Brownz killed my media centre PC!
Discussion in 'UK Motorcycles' started by Krusty, Apr 25, 2009.
  1. Krusty
    OK not literally, but it refuses to come back to life after plugging in
    the lovely hard disk I relieved him of. I suspect the AGP slot, as
    sometimes it'll do one long beep then four short ones & shut itself
    down again, but if I re-seat the graphics card (or stick another one
    in), it'll occasionally get to the 'hit del to enter setup' screen - &
    then just hang.
    I've tried unplugging everything, & resetting the bios, but no cigar.
    Is it likely to be anything other than the motherboard? It doesn't do
    any beeping during booting when it gets as far as the 'hit del...'
    screen - just the one long four short when it won't even get that far.
    Assuming it is the motherboard (an Abit AV8), what are my chances of
    getting another one that'll take all me bits - so socket 939 ATX,
    DDR400, AGP, & optical out?
    Krusty
    '03 Tiger 955i
    '02 MV Senna (for sale) '96 Tiger (for sale)
    '79 Fantic Hiro 250 (for sale) '81 Corvette (for sale)
  2. Take it you've tried re-seating the memory?
    Mungo \Two Sheds\ Toadfoot, Apr 25, 2009
  3. Krusty
    Tosspot Guest
    Of all the chicken sacrificing rituals, it always amazes me this works 3
    out of 4 times. Old Sun boxes in particular, they seem to spend 5 years
    trying to shit memory cards before finally expelling them.
    On another note, corrected typo on that post was exspelling. If that's
    not a word I want to know why not!
    Tosspot, Apr 25, 2009
  4. Krusty
    I have - re-seated, switched slots, left some out etc.
    Krusty
    '03 Tiger 955i
  5. Have you tried clearing the cmos ?
    Find CCMOS1 jumper, disconnect AC power cable from PSU, move jumper from pin
    1-2 to pin 2-3, pop out the bios battery, hit your on/off switch a few times
    to drain all power from the board, pop the battery back in, move the jumper
    back to pins 1-2, re-insert power.
    Brownz \(Mobile\), Apr 25, 2009
  6. Krusty
    I have, but...
    ....not to that extent. I just unplugged the power & stuck the jumper on
    2-3 for a couple of minutes, then moved it back. It definitely did
    something as I now get the full screen logo, which I had disabled
    before.
    Krusty
    '03 Tiger 955i
  7. Krusty
    T i m Guest
    Hmm, did you say you have pulled it back to *just* the system board
    (inc video card if not also onboard) especially no HDD cables plugged
    in etc?
    If it finishes the POST but then hangs it sounds like it's seeing a
    bootable device but can't get any sense from it (or you would get a
    'Missing operating system' type message). The fact that it's beeping
    an error suggests it's not dead_dead but is obviously unhappy with
    something (good news actually).
    If you press Del at the prompt does it ender the CMOS setup screen?
    Is there a CD/DVD drive in there, do you have any bootable media, Live
    Linux or XP CD?
    Bit late now but did you take precautions?
    T i m
    T i m, Apr 25, 2009
  8. 10:1 that he was going for 'the morning after' pill.
    doetnietcomputeren, Apr 25, 2009
  9. Krusty
    T i m Guest
    Ah, as with not taking static precautions not can all be a bit risky.
    T i m
    p.s. Not saying he didn't do either or both of course. ;-)
    T i m, Apr 25, 2009
  10. Krusty
    No, it totally locked after that screen appeared. It's doing something
    different now - bringing up the full screen logo as before for a few
    seconds, then showing the usual BIOS boot screen & saying 'CMOS
    checksum error - defaults loaded' under the list of drives. At the
    bottom of the screen it says 'Press F1 to continue, DEL to enter SETUP'
    but won't do anything else no matter what I hit.
    I've tried with & without an XP CD in the drive, but it doesn't get as
    far as checking if there's anything in there.
    Yes, I kept a pillow between my knees at all times.
    Krusty
    '03 Tiger 955i
  11. Krusty
    T i m Guest
    On 25 Apr 2009 22:33:21 GMT, "Krusty" <>
    wrote:
    Do you have a USB keyboard in there at the mo? If legacy USB support
    was or has now been disabled in the BIOS then it might simply not
    seeing your key presses.
