, and since I have no spare, it's not going to happen. There aren't any around here that have anything like the presence I'd like to trust. Plus I'm finding it hard to believe I'm going to save enough to make the extra hassle worth while. -- Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 Tyger, Tyger Burning Bright (Remove rust to reply) 116 Giulietta 3.0l Sprint 1.7 GTV TS GT 3.2 V6 Triumph Sprint ST 1050: It's blue, see. www.cuore-sportivo.co.uk
Assuming you're going to buy identical wheels: Ebay two of the three good ones as a good pair. Put the damaged one up at £1 start, no reserve. If it sells, great, if not, junk it. Keep the 3rd good one as a spare.
Sensible idea, thanks Except it (probably) won't match the others. If I can get just a single one, then I probably will. Depends on the cost really. -- Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 Tyger, Tyger Burning Bright (Remove rust to reply) 116 Giulietta 3.0l Sprint 1.7 GTV TS GT 3.2 V6 Triumph Sprint ST 1050: It's blue, see. www.cuore-sportivo.co.uk
I did say 'assuming you're going to but identical wheels'. Good luck with that. I suspect you'll find the amount of people looking for a single wheel pushes the prices up quite a bit.
A1 were excellent last time I used them, and as they've been there for years, I assume they're still OK. Wolves really isn't that bad at all. There's plenty worse.
Yeah, I wondered if that's what you meant. Well, I was aiming for new, but yes, I suspect it may be poor value. -- Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 Tyger, Tyger Burning Bright (Remove rust to reply) 116 Giulietta 3.0l Sprint 1.7 GTV TS GT 3.2 V6 Triumph Sprint ST 1050: It's blue, see. www.cuore-sportivo.co.uk
141 miles. That would be about £70 in fuel plus my time. Can't see it happening. -- Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 Tyger, Tyger Burning Bright (Remove rust to reply) 116 Giulietta 3.0l Sprint 1.7 GTV TS GT 3.2 V6 Triumph Sprint ST 1050: It's blue, see. www.cuore-sportivo.co.uk
Yes, there are none that I can see on ebay. Jap breaker? For an Alfa? I would try breakers but they were all shut. Bastards -- Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 Tyger, Tyger Burning Bright (Remove rust to reply) 116 Giulietta 3.0l Sprint 1.7 GTV TS GT 3.2 V6 Triumph Sprint ST 1050: It's blue, see. www.cuore-sportivo.co.uk
(The Older Gentleman) gurgled happily, sounding much like they were saying: Alternatively, accept that if you've twatted one, you'll twat another one. Just buy a set of four, and keep three as spares for next time, the time after, and the time after that...
