Bridgestone 010's V 020's
Discussion in 'UK Motorcycles' started by Rocket, Oct 14, 2003.
  1. Rocket
    Rocket Guest
    Can anybody who has tried both on the same bike comment on just how much
    less wet or dry grip an 020 has compared to an 010? Decking the pegs (and
    engine bars) on 010's is no problem.
    I got a Bandit6 and am only getting 5K from a rear and 9K from a front 010
    so I am seriously considering changing to 020's when they wear out again.
  2. Rocket
    Ginge Guest
    I can't answer the question of 020 vs 010, other than I didn't find
    020's all that reassuring on my ZRX once they started to wear... and
    realised 010's would last about 3000 miles to a rear.
    You may want to consider Avon AV45/46ST's they wear like 020's but grip
    almost as well as 010's... I've done about 3500 miles on them so far and
    the rear is still hardly worn, but just seems to improve in grippyness.
    They're great in the wet too.
    Ginge, Oct 14, 2003
  3. In uk.rec.motorcycles, Rocket said:
    Never had 010s but got a shade under 10,000 miles out of a rear 020 on a
    Bandit 6, ask Lozzo ;-)
    Whinging Courier, Oct 14, 2003
  4. In uk.rec.motorcycles, Whinging Courier said:
    Oh shit! Make that an Avon Azaro 3 then. About 8,000 out of an 020 IIRC.
  5. Rocket
    Colin Irvine Guest
    I've currently got 020s, and the last-but-one tyres were 56s (near
    enough 010s). I can/could deck the pegs on both. I guess back to back
    there'd be a difference, but on the road I don't think the 010s are
    worth it - unless, of course, you're a riding god.
    Colin Irvine, Oct 14, 2003
  6. Rocket
    Ginge wibbled incoherently...
    The Ginge speaks the troof. Fucking excellent choice of tyres IMHO.
    Lozzo
    ZZR1100D, GPZ500S, CBCBCB750RSRSRS
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14, KoBV#3.
    www.mjkleathers.com
    Lozzo, Oct 14, 2003
  7. Rocket
    Whinging Courier wibbled incoherently...
    But it was as bald as ****, and it was an Azaro3 AV45/46 ST combo.
    Lozzo
    www.mjkleathers.com
    Lozzo, Oct 14, 2003
  8. Rocket wrote
    Depends dunnit.
    Shows poor judgement if you ask me.
    Where do you want the grip? Presumably on the bit that has worn out as
    that is the one you are using most. So how have the tyres worn?
    steve auvache, Oct 14, 2003
  9. Rocket
    ozmick Guest
    FWIW i changed to the new 020s (020NTs) a few weeks back on the cbr6
    after about 4 or so sets of 010s. [2]
    New tyres always feel better than old shagged tyres ime, so it's a bit
    hard to think back to the new 010s to compare.
    The 020s seem to take a longer to warm up, and initially i did not
    like them, specifically for that reason. For the first half a mile or
    so under heavy braking on uneven surfaces would "ch-ch-chirp" which
    just wouldn't happen on the 010s. I'm tempted to drop them a psi or
    two to see if that helps them warm up.
    Once warm tho they're fine, perhaps they don't quite feel as planted
    leant over, but when you go from shagged 010s to new 020s that's not
    going to help in the comparison.
    Only had one short spell in the wet so i can't say - which was the day
    i put them on[1].
    So in summary when cold - worse than expected - when warm - pretty
    good especially if they last 7K on the rear. (4-5 K on the 010s).
    hth.
    [2] After putting some Diablos[3] on da Mille and some Pirellis on the
    Fiat i decided to try to cut down on the rubber habit.
    [1] new tyres = rain.
    [3] which are very nice.
    ozmick, Oct 14, 2003
  10. Rocket
    SteveH Guest
    I had 010s and 020s on my TRX850.
    I'm not a quick rider, but could get right to the edge of a rear 010,
    and didn't really notice much difference with an 020.
    It's also worth trying an 010 front with an 020 rear. Utterly horrible
    on a TRX850, but this combination seems to work well on most bikes.
    SteveH, Oct 15, 2003
  11. Rocket
    Nigel Eaton Guest
    Using the patented Mavis Bacon "Hunt&Peck" Technique, Rocket
    <stands up>
    I am a ZZR11 rider and I seriously cannot tell the difference between
    010s and 020s when riding the bike.
    There. I've said it.
    <sits down>
    Nigel Eaton, Oct 15, 2003
  12. Rocket
    Nigel Eaton wibbled incoherently...
    Your bike is faster when using 010s, mainly because your wallet is lots
    lighter.
    Lozzo
    www.mjkleathers.com
    Lozzo, Oct 15, 2003
  13. Rocket
    Nigel Eaton Guest
    Using the patented Mavis Bacon "Hunt&Peck" Technique, Lozzo
    <G>
    Ah. That's all right then.
  14. Rocket
    Tim Gray Guest
    DRY:
    I've tried all three on me beemer R1100RS. The main difference between them
    is mileage and wet weather performance. All of them are fine in the dry, you
    can deck away. The 010's are better from go and more stable, but they all
    warm up quickly. The 010 rear lasted just over 4000 miles, though it should
    have been changed around 3500. The 020 if I remember, could maybe have done
    a bit more, but was changed at around 5500 miles. The Avon 46 is still going
    at about 9000. I reckon with the 010's you could squeeze two rears to a
    front. I was always tempted to try the 010 front and 020 rear combo that
    Bridgestone don't recommend but everyone else does. I guess the main reason
    I didn't was I didn't want to give anyone an easy cop out if I was involved
    in a prang. The rumour is, the AV46 rear has a unusually deep trear tread to
    start with (it did look deep), might explain the previous posters comment
    about grip improvement with mileage, although I never noticed it changing.