    If it's not USB (but PS2) or only has support for USB kbd / mouse and
    you are hitting the prompted keys quickly enough (it's not a reaction
    test as such though) then it's not sounding good.
    Ok, so it's either not getting to that stage because the CD drive
    isn't in the list of boot devices or it is actually busted.Is this
    with *just* the CD drive connected to the system board and assuming
    it's (ideally) a Master device (rather than cable select). Have you
    tried the CD drive on the other connector on the system board? (Pri /
    Sec)
    Ah, you should have been fine then.
    T i m
    T i m, Apr 25, 2009
  12. Krusty
    TMack Guest
    AFAIK the AV8 uses an AMI bios. "Four short" beep sequence indicates
    memory problem. It could be a bad memory stick. Try another, or if you have
    two then try each one separately in each different slot. It could also be
    problems with the cpu (memory controller is integrated into cpu) or
    motherboard circuitry.
    If it is the motherboard you can still but new (but expensive) e.g.
    http://www.ebuyer.com/product/139612 However, there are used examples of
    Socket 939 motherboards on ebay for substantially less.
    TMack, Apr 26, 2009
  13. Krusty
    I've been caught out by that one before, so I plugged a PS2
    keyboard/mouse in before starting.
    It's sort of come back to life now, after leaving it to rest overnight.
    Plugged everything back in this morning & it booted up fine. Rebooted
    it just to check I wasn't imagining it, & it went back to doing the
    beeping again. Cleared the BIOS again, removed two of the DIMMs, & it
    booted up. Rebooted several times, & it seems fine. So I'm leaving
    those two DIMMs out for now.
    Then I unplugged the old drives & hooked up the Brownz drive, & the
    BIOS refuses to see it. It's spinning up OK, so I suspect the problem
    is the drive's SATAII but the mainboard only supports SATAI (which is
    what the other drives are). I believe the SATAII drive should be able
    to clock itself down, so I guess it's just an incompatibility. I have
    got another PC with SATAII so I'll try the drive in there when I can be
    arsed.
    Installing XP now (I'm fed up of NVidia's shitty Vista drivers -
    particularly their inability to remember the flicker filter setting),
    so fingers crossed.
    Krusty
    '03 Tiger 955i
    Krusty, Apr 26, 2009
  14. Krusty
    T i m Guest
    Looks like TMack was spot on then. ;-)
    Have you checked for a BIOS upgrade?
    http://tinyurl.com/ddwu8b (the latest being 2006/05/07) ;-(
    Not sure you can get a PCI to SATAII card (you can easily get PCIe to
    S2 but don't think you have PCIe slots on there).
    Yep, XP is for the best. Anyway, glad it was only (hopefully) some
    iffy RAM rather than anything more expensive or messy.
    T i m
    T i m, Apr 26, 2009
  15. Krusty
    TMack Guest
    What version of the A8V have you got and what is the new hard disk?
    TMack, Apr 26, 2009
  16. Ahhh .... your board has a VT8237 Southbridge with SATA I (150) controller,
    and that drive is SATA II (300). Doh !
    Brownz \(Mobile\), Apr 26, 2009
  17. Krusty
    Not sure what revision it is, but it's an earlyish non-3rd eye one. The
    drive's an Hitachi Ultrastar 500GB, 1997 vintage.
    Krusty
    '03 Tiger 955i
  18. Krusty
    Maybe, but I had those two DIMMs out last night too & it didn't make a
    difference. I still reckon there's something dodgy on the mainboard - a
    dodgy connection that's affected by the flexing of pushing cards in &
    out.
    That's the one I've got.
    Hasn't got any.
    I can leave the new drive in t'other PC if it works, & just stream
    recordings to/from there, so not a major problem.
    Krusty
    '03 Tiger 955i
  19. Krusty
    TMack Guest
    Your motherboard can't recognise SATAII. Hitachi disks don't have a jumper
    to change from SATAII to SATA1 - it has to be done in firmware. You need to
    find a SATAII computer that can recognise the hard disk and which has a
    floppy drive, then use Hitachi's "Feature Tool" (runs from a bootable
    floppy) to change it from SATAII (3.0Gb/s) to SATAI (1.5Gb/s). With a bit
    of luck your bios will then "see" the disk and you will be in business.
    TMack, Apr 26, 2009
  20. Krusty
    Crikey, Hitachi were a bit ahead of the game, weren't they?!
    Champ, Apr 26, 2009
