Broken thundercat... advice sought (where to get an engine)
Discussion in 'UK Motorcycles' started by Euain, Jul 7, 2004.
  1. Euain
    Euain Guest
    Hi all,
    The Thundercat is not well at the moment and I am trying to decide what
    to do with it. We were on a nice European tour - almost on the way home
    - when it started making a VERY nasty noise. That's where the bike's
    trip ended[1].
    Having a closer look back at home, it seems pretty terminal for the
    engine. The problem was a broken crankshaft (picures here ->
    http://homepages.nildram.co.uk/~euain/bike/ )
    So my questions are - is a bike without an engine worth anything? 1999
    Thundercat - excellent condition apart from a slightly rough engine
    (ahem).. (30,000 miles - new head bearings, Ohlins rear shock about 7000
    miles ago...)
    I doubt it - so main question - anyone recommend a good breakers?
    (Anyone got a spare Thundercat engine ?). I am in Basingstoke and would
    ideally like to pick up the engine rather than have someone deliver one
    I hadn't seen (but I accept this might not be possible).
    (I am assuming that I can just send the new engine numbers to the DVLA
    to get a new V5? Anyone done this before?)
    Assuming I get a complete engine - anyone need any spare parts for a
    Thundercat engine - the covers are fine (well uncrashed - winter has got
    to the paint a bit on some of them), gearbox and top end in excellent
    condition (fully synthetic oil since 4000 mile service).
    Hmm... I was meant to be saving money this summer.. oh well..
    Euain / Fred
    [1] - Carole Nash European recovery is very useful.
    Euain, Jul 7, 2004
  2. Euain
    Ginge Guest
    It won't, but a Fazer one will.. Re-fit the original 'cat cams and
    carbs and it's full power again.
    Ginge, Jul 7, 2004
  3. Wow! That is *well* fucked. I wonder what caused it?
    Well, in answer to your questions:
    The bike is worth money as a breaker - plastics, clocks, breaks, forks,
    etc will all sell on Ebay.
    As will the top end and everything else, actually. Erm, except the
    bottom end ;-))
    As someone else said, Fazer (early model, not the new R6-based one)
    engines will fit. But financially this makes less sense than breaking or
    fitting a replacement Tcat engine.
    What's a Fazer-engined Tcat worth? Answer: notalot.
    As for the engine numbers - yes, just change the logbook (there's a spce
    for engine changes) and post it off.
    My advice - if you can find a good Tcat engine for under 500 quid, buy
    it. Otherwise, break it.
    The Older Gentleman, Jul 7, 2004
  4. Euain
    entwisi Guest
    Try on here http://groups.msn.com/yamahathundercats
    entwisi, Jul 8, 2004
  5. Euain
    Euain Guest
    That's encouraging... it gives me another option..
    Thanks. That's pretty much what I was thinking. Sounds daft but I'd feel
    bad breaking the bike - you get kind of attached after 30,000 miles.
    A couple of calls to breakers got responses - "we've just sold our last
    one for 350" and "we have one for 600 quid, 4000 miles, still in the
    bike". 600 is more than I was planning to spend but at least there are
    engines out there.
    Still- there is still SWMBO's CB400F (still going strong) when all else
    goes pear-shaped.. =)
    Euain
    Euain, Jul 9, 2004
  6. Euain
    Euain Guest
    I'm hoping to get a 'cat engine. Apart from anything else, the Fazer is
    painted a different colour and no-one's really going to want a
    Thundercat/Fazer hybrid.
    I'm kind of hoping that a lower mileage engine might be a selling point
    with the bike - the rest of the bikes in very good condition.
    Euain
    Euain, Jul 9, 2004