    WET:
    The wet separates them massively in my book. The 010 still works like glue,
    it's amazing how much grip you still have front and rear. The 020 rear is
    okay, but the front *always* unnerved me, especially if it was chilly as
    well. It also wore a surprising amount, it was not far of the pace of the
    rear. I've spoken to others about the front grip of the 020, no-one has
    really said the same - so maybe it was a dodgy batch,but the front always
    'moved', and always threatened to go places different to me. I have to
    admit, I didn't mess about with pressures that much, just set it to book.
    The AV45/46, the front is way more confidence inspiring than the 020, but
    the back is like it's on marbles. (Mind you, I'd rather the back slid than
    the front). In the wet it's easy, even on the BM with it's 18 inch rear, to
    spin the rear avon up when pulling out and oomphing it to overtake at around
    50/60mph...! I've had the thing moving sideways on a dual carriageway at
    70mph [1] whilst *over*[1]taking and aiming for a diminishing gap. That
    said, it's predictable, the front is stable, and you get used to it - but
    you do have to remember it does it, else you'll be in the hedge. The BM's
    throttle smoothness isn't all it could be for controlling slides... the
    injection just sorta does nothing then kicks in. But that mileage figure,
    dang handy if you do the miles, not sure I'd like to run them through a
    Winter though... I have to change soon and I'm trying to decide, 020 and see
    if I had a dodgy front, or AV45/46 and know the back will slide, oh yes. The
    010's are great and would be handy in the depths of Winter, but they'd cost
    me a fortune.
    I've done about 20,000 miles through all the seasons over the last year, and
    these three tyres were used back to back. (I've just added up my rear
    mileages quotes, and yes it doesn't make 20k miles... so I'm obviously fuzzy
    somewhere, but that's the gist. The 020's were old style,not the new NT,but
    as far as I am aware all the new changes are on the rear, the front is the
    same. And if you're wondering about my riding style, the ABS always gets in
    the way (it's scary when it lets the brakes off and you're heading for the
    back of a truck), and I deck the centre stand, admittedly it's a BM but
    still, I have fun.
    Hope this helps someone anyhow -
    Tim.
    [1]Honest...
    Tim Gray, Oct 15, 2003
  15. Rocket
    Tim Gray Guest
    DRY:
    WET:
    me a fortune.
    still, I have fun.
    Tim.
    [1]Honest...
  16. <Puts on IMHO hat>
    The 020s have less of a rounded profile than the 010s so I find cornering
    takes a bit more of a effort to tip the bike in. This also leads to the
    front being worn worryingly close to the edge and the back with zero chicken
    strips. Whether or not you judge this to be a good thing is up to you. I
    prefer some left when the pegs (and knee usually) go down bu that's just me.
    The 010 was a fantastic tyre [1] with more grip than I ever dared use. Even
    in damp conditions I was constantly surprised that it didn't lock up or at
    least squirm under my ham fisted inputs.
    The 020 on the other hand does not inspire the same confidence. I've had
    several near lowsides from the back breaking away (admittedly under
    aggressive cornering) and a couple of shuffles of the front under heavy
    breaking.
    That said, I've gone with the 020 as it's winter and I tend to do less
    hooning and more commuting so I need a tyre to last more than ~4k which is
    down to the canvass on the 010. I'm hoping to get around double that on the
    020, which should see me to the end of winter. Then it's going to be back
    to 010s.
    Pah, wuss.
    [1] Now running 020s
    AnyOne ForAPint, Oct 15, 2003
  17. Rocket
    christofire Guest
    I've had both on my SV.
    020 - roughly 9k miles from front, and similar from the rear IIRC.
    010 - roughly 5-6k miles from front, 3-4k from a rear.
    I thought the 020s were fine on hot, sunny summer days where the tyres
    got nice and hot. They felt good, and inspired confidence. However,
    they were OK[1] at all other times. Good longevity, but in the wet I
    found the rear would spin up when provoked coming out of roundabouts.
    By the end of their life they were going blue at the edges, so I tried
    010s after that set.
    010s - Great fun, feel good but they seem to be wearing out too fast for
    my liking now. My last 3 rears have been 010, lost count of the fronts.
    They were good at Cadwell, but they do square off as soon as you show
    them a motorway.
    I've only gone from 020->010, and I know I got more confidence to go
    faster. As to how it feels going back I'm not sure. When I had my 020s
    it was partly through a winter which explains the high milage for both
    tyres - tiptoeing around on icy roads. You can but try, and if they're
    not for you either ride the bike more until you wear them out or sell
    them here / ebay as part worns.
    [1] i.e. far better than the MEZ4s that the SV came with.
    christofire, Oct 15, 2003
  18. In uk.rec.motorcycles, Lozzo said:
    It was hardly bald as ****, there was still evidence of tread on there
    ;o)
    I still think it did close to 9,000 before it got to the wear
    indicators, but.
    Whinging Courier, Oct 15, 2003
  19. Rocket
    Alan.T.Gower Guest
    again.
    Actually I think that's rather good. I reckon on about 4K from my son's
    Bandit 6.
    Alan.T.Gower, Oct 15, 2003
  20. Rocket
    jsp Guest
    I thought you said a while back that you were going to stop offering
    tyre advice.
    John
    SV650
    Black it is
    and naked
    jsp, Oct 15, 2003
