Broken speedo & tacho needles
Discussion in 'Australian Motorcycles' started by Annie, Sep 5, 2005.
  1. Annie
    Annie Guest
    I just stuffed my '92 DR650 into the dirt (front end washed out - must
    remember to turn after front wheel on ground, not before!).
    The damage is restricted to a few more scratches on the plastics but both
    the speedo & tacho needles have snapped off!
    Does anyone know if I can replace just them or do I have to get a whole
    instrument cluster?
    Thanks,
    Deano
    Annie, Sep 5, 2005
  2. In terms of ordering from Suzuki, you'll only get the unit as a whole,
    you wont be able to buy just the needles. You could possibly source
    one from a wreckers, even it if wasnt working just to butcher it for
    the needles but the simplest and probably cheapset solution will be to
    buy a bicycle computer, program it up and use it for your speedo. I
    dont think theres much you can do about the tacho, I think there's some
    kind of overgrown bicycle computer that might do the whole show for you
    but I'm not sure.
    lemmiwinks.au, Sep 5, 2005
  3. Annie
    john doe Guest
    open it up and glue some toothpicks in place... bit of flouro paint
    won't go astray either.
    john doe, Sep 5, 2005
  4. Annie
    Kevin(Bluey) Guest
    Look for an instrument repair/calibration company (Tenix comes to mind)
    that repairs industrial guages etc they should be able to replace the
    needles and recalibrate the tacho and the speedo.
    Probably won't need to take out a second mortgage like you would to buy
    the instruments from Suzuki.
    Kevin(Bluey), Sep 5, 2005
  5. What about trying an instument repairer?
    Al
    Alan Pennykid, Sep 5, 2005
  6. Annie
    jlittler Guest
    jlittler, Sep 7, 2005
  7. Bluey said....
    Is this the same mob that maintains speed cameras?
    Martin Taylor, Sep 7, 2005
  8. Annie
    diode Guest
    When you say, broke the needles off,
    Does that mean the little netal shafts/posts the needles sat on were snapped
    off ?
    or,
    The plastic needles popped off of those little metal shafts and may be re
    attached ?
    Could be as easy as that ?
    Ben
    diode, Sep 8, 2005
  9. Annie
    Annie Guest
    Needles snapped off just past the small disc that pops onto the shaft - can
    still see the bottom fifth of the needle on that disc and sort of line it up
    with the markings to get a general idea.
    Looks like glue initially, them try the instrument mobs like VDO.
    Thanks for the replies.
    Deano
    Annie, Sep 8, 2005
  10. Annie
    Kevin(Bluey) Guest
    Kevin(Bluey), Sep 10, 2005
  11. Annie
    Kevin(Bluey) Guest
    Dont know about speed cameras ,maybe they do .
    They are a large company with different divisions .
  12. Annie
    jlittler Guest
    If you say so, but it's certainly not a capability listed on their
    website,
    http://www.tenix.com.au/Main.asp?ID=20
    Divisions include defence, anzac shipbuilding, aviation etc no
    instrument division (unless it comes under aviation, but if so it's not
    specifically listed)
    Products include all sorts of military and aviation paraphenalia.
    http://www.tenix.com.au/Products.asp
    You sure it was Tenix ?
    JL
    (unless of course you're in the armed forces and you got a favour done
    by someone)
    jlittler, Sep 10, 2005
  13. Annie
    GB Guest
    Tenix is Transfield. Wog company, can't work there unless
    you're a wog or your brother is a wog. Boats, submarines,
    tunnels, roads, bridges, shit like that. When someone figures
    out a way to make a finely calibrated instrument when the
    smallest tool in your toolbox is a five pound hammer, then
    Tenix will have a go at it. Up until then, I have me doubts.
    GB
    GB, Sep 12, 2005
