I lurk and occasinally post in 'another place. Someone there has asked Bridgestone their opinions on using an 010 front with an 020 rear and they replied with this : "Dont do it, we do not approve the mixing of patterns on the YZF600R. There are a lot of urban myths about the mixing of tyres and unfortunately it is nearly all myth. There is logic behind why people suggest it though, as a front tyre does need a specific compound (softer) to offer the grip needed when cornering. When we develop a new pattern we take this into account so the best fitment you can have if you have a BT020 on the rear is the matching BT020 on the front as they are designed to work together (front and rear specific). The BT020 will offer more than enough grip for road riding, in fact in the correct conditions you'll run out of road before you run out of grip. If your bike is used only on the road then you need to get the following: Front: 120/60 ZR17 BT020 (running 36 PSI) Rear: 160/60 ZR17 BT020NT (U) (running 42 PSI) The BT020 will have ample grip for your Thundercat, if you feel you want something even grippier then opt for a set of the brand new BT014's. You did the right thing by asking us, its always best to check as the mixing of patterns can cause stability problems on certain bikes and the difference with grip would almost certainly be physiological. If you need any further advice please let me know. Best Regards Tom Davey Bridgestone UK Ltd" So, there you have it. HTH
