Broken spoke. Arse
Discussion in 'Classic Motorbikes' started by The Older Gentleman, Aug 11, 2007.
  1. In th 400 Four's rear wheel. Wonder when that happened, then, because it
    wasn't there last time I cleaned the rear wheel, some time before
    Chimay.
    Last time I had a spoke break in a rear wheel, it was on an SOHC Honda
    CB750, and the spoke disappeared into the wheel, ripping the tube open
    and deflating the tyre in ---> <--- that short a time.
    Shows the importance of cleaning SOBs, or any bikes, I suppose. Hello,
    Mr. Silver, a new spoke please. And a spare, too.
  2. The Older Gentleman
    On Sat, 11 Aug 2007 15:55:51 +0100,
    Why not go the whole hog and get a complete set of stainless ones?
    _______
    Ace, Aug 11, 2007
  3. The Older Gentleman
    crn Guest
    Probably because stainless spokes are more brittle and thus more likely
    to break in the usual place at the sharp bent where they pass through the hub.
    Nice and shiny for a show queen but not a lot of good in practice on a
    bike that will be ridden.
    crn, Aug 11, 2007
  4. The Older Gentleman
    Funny how they manage OK on mountain bikes.
    My new MTB has stainless spokes, but they're black. Oh, and flat,
    which is rather, err, odd. But it means there's no bending on the
    crossover.
    _______
    Ace, Aug 11, 2007
  5. The Older Gentleman
    My YZ250 has aftermarket SS spokes in the rear wheel. This has to
    survive the beating an MX bike has to put up with, and with my weight
    on it.
    I'll agree that SS alloys can be more brittle than other steels but
    it's simply a matter of choosing the right alloy and designing the
    component to suit it.
    Pip Luscher, Aug 11, 2007
  6. That and putting in a single spoke is rather easier and cheaper than
    sending the wheel off for a complete re-spoke. And it was rebuilt not
    too long ago anyway, so the spokes all look nice and clean.
  7. The Older Gentleman
    sending the wheel off for a complete re-spoke.[/QUOTE]
    Do it yourself man! It really isn't difficult you know.
    Ah well, that's fair enough, I suppose.
    _______
    Ace, Aug 11, 2007
  8. The Older Gentleman
    Bollocks - it's all about getting the correct SS.
    I have a bike that is far from a show queen, gets ridden and has 25 y/o
    Boranni rimmed stainless spoked wheels with no problems.
    I suspect from this and some of your other posts you actually know very
    little.
    sweller, Aug 11, 2007
  9. The Older Gentleman
    crn Guest
    WRONG - the rims are irrelevant.
    The problem is at the sharp bend where the spoke enters the hub.
    The solution is to have a radiused hole matching the radius of the bend
    in the spoke rather than the sharp corner of a drilled hole.
    This is expensive, so the best that happens in practice is a mild chamfer.
    This corner produces a very high local stress in the spoke which is best
    tolerated by a mild steel, any stainless formulation will always be
    more liable to failure here than a mild steel, and the stainless alloys
    which would be the least bad also happen to be the more expensive alloys.
    Given that the specific application is suffering fractures in mild steel
    spokes it is clear that the use of stainless can only make matters worse
    unless the hub holes are reworked and the bend in the spoke is made under
    very carefully treated processes. Annealing the bend to relieve the stress
    will also tend to discolour the finish of a stainless item.
    Sex munce ago i cuddunt spill injuneer now i are wun.
    Back to engineering college for you, lad.
    When you have finished your HND (or whatever they call it now) your next
    task is to discover how to be sure that a spoke purchased for Johnny
    randon retailer who buys from the cheapest supplier can be guaranteed
    to meet the specification and contain the correct alloy.
    OTOH maybe the original failure was caused by a latent defect in the
    original spoke and a simple replacement will be a satisfactory
    permanent repair. Examination of the failed spoke under an SEM would
    settle this question.
    crn, Aug 12, 2007
  10. There is a rather worrying gash running across the tyre tread as well,
    which suggests that I hit something hard and knobble, rather firmly.
    Life's too short, etc....
    The Older Gentleman, Aug 12, 2007
  11. So I understand. But it's one of those things where you really *do* need
    SWK looking over your shoulder, the first time. Classic Bike sent their
    writer Sally off to learn how to rebuild a wheel, and she produced a
    creditable effort on her first try, but only under the aforementioned
    conditions.
  12. The Older Gentleman
    Get a SObicycle wheel and practice.
    http://www.sheldonbrown.com/wheelbuild.html
    platypus, Aug 12, 2007
  13. The Older Gentleman
    Naah, piece of piss mate.
    I used sheldon's instructions the first time I built a (push-)bike
    wheel, with no problems whatsoever. It's still running true to this
    day.
    _______
    Ace, Aug 12, 2007
  14. The Older Gentleman
    conditions.[/QUOTE]
    I did my YZ myself simply by replacing one spoke at a time, working
    across the wheel the way one would tighten nuts. To be fair, it's also
    slightly less critical if an offroad wheel is slightly off true. Mine
    wasn't noticeably out of true at the end.
    Pip Luscher, Aug 12, 2007
  15. The Older Gentleman
    which suggests that I hit something hard and knobble, rather firmly.[/QUOTE]
    Just a thought: be sure that no other spokes are loose: that could
    have caused the breakage too.
  16. Just a thought: be sure that no other spokes are loose: that could
    have caused the breakage too.[/QUOTE]
    Checked 'em, and they're all fine.
  17. We've been building pushbike wheels with stainless spokes for years and
    AFAIK none have ever broken. Use the right material and they don't, and I'd
    expect spoke-sellers to spec the right material.
    Only spokes I've ever had break are old non-stainless ones.
    Austin Shackles, Aug 13, 2007
  18. How do you know the spokes are mild steel? I'd expect high-tensile of some
    kind. And to say "stainless" as if that's one thing, when there are many
    stainless alloys, leas me to agree with sweller, you don't know much.
