Bu**ocks
Discussion in 'UK Motorcycles' started by Spete, Feb 24, 2005.
  1. Spete
    Spete Guest
    Dropped the bike this morning. Just as I was reversing the bike, one of
    the courtyard doors blew shut at some speed. Couldn't keep the bike up
    anymore and gently let it rest against the bike trailer.
    Damage: small dent in the tank as far as I can see. What worries me
    though, is that initially, setting off, the bike felt fine, but after a
    few miles it started to run like a bag of spanners. It's lost all it's
    punch and sounds like it's running waaay too rich. A quick inspection
    didn't turn up any major damage. It does run, idle is at about 1000
    revs, so all should be fine...no? No!
    Any ideas?
    Spete
    Spete, Feb 24, 2005
  2. Spete
    Carb icing in this fine weather we're having at the moment?
    Muck, Feb 24, 2005
  3. Buttocks?
    You are odd, you Dutchies.
    Wicked Uncle Nigel, Feb 24, 2005
  4. Spete
    NickyD Guest
    Bu**ocks? Well, probabay buttocks, maybe burdocks, bullocks seems to sound
    right but is such a rarely used word.
    NickyD, Feb 24, 2005
  5. Spete
    Spete Guest
    Bu**ocks? Well, probabay buttocks, maybe burdocks, >bullocks seems to
    sound
    You seem to forget I'm a furri....fori.... not from this cuntry...
    Spete
    Spete, Feb 24, 2005
  6. Spete
    you obviously don't listen to The Archers.
    darsy, Feb 24, 2005
  7. Spete
    Paul - xxx Guest
    Spete composed the following;:
    Dunno what bike or carb, but could the choke lever or actuator have been
    bent and caused it to stay open/closed?
    Paul - xxx, Feb 24, 2005
  8. Spete
    Spete Guest
    been
    It's a Firestorm amd probably not. I dropped the bike on the righthand
    side and the lever is on the left. It may just be that some crud got
    released or something got flooded, but the latter doesn't seem logical
    as rode it for a few miles...
    Here's hoping that the problem will have gone away this afternoon....
    Spete
    Spete, Feb 24, 2005
  9. Yes
    You are a clumsy cloggy ****.
    oldbloke at work, Feb 24, 2005
  10. Spete
    gazzafield Guest
    These problems don't go away. They sometimes hide, then come back and
    bite you.
    gazzafield, Feb 24, 2005
  11. Spete
    It may be completely unrelated to the falling over. Water in the fuel
    or, as you say, a bit of crud restricting the float needle.
    sweller, Feb 24, 2005
  12. Spete
    Sean Guest
    Possibly carb icing. I had great fun riding the ER to work this morning.
    Carbs iced up, giving me a single cylinder 8 stroke if the sound was
    anything to go by.
    Nowt to worry about if when the temperature drops below 0c or gets above
    5c[1] the problem goes away.
    [1] Seems to be the temp range that causes it on the ER and GTRat when much
    precipitation abounds.
    Sean, Feb 24, 2005
  13. Spete
    Cab Guest
    You let Timo touch the bike?
    Cab, Feb 25, 2005
  14. Spete
    Bob Mc Guest
    bloody -10.5 deg C this morning!
    Sunny though.
    Bob Mc, Feb 25, 2005
  15. Spete
    If you're in the UK, that's bloody cold.
    Muck, Feb 25, 2005
  16. Spete
    Cab Guest
    It would be, wouldn't it? If he's in Switzerland, I'd say that may be
    average for certain places...
    Cab, Feb 25, 2005
  17. Spete
    I can never remember where people are located... it was a comment to
    cover that really.
    Muck, Feb 25, 2005
  18. Spete
    Bob Mc Guest
    Swizzerland, but it's been around 0 to -2 for the last couple of days
    and I felt the drop, deeply!
    There's one place here that is always about 15° colder than the rest of the
    country in winter.
    -30° is apparently common!
    La Brévine - if anyone's interested.
  19. Spete
    There's a chance that I may be going to live in Zurich, maybe. It's more
    likely that I'll be living in Brighton and going to Uni though.
    Muck, Feb 25, 2005
  20. Spete
    Bob Mc Guest
    Welcome!
    There are some lovely rides[1] around here.
    And of course other things.
    What influences the decision?
    [1] for bikes, as well
Similar Threads
Loading...
